do okrasa valves fit stock 36hp heads?
esde
esde is offline
PostPosted: Sun Aug 05, 2018 7:59 pm    Post subject: do okrasa valves fit stock 36hp heads? Reply with quote
I'd like to fit the Okrasa size 33mm intake valves to my stock heads, will they fit? And if not what are people using?
It sure would be easy if I can just order the valves, keepers, and springs from WW and be done..
modok wrote:
RichardinNZ
RichardinNZ is offline
PostPosted: Sun Aug 05, 2018 8:53 pm    Post subject: Re: do okrasa valves fit stock 36hp heads? Reply with quote
I had to have new seats installed in my stock heads to fit 33mm intake valves. However, I have read of others managing to install them with stock seats.
Richard
'58 Beetle; NZ Assembled
Dual Carb 36hp
My Car https://www.thesamba.com/vw/forum/album_page.php?pic_id=1750253
View user's profile Send private message Visit poster's website AIM Address Instagram Gallery Classifieds Feedback
esde
esde is offline
PostPosted: Wed Aug 08, 2018 6:17 pm    Post subject: Re: do okrasa valves fit stock 36hp heads? Reply with quote
I think I should have been more specific..
Will these valves fit a stock VW 36 hp head? These are the Wolfsburg West replacement valves for their Okrasa heads.
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111109601AOK
I would like to have the larger intake installed on stock heads, but finding the parts to do it is elusive.
modok wrote:
RichardinNZ
PostPosted: Thu Aug 09, 2018 3:37 am    Post subject: Re: do okrasa valves fit stock 36hp heads? Reply with quote
My understanding is that the Okrasa valves are 33mm .... So the same as I installed. Mine came from Aircooled Research. I had my stock heads modified rather than use Okrasa heads.
Richard
Dual Carb 36hp
esde
esde is offline
PostPosted: Thu Aug 09, 2018 2:57 pm    Post subject: Re: do okrasa valves fit stock 36hp heads? Reply with quote
RichardinNZ wrote:
My understanding is that the Okrasa calves are 33mm .... So the same as I installed. Mine came from Aircooled Research. I had my stock heads modified rather than use Okrasa heads.
I'm wondering if the Okrasa stem length and diameter are the same as stock? You would think that the guys at Wolfsburg West would know, but they're being jerks about answering my questions, even though it would get them a sale..
modok wrote:
RichardinNZ
PostPosted: Thu Aug 09, 2018 3:53 pm    Post subject: Re: do okrasa valves fit stock 36hp heads? Reply with quote
I cannot confirm but thought yes. However why not make contact with Matthew at Aircooled Research and get some 33mm valves from him. Subject to the seat they will do what you want to achieve. I've included some more about my heads in the link in my signature.
Richard
Dual Carb 36hp
esde
esde is offline
PostPosted: Thu Aug 09, 2018 5:42 pm    Post subject: Re: do okrasa valves fit stock 36hp heads? Reply with quote
Thanks for the info Richard. I did ask Matt, but have not heard back. I'll update when I do figure it out..
SD
modok wrote:
Robert Chambers
Robert Chambers is offline
PostPosted: Fri Aug 10, 2018 7:38 am    Post subject: Re: do okrasa valves fit stock 36hp heads? Reply with quote
I had new seats installed in my stock 36 HP heads for the WW 33 mm Okrasa intake valves. Some blending was needed after the seats were installed as the seats were slightly bigger in diameter. Fit was perfect. New guides and exhaust valves were also installed with all new springs. I lapped in the valves, checked for equal height on the valve stems and performed some minor porting and port matching. The heads look great! I hope to assemble the engine this Winter.
'63 OG 117 Herbie Replica
'56 Euro Oval Deluxe
'52 Standard Zwitter
'63 OG 117
txoval
txoval is offline
PostPosted: Sat Aug 11, 2018 11:46 am    Post subject: Re: do okrasa valves fit stock 36hp heads? Reply with quote
Matthew did my heads as well, I sent him the WW Okrasa valves and he did the rest
Stem diameter and length were same as stock
esde
esde is offline
PostPosted: Sat Aug 11, 2018 11:50 am    Post subject: Re: do okrasa valves fit stock 36hp heads? Reply with quote
Funny, he literally just responded to my email, with the same info..
modok wrote:
