'73 Starndard before and after lowering
NJ John
NJ John is offline
PostPosted: Tue Oct 02, 2018 4:50 pm    Post subject: '73 Starndard before and after lowering Reply with quote
This is how I got it. 5.5 rear rims with 215/65-15 and 4.5 fronts with tall 195/70-15 tires. Car is otherwise stock.
This is with a 3" narrow beam with adjusters, dropped disc brake spindles and 145/15 front tires.
This is the rear lowered one outer spline. Same 215/65-15 tires.
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
APPLEGREENVW
APPLEGREENVW is offline
PostPosted: Tue Oct 02, 2018 5:02 pm    Post subject: Re: '73 Starndard before and after lowering Reply with quote
Did you use special lowering ball joints?
Parts for sale https://www.thesamba.com/vw/classifieds/search.php?username=APPLEGREENVW
02/76 Beetle sedan
View user's profile Send private message Send e-mail YouTube Gallery Classifieds Feedback
NJ John
NJ John is offline
PostPosted: Tue Oct 02, 2018 8:15 pm    Post subject: Re: '73 Starndard before and after lowering Reply with quote
Nah, it's not down that much on the adjusters. It's a in combo with the spindles. It rides and handles pretty good. I narrow the stock sway bar, but haven't put it on yet. And I used some no name blue low pressure gas shocks. Can't wait to try the sway bar, though.
57BLITZ
57BLITZ is offline
PostPosted: Tue Oct 02, 2018 10:21 pm    Post subject: Re: '73 Starndard before and after lowering Reply with quote
I Give It 2 Thumbs Up! Cool
Jesucristo es mi Señor y Salvador!
NJ John
NJ John is offline
PostPosted: Wed Oct 03, 2018 1:48 pm    Post subject: Re: '73 Starndard before and after lowering Reply with quote
Thanks!
I may switch to 205/65-15 on the rear. These tires came on the car and are kinda big.
Eskamobob1
Eskamobob1 is offline
PostPosted: Wed Oct 03, 2018 1:57 pm    Post subject: Re: '73 Starndard before and after lowering Reply with quote
You should try some spacers and getting a flushed look in the front like you did in the back. Mind if I ask if you have any rubbing in the back? I was thinking of 215/60s in the back on mine, but if you dont rub, then the more meaty setup looks way better IMO
'74 - front disks/lots more work to do
Cusser
Cusser is offline
PostPosted: Wed Oct 03, 2018 2:12 pm    Post subject: Re: '73 Starndard before and after lowering Reply with quote
Many here would doubt that the car is actually otherwise stock !!!
NJ John
NJ John is offline
PostPosted: Wed Oct 03, 2018 2:38 pm    Post subject: Re: '73 Starndard before and after lowering Reply with quote
I like the narrowed front end drag car look.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Oct 03, 2018 2:48 pm    Post subject: Re: '73 Starndard before and after lowering Reply with quote
You don't need "lowered ball joints" with drop spindles. The front end geometry is the same as stock.
145-15 fronts really kill the braking and handling.
When selecting rear tires don't forget the will alter your engine speed when cruising.
I'm using 205/60-15 rear and 195/55-15 front with a 3" drop.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
NJ John
NJ John is offline
PostPosted: Wed Oct 03, 2018 3:59 pm    Post subject: Re: '73 Starndard before and after lowering Reply with quote
I have a few sets of rims. One has 185/60-15 fronts.
