59sweetrag Samba Member
Joined: June 23, 2005 Posts: 5 Location: Central California
Posted: Sat Jun 25, 2005 2:13 pm Post subject: judson supercharger choke cable??? |
i have a 59 with a cable that runs to a knob on the lower right side of my dash ( looks factory) the car had no motor when i purchased it. Is that the choke cable for a judson supercharger?? if not what is it ???? |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
coolairX2 Samba Member
Posted: Sat Jun 25, 2005 6:08 pm Post subject: Judson choke cables |
Cars with Judson's use the same choke cable but the routing through the fan shroud has to be changed. Also the original Judson kit had a extender cable so that the normal cable would reach the new location of the carb.
Other than that the choke cables are the same.
-Craig |
Steve22 Samba Member
Joined: March 05, 2004 Posts: 1389 Location: the wild unknown
Posted: Sat Jun 25, 2005 8:41 pm Post subject: Re: Judson choke cables |
coolairX2 wrote: |
-Craig |
I don't remember seeing a choke cable listed with any VW Judsons or on George Folchi's or Alejandro Martin's parts lists either... educate me please, where did you get this info? _________________ '65 Karmann Ghia 'vert
'73 Super Beetle
'59 Beetle ragtop
'73 Sunroof Transporter |
Posted: Sun Jun 26, 2005 4:34 am Post subject: Choke cable |
I had George Folchi do some work on my Judson that I installed in my 58 Ghia. In talking with him he mentioned that cable extender. I have also seen pictures of an NOS Judson kit that had this piece. It is not a complete cable only a 4 inch section of cable which is easily sourced. If you don't have it the stock cable will be short by that amount because of the reroute.
-Craig |
1958ghia Samba Member
Posted: Tue Jun 28, 2005 12:15 pm Post subject: |
Craig,
I was able to re-route the stock choke cable on my ghia to make it work. I didnt route it through the stock hole in the front engine tin, just between the rubber and tin. Then I was able to slide the choke cable further to the driver's side where the choke cable was re-drilled through the fan shroud... It was actually the exact right length... Works great too!
Kyle |
