Bugginout2019 Samba Member
Joined: December 18, 2018 Posts: 5 Location: Galveston, TX
Posted: Wed Dec 26, 2018 1:02 pm Post subject: Re: My 67 Burro off road overland bug |
How do you seal the body to the cage? Example, where the cage penetrates the front firewall. Do you weld the fire wall to the cage? Is there a rubber grommet used to seal it off to disallow dust and other debris from entering the cockpit?
20valve wrote: |
Here’s a few pictures during the build.
20valve Samba Member
Posted: Fri Dec 28, 2018 10:10 am Post subject: Re: My 67 Burro off road overland bug |
Bugginout2019 wrote: |
The cage tubes run through 1.5” holes that are bored through the body lift then welded to it. After that it’s seam sealed using brush able body seam sealer.
20valve wrote: |
Posted: Fri Dec 28, 2018 10:11 am Post subject: Re: My 67 Burro off road overland bug |
Triple Driver wrote: |
Could you please describe the gauge layout. How does your speedo operate? With a cable? What kind of shocks are you running?
I’m using a GPS speedometer.
Here's my set up, just for bang'n around desert roads and trails.
69builder Samba Member
Posted: Mon Nov 11, 2019 2:54 pm Post subject: Re: My 67 Burro off road overland bug |
What type of kerosene heat setup did you use @ 20valve? |
