Flap over voltage regulator
The Beatles beetle
The Beatles beetle is offline
PostPosted: Thu Dec 27, 2018 8:21 am    Post subject: Flap over voltage regulator Reply with quote
I was looking through the 1971 beetle owner’s manual and I saw a flap hanging over the voltage regulator under the rear seat. It looks like it’s made out of paper and that there might be more under the rear seat.
See image: https://www.thesamba.com/vw/archives/manuals/71bug/page51.jpg
Is there any more paper in there or is that the only place where it has it?
If anyone can make the dimensions for it, I would appreciate it.
Maddel
Maddel is offline
PostPosted: Thu Dec 27, 2018 8:46 am    Post subject: Re: Flap over voltage regulator Reply with quote
The original cardboard tends to sort of scorch...
I used heat-resistant thin resin material (like a conductor plate) instead.
The Beatles beetle
PostPosted: Thu Dec 27, 2018 9:08 am    Post subject: Re: Flap over voltage regulator Reply with quote
Do you have the dimensions for it?
Maddel
Maddel is offline
PostPosted: Thu Dec 27, 2018 10:59 pm    Post subject: Re: Flap over voltage regulator Reply with quote
Will work on the bug today and take the measurements for you.
May be I'll be able to locate the original cardboard one too for the dimensions.
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Fri Dec 28, 2018 4:36 am    Post subject: Re: Flap over voltage regulator Reply with quote
Modern (and better) solid state Bosch regulators are even more important to keep protected - as the entire top "cover" of that style regulator is actually D+... the raw generator output, so basically, it's live when the engine is running, something you definitely don't want some stray metal object to slither down there and come in contact with.
Andy T.
Maddel
Maddel is offline
PostPosted: Fri Dec 28, 2018 1:24 pm    Post subject: Re: Flap over voltage regulator Reply with quote
Excavated the original charred cardboard cover, here are the dimensions in millimeters:
The Beatles beetle
PostPosted: Sat Dec 29, 2018 2:43 pm    Post subject: Re: Flap over voltage regulator Reply with quote
Thank you so much, Maddel! I’ll make one for my bug next week
vamram Premium Member
vamram is offline
PostPosted: Sat Dec 29, 2018 3:04 pm    Post subject: Re: Flap over voltage regulator Reply with quote
Where can you get that thin resin material?
Click to view image
Save the Supers!!
The Beatles beetle
PostPosted: Sat Dec 29, 2018 7:47 pm    Post subject: Re: Flap over voltage regulator Reply with quote
Sorry if I sound very exigent but can you tell me its thickness?
Maddel
Maddel is offline
PostPosted: Sun Dec 30, 2018 3:49 am    Post subject: Re: Flap over voltage regulator Reply with quote
May be my description was a bit misleading... Embarassed
I used this epoxy glass cloth GFK material - but I'm in Germany.
Translation from the German vendors web shop:
Fiberglass (glass fabric-based laminates) is a pressed material consisting of special fiberglass cloth impregnet with thermosetting epoxy resin binder. The material has good processability characteristics. Compete successfully with metals, plastics, carbon fiber. Exellent electric performance and mechanical properties.
Applications: Is ussed for manufacture of gears. transformer spacers, electrical generators, low voltage insulating washers, warm wheels, bushings, bearings, cams, seal rings, pulleys and other articles of industrial application. The material is applicatedmaiinly in transformator and motor engineering, houshold appliance engineering, switch engineering, measuring devices, machine and instrumental engineering.
I think in American English it's called glass-fiber reinforced plastic (GRP).
I'm sure there are many providers of such sheets in the States.
allenw
allenw is offline
PostPosted: Sun Dec 30, 2018 5:42 am    Post subject: Re: Flap over voltage regulator Reply with quote
GRP is what we call Fiberglass in the US
Maddel
Maddel is offline
PostPosted: Sun Dec 30, 2018 6:34 am    Post subject: Re: Flap over voltage regulator Reply with quote
So do we over here! Laughing
Here you go...
- original card board: 0.7 millimeters
- alternative fiberglass sheet: 0.5 millimeters
vamram is offline
PostPosted: Sun Dec 30, 2018 7:16 am    Post subject: Re: Flap over voltage regulator Reply with quote
"Fiberglass" explained by a German engineer!! Laughing Thanks, Maddel, not laughing at you, but at the simplicity of the translated then filtered down answer.
Click to view image
Save the Supers!!
AlmostHeavenWV_VW
AlmostHeavenWV_VW is offline
PostPosted: Mon Jul 29, 2019 7:24 pm    Post subject: Re: Flap over voltage regulator Reply with quote
I made my own VR 'flap' today:
Discovered that the 'Heavy Duty' 3-ring binders have a semi-rigid plastic resin type board in them when I was replacing a broken binder.
Then, following the the footsteps of TDCTDI, I thought "Hey that'd make a good cover flap for the VR!"
So....
Here's the plastic/resin board from inside the 'binding' of the 3 ring binder:
(It's from a 4" binder, IIRC)
Take the bolt off the driver's side of the rear seat rail:
Slide the resin board under the seat rail, choose your orientation/ placement of the resin board and mark it. Then, remove the board and drill a hole/slot for the seat rail bolt to pass through. I also trimmed the corner to allow the board to fit better up against the B-pillar:
Slide the board into place, and re-fasten the rear seat rail bolt.
Before
After
Best of all, it was free! (or $5 if you need to buy a binder to cannibalize)
Happy bug'n!
1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor
The Beatles beetle
PostPosted: Tue Aug 06, 2019 5:13 pm    Post subject: Re: Flap over voltage regulator Reply with quote
So....
Before
After
Happy bug'n!
That’s actually a great idea. I made one out of an old rubber floor mat, so far no problems except it’s flimsiness. I’m not running a VR because of the alternator conversion. In its place, I have a small fuse box for my accessories. Cardboard was out of the picture but I wanted to get an idea of what I could make with different materials.
DesignBuild
DesignBuild is offline
PostPosted: Fri Jun 11, 2021 3:14 pm    Post subject: Re: Flap over voltage regulator Reply with quote
If you wanted to do the GRP you just need a sheet or two of glass or tempered Masonite. Wax the surfaces very well, place a sheet of woven glass cloth on the surface and slowly and carefully saturate the cloth with catalyzed resin. Let it get tacky and apply the other piece of waxed glass or waxed Masonite and apply some weight. Let it cure.
Carefully pry the pieces apart using a bit of heat from a hair dryer. When you get it free trim as necessary. You can use pop rivets to attach it to the channel the wires go through using short pop rivets. If you heat it with the hair dryer you can put a 90 degree bend in the GRP and then fasten the GRP behind the VR. with one bent edge over the VR to protect the connections from contact with the under side of the rear seat.
You can get a kit at auto parts stores that included the resin, cloth and roving, and a tube of liquid catalyst. There is usually more than enough resin for this application. Actually there should be enough resin and materials to make an air dam if you can construct a template to form it against.
