Paul70Ghia Samba Member
Posted: Thu Dec 27, 2018 1:36 pm Post subject: IRS Rear bearing play |
Hi, rocking the top and bottom of tyres on both sides shows a lot of play in the rear bearings with an audible clonk. This can also be heard going over pot holes.
I’ve replaced the bearings on one side with little/no improvement. Torque is correct applied with mr torque tool.
If it’s rocking up/down, then doesn’t this mean the outer, roller bearing is too large a diameter for the stub axle?
Any similar experience/solutions? |
Matt Wilson Samba Member
Joined: November 14, 2005 Posts: 2408 Location: Colorado
Posted: Thu Dec 27, 2018 5:08 pm Post subject: Re: IRS Rear bearing play |
When I tighten my axle nut for the stub axle I also gently slosh the car. That way I remove all the play.
If the bearing fits the bearing shell, and the race fits snug between the stub shaft and the bearing, you should be okay. It is possible to assemble the bearing stack incorrectly as well as install with parts missing. When you say you replaced the bearings on one side, is that one bearing stack on one wheel, or just the outer bearing?
I've never used a Mr. Torque tool, just an impact wrench or breaker bar.
Sometimes if you have hard to find noises, it can be helpful to get under the car with a rubber mallet and gently bang around to find the rattle. _________________ 1972 Standard Beetle
1969 Baja Beetle |
helowrench Samba Member
Joined: August 27, 2003 Posts: 567 Location: dallas texas
Posted: Thu Dec 27, 2018 5:29 pm Post subject: Re: IRS Rear bearing play |
Other than the missing/incorrect parts scenario, I have also seen case where the spacer between the bearing inner races collapsed.That will lead to play, and rapid failure.
Rob _________________ Current VWs:
70 bug vert for wifey
73Thing bucket o rust
73 914 1.7
12 Passat 2.5 Highway cruiser |
Car32 Samba Member
Posted: Sat Jun 12, 2021 11:03 am Post subject: Re: IRS Rear bearing play |
I hope this is the right thread for my new-to-me '71 Ghia's IRS situation.
The left axle is noticeably thicker than the left axle (as in, larger diameter). I measure 29mm versus 25mm with a micrometer.
When I tug on the axles, the left one can be moved in and out about 1" while the right one is stable.
Did some PO replace the left axle with something from another car? _________________ First Car = 1970 Westfallen Typ II
Second Car = 1966 Baja
Nth Car = 2006 Cayman S
1971 Karmann Ghia Coupe |
Ian Godfrey Samba Member
Joined: September 25, 2006 Posts: 1138 Location: Melbourne Australia
Posted: Sat Jun 12, 2021 2:19 pm Post subject: Re: IRS Rear bearing play |
That is really odd.... and welcome to the forum
You should not be able to move the IRS stub axle in and out.
hopefully you can easily find some second hand parts to correctly build up you left axle. you will need axle, bearings, outer bearing cover, seals, spacers, big circlip, brake drum, nut etc
it might be easiest to find a complete trailing arm to rebuild.
I am not sure how experienced you are, but 2 suggestions, don't use chinese bearings, and see if you can get someone to spin the stub axle between centres on a lathe to check that is is straight.
I put one together and had a nasty wheel wobble, I thought it was the drum but it was the axle |
Car32 Samba Member
Posted: Sun Jun 13, 2021 1:24 pm Post subject: Re: IRS Rear bearing play |
Thanks for the tips, Ian.
I wish I'd noticed the free play when I installed the rear discs on the car. Looks like I'll be taking that side apart again. _________________ First Car = 1970 Westfallen Typ II
