NJ John Samba Member
Joined: September 21, 2007 Posts: 2936 Location: HdG, MD & NJ
Posted: Tue Oct 02, 2018 4:50 pm Post subject: '73 Starndard before and after lowering |
This is how I got it. 5.5 rear rims with 215/65-15 and 4.5 fronts with tall 195/70-15 tires. Car is otherwise stock.
This is with a 3" narrow beam with adjusters, dropped disc brake spindles and 145/15 front tires.
This is the rear lowered one outer spline. Same 215/65-15 tires.
_________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
APPLEGREENVW Samba Member
Joined: November 30, 2003 Posts: 2557 Location: Seekonk,Massachusetts USA
Posted: Tue Oct 02, 2018 8:15 pm Post subject: Re: '73 Starndard before and after lowering |
Nah, it's not down that much on the adjusters. It's a in combo with the spindles. It rides and handles pretty good. I narrow the stock sway bar, but haven't put it on yet. And I used some no name blue low pressure gas shocks. Can't wait to try the sway bar, though. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2392 Location: DEEK - U.S.A.
Posted: Tue Oct 02, 2018 10:21 pm Post subject: Re: '73 Starndard before and after lowering |
I Give It 2 Thumbs Up!  _________________ Jesucristo es mi Señor y Salvador! |
Posted: Wed Oct 03, 2018 1:48 pm Post subject: Re: '73 Starndard before and after lowering |
Thanks!
I may switch to 205/65-15 on the rear. These tires came on the car and are kinda big. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
Eskamobob1 Samba Member
Joined: August 08, 2016 Posts: 541 Location: South OC SoCal
Posted: Wed Oct 03, 2018 1:57 pm Post subject: Re: '73 Starndard before and after lowering |
You should try some spacers and getting a flushed look in the front like you did in the back. Mind if I ask if you have any rubbing in the back? I was thinking of 215/60s in the back on mine, but if you dont rub, then the more meaty setup looks way better IMO _________________ '74 - front disks/lots more work to do |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33194 Location: Hot Arizona
Posted: Wed Oct 03, 2018 2:12 pm Post subject: Re: '73 Starndard before and after lowering |
NJ John wrote: |
This is how I got it. 5.5 rear rims with 215/65-15 and 4.5 fronts with tall 195/70-15 tires. Car is otherwise stock. |
Many here would doubt that the car is actually otherwise stock !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Wed Oct 03, 2018 2:38 pm Post subject: Re: '73 Starndard before and after lowering |
Eskamobob1 wrote: |
You should try some spacers and getting a flushed look in the front like you did in the back. |
I like the narrowed front end drag car look. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79781 Location: Sneaking up behind you
Posted: Wed Oct 03, 2018 2:48 pm Post subject: Re: '73 Starndard before and after lowering |
APPLEGREENVW wrote: |
Did you use special lowering ball joints? |
You don't need "lowered ball joints" with drop spindles. The front end geometry is the same as stock.
145-15 fronts really kill the braking and handling.
When selecting rear tires don't forget the will alter your engine speed when cruising.
I'm using 205/60-15 rear and 195/55-15 front with a 3" drop.
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Wed Oct 03, 2018 3:59 pm Post subject: Re: '73 Starndard before and after lowering |
I have a few sets of rims. One has 185/60-15 fronts. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
