amikulics Samba Member
Posted: Sun Jul 29, 2018 12:32 pm Post subject: Knocking after rebuild |
It's been a few weeks but I finally got my 72 1700 type 4 engine back together.
I had found low compression all around so I decided to do the piston rings. My engine originally used sealing rings at the top and bottom of the cylinders but I ditched the ones on top and lapped the cylinders to the heads. Before ever starting the engine I did a quick compression check and all cylinders were at least 90 (I know compression cannot accurately be measured this way but I wanted to ensure I didn't have any huge mistakes).
Today I got the chance to start it up, however it developed a knocking sound that increases and decreases with rpm. During my rebuild I only did the rings and never split the case which is why I'm hesitant to think its crank-related. The engine also ran and sounded great before the rebuild. Also removing the top sealing ring would raise the compression ratio but I was running 91 octane so this shouldn't be a problem. I've also gone back and checked all the valves. I'm far from an expert mechanic so please feel free to suggest anything. |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42993 Location: at the beach in Northern Wokistan
Posted: Sun Jul 29, 2018 1:48 pm Post subject: Re: Knocking after rebuild |
As you put it back together did you make sure the piston arrows were all pointing the correct way? Wrist pin circlips in correctly? Double checked? Make sure you still had piston to head clearance when you took the head gaskets out if you didn't add that measurement to the shims at the bottom? Distributor in all the way? Rocker arms and shafts in the correct location and wires clearing the pushrods? _________________
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"
1971 deluxe (sold)
1977 deluxe |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5175 Location: California's Hot and Smoggy Central Valley
Posted: Sun Jul 29, 2018 2:24 pm Post subject: Re: Knocking after rebuild |
| SGKent wrote: |
| ...[did you]Make sure you still had piston to head clearance when you took the head gaskets out if you didn't add that measurement to the shims at the bottom? |
One or more pistons interfering with head... |
Posted: Sun Jul 29, 2018 2:46 pm Post subject: Re: Knocking after rebuild |
| Wasted youth wrote: |
| SGKent wrote: |
So you think the pistons are hitting the heads because they are too close without the shim? Is there a way to check by hand? |
SGKent  Samba Member
Posted: Sun Jul 29, 2018 3:55 pm Post subject: Re: Knocking after rebuild |
Pull the plugs when the engine is cold. Take a foot long piece of thick solder for plumbing, straighten it then put it into each plug one at a time until the tip hits the cylinder wall 3 inches or so after it goes in the spark plug hole. Hold onto it just because. Then rotate the engine by hand using the alternator nut. Crush the solder. If you can't crush it then there is no clearance. When the solder is pulled out, the thickness of the solder is the approximate piston to head clearance. Don't forget to remove the wrench from the alternator nut when you are done. Normally engine builders use clay for that during the build process if clearances are tight. I don't know anything but solder that will work but anything that crushes, doesn't fall apart, and doesn't stick can be used. Maybe someone else knows a product like a malleable plastic or clay in a sleeve etc that doesn't ooze out. _________________
George Carlin:
1971 deluxe (sold)
1977 deluxe |
Posted: Sun Jul 29, 2018 5:21 pm Post subject: Re: Knocking after rebuild |
| SGKent wrote: |
| ...Don't forget to remove the wrench from the alternator nut when you are done. |
Best tip all day.
When you look for solder, find the style with the lowest tin content. It will be the softest. Oatey is one brand of plumbing solder. The lable on the end gives lead and tin content in percentages. |
timvw7476 Samba Member
Posted: Sun Jul 29, 2018 10:23 pm Post subject: Re: Knocking after rebuild |
Did you hone the cylinders when installing the new rings?
the 1700/1800 really likes scuffing the thrust side of the piston skirt,
when you re-ring you can be rewarded with piston slap when cold &
warning up. Not the end of the world, but it comes & goes with thermal
warm up. Or you've got an arrow on a piston crown pointing away from the
flywheel. |
Zed999 Samba Member
Posted: Mon Jul 30, 2018 10:51 am Post subject: Re: Knocking after rebuild |
Did you loose any washers while you were fitting tineare, manifolds and carbs?
Been there done that but I think you would have stopped cranking after the first hit. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17784 Location: San Diego, California
Posted: Mon Jul 30, 2018 1:09 pm Post subject: Re: Knocking after rebuild |
No offense but are you doing this on a low budget for a reason? My question is being asked because it's a damn lot of work to go in and just do rings only to have issues like you're having. Did anyone look the heads over? Did anyone calculate the compression ratio? When you add new power to the top end and don't do anything to the bottom end it puts strain on all the old parts. Sometimes you can get away with it, sometimes not. I leave long block building to the experts because of what I said. It's just too much work to do over and over until you get it right. I'm currently working on a 1973 engine that just came back from the shop. Cost was $2200 for a rebuild. We'll see how things go. Crossing my fingers because this is the first time I've worked on one of their rebuilds.
_________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
74 Thing Samba Member
Posted: Mon Jul 30, 2018 1:14 pm Post subject: Re: Knocking after rebuild |
| What shop did you use? |
Posted: Mon Jul 30, 2018 1:18 pm Post subject: Re: Knocking after rebuild |
The shop is called Brothers VW Machine Shop in Ontario California
http://www.brothersvwmachineshop.com/ _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36454 Location: Conejo Valley, CA
Posted: Mon Jul 30, 2018 1:22 pm Post subject: Re: Knocking after rebuild |
| SGKent wrote: |
Best tip all day. |
My brother and I could have used this tip when working on his bug so many years ago. We used a ratchet, and left it on the gen nut. Then we started it up.
We heard this funny high-pitches whizzing noise, then a metallic BANG, then about 3-4 seconds later we heard a bell ringing about 50 yards down the street... it was the ratchet handle at the bottom of a high arcing trajectory hitting the pavement. We are lucky we were nowhere near it when it let go... the dent was in the decklid, not our skull. |
Posted: Mon Jul 30, 2018 1:28 pm Post subject: Re: Knocking after rebuild |
Those are the kind of mistakes a person only makes once and people can be told over and over to not make that mistake but until they do...... _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
SGKent  Samba Member
Posted: Mon Jul 30, 2018 1:51 pm Post subject: Re: Knocking after rebuild |
Piston slap is a really light knock - that is why they call it a slap. its more like a double rattle than a knock. To me I think your exhaust is leaking. _________________
George Carlin:
1971 deluxe (sold)
1977 deluxe |
Posted: Mon Jul 30, 2018 2:06 pm Post subject: Re: Knocking after rebuild |
| SGKent wrote: |
| Piston slap is a really light knock - that is why they call it a slap. its more like a double rattle than a knock. To me I think your exhaust is leaking. |
In person it sounds like something hitting something else and its loud. Do you think an exhaust leak could cause that? Also is there anywhere besides where they attach to the heads that I should be checking for an exhaust leak? |
SGKent  Samba Member
Posted: Mon Jul 30, 2018 2:12 pm Post subject: Re: Knocking after rebuild |
| amikulics wrote: |
| SGKent wrote: |
$3.99
https://www.harborfreight.com/mechanics-stethoscope-63691.html
Have any of this lying around?
George Carlin:
1971 deluxe (sold)
1977 deluxe |
Mispeld Samba Member
Joined: April 29, 2018 Posts: 366 Location: Jacksonville - Coastal NC
Posted: Mon Jul 30, 2018 3:14 pm Post subject: Re: Knocking after rebuild |
That sounds like a collapsed hydraulic lifter(s) (if you have hydraulic lifters). I personally think they sound similar to an exhaust leak. That noise doesn't sound like piston slap or "pinging" as we call it when it's too far advanced. It's possible with too much compression to need to use higher octane but I don't think we are experiencing that.
What type of lifters do you have?
Pull your valve covers and push on the pushrod side on the rockers with a large screwdriver or whatever.
Check your valve adjustments. _________________ Tom
1977 Westy. 2.0 Fuel Injected. |
Posted: Mon Jul 30, 2018 5:14 pm Post subject: Re: Knocking after rebuild |
| Mispeld wrote: |
Check your valve adjustments. |
I've left it totally stock as a 1972 so no hydraulic lifters and I have been using 91 octane gas. And any specific "problem areas" I could check for the exhaust? |
white74westy Samba Member
Posted: Mon Jul 30, 2018 5:23 pm Post subject: Re: Knocking after rebuild |
| amikulics wrote: |
| Mispeld wrote: |
I think Steve is correct. As he mentioned above, it sounds as if you have an exhaust leak(s). While you have the engine on the stand, why not find all the leaks?
Here is a video that shows you how to make a fairly inexpensive smoke machine:
https://www.thesamba.com/vw/forum/viewtopic.php?t=620083
OR
You could buy one off ebay:
https://www.ebay.com/bhp/smoke-tester
Put the smoke in the vacuum hose that attaches to the brake booster and see where it comes out. You'll quickly find all the leaks in the system.
EDIT: Make sure you "cap off" the carb intakes and the exhaust. As the fellas in the thread above make mention of, you can use nitrile gloves to do so.
Hope that proves useful!
a.
