1980 Vanagon Distributor Drive Gear Spacer
chisco_jfr
chisco_jfr is offline
PostPosted: Thu Nov 15, 2018 7:59 am    Post subject: 1980 Vanagon Distributor Drive Gear Spacer Reply with quote
Hi, I have a question about my VW Vanagon 1980 with 2.0L Aircooled Engine (CV). Can I use the "DISTRIBUTOR DRIVE GEAR SPACER" from T1 (part number: 111-105-235A) in a T4 engine? I can't find the T4 spacer in the web.
This is the spacer from T1
This is the spacer from T4
hazetguy
hazetguy is offline
PostPosted: Thu Nov 15, 2018 9:46 am    Post subject: Re: 1980 Vanagon DISTRIBUTOR DRIVE GEAR SPACER Reply with quote
No, you can not use the Type 1 washer. They are very dimensionally different from a Type 4 washer.
Type 1 on left, Type 4 on right.
MarkWard
MarkWard is offline
PostPosted: Thu Nov 15, 2018 9:57 am    Post subject: Re: 1980 Vanagon DISTRIBUTOR DRIVE GEAR SPACER Reply with quote
It's not exactly clear, but it looks like the part number is 021 105 235 for the 2.0 shim if that helps your search. I came across this link searching the part number. Porsche 914 probably used the same washer too.
https://www.thesamba.com/vw/forum/archive/index.php/o-t--t-178228--.html
chisco_jfr
PostPosted: Thu Nov 15, 2018 10:13 am    Post subject: Re: 1980 Vanagon DISTRIBUTOR DRIVE GEAR SPACER Reply with quote
Did you know where I can buy the Type 4 washer?
Wildthings
Wildthings is offline
PostPosted: Thu Nov 15, 2018 10:59 am    Post subject: Re: 1980 Vanagon Distributor Drive Gear Spacer Reply with quote
Contact any vendor by phone, most have a shop or some association with a shop that might have bins full of misc. parts.
You could also place a WTB (want to buy) add in the Samba classifieds.
hazetguy
hazetguy is offline
PostPosted: Thu Nov 15, 2018 11:01 am    Post subject: Re: 1980 Vanagon DISTRIBUTOR DRIVE GEAR SPACER Reply with quote
i sent you a PM. check your inbox.
dhaavers
dhaavers is offline
PostPosted: Thu Nov 15, 2018 5:32 pm    Post subject: Re: 1980 Vanagon Distributor Drive Gear Spacer Reply with quote
I'm pretty sure I came across a member that was offering these in the classifieds recently...???
Have a look around...
- Dave
"The WonderVan"
chisco_jfr
PostPosted: Fri Nov 16, 2018 6:14 am    Post subject: Re: 1980 Vanagon Distributor Drive Gear Spacer Reply with quote
Thanks to alll, specially to hazetguy. I found the washer here in the classifieds. Very Happy
dhaavers
dhaavers is offline
PostPosted: Fri Nov 16, 2018 7:45 am    Post subject: Re: 1980 Vanagon Distributor Drive Gear Spacer Reply with quote
^^^ Link? I couldn't find it...
Sad
- Dave
"The WonderVan"
chisco_jfr
PostPosted: Fri Nov 16, 2018 7:46 am    Post subject: Re: 1980 Vanagon Distributor Drive Gear Spacer Reply with quote
Sad
- Dave
https://www.thesamba.com/vw/classifieds/detail.php?id=2228379
dhaavers
dhaavers is offline
PostPosted: Fri Nov 16, 2018 8:01 am    Post subject: Re: 1980 Vanagon Distributor Drive Gear Spacer Reply with quote
Score! Glad you found one...
Cool
- Dave
"The WonderVan"
