raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23130 Location: Oklahoma City
Posted: Tue Jun 09, 2015 6:10 am Post subject: |
Wasted youth wrote: |
Just puting sacrifical copper parts into the transmission would also solve most of the issues. -Ray
How about a solid copper drain plug...with a magnetic core?
Some of the waste heat exchanger equipment I operated years ago in Uncle Sam's Canoe Club had sacrificial zinc anodes. Helped keep the seawater-fed shell and tube coolers from rotting away. |
They may help. I dont know if the surface area can work all of the oil....but if its working r8ght, over time it will turn green. Ray |
theramny Samba Member
Joined: October 17, 2014 Posts: 77 Location: BUFFALO NY
Posted: Sat Jul 18, 2015 8:39 am Post subject: |
what about royal purple gear oil I've been very pleased with there products |
Posted: Sat Jul 18, 2015 10:02 am Post subject: |
theramny wrote: |
Excellent gear oil. Whether it would be any better or worse at corrosion protection.....maybe yes maybe no. Even synthetics are formulated from petroleum base stocks and have some sulphur in them.
As to whether it would be fine for a steering box.....it should be just fine as long as its an EP rated gear oil.
Whether it stays in or not or leaks out any faster....dont know. Ray |
Tcash Samba Member
Joined: July 20, 2011 Posts: 12846 Location: San Jose, California, USA
Posted: Sat Sep 05, 2015 4:06 pm Post subject: steering box lube |
bsairhead wrote: |
John Deere corn head grease. And that's all i have to say about that. |
Tcash Samba Member
Tcash Samba Member
Posted: Tue Jul 10, 2018 5:52 pm Post subject: Penrite Steering box lube |
Manufacturer
https://www.penriteoil.com.au/applications/car-4wd/greases/steering-box-lube
USA Distributor
Part number LUB009
https://www.restorationstuff.com/ecommerce/
Parts Catalog
http://www.restorationstuff.com/pdf/RestorationSupplyCompany.pdf
Good Day Mates
Tcash
I purchased the Penrite Steering box lube and performed a very unscientific test on it.
Drop point: 170*C
Operating temperature range: -20C to 130C
Colour: Light Brown
One blob put in the refrigerator and brought down to 40*F
Second blob applied on 40*F plate at 75*F ambient Temp.
5 minute race is on.
5 minute race results. I wish I took more pictures. #75* took the lead laying down a thick film, just when I thought all was lost, #40* started picking up the pace laying down a thin film all the way to the end and beating #75* by a nose.
Tcash Samba Member
Tcash Samba Member
Tcash Samba Member
Posted: Wed Jul 18, 2018 10:09 pm Post subject: Re: Steering box lube |
Drop point: 170*C
Colour: Light Brown
vintage water Samba Member
Joined: September 17, 2020 Posts: 81 Location: CONCARNEAU
Posted: Wed May 25, 2022 9:20 am Post subject: Re: Steering box lube |
in the end you would recommend which oil?
thank's |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42514 Location: at the beach
Posted: Wed May 25, 2022 9:48 am Post subject: Re: Steering box lube |
Stalube GL4 from NAPA _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
