bakersam Samba Member
Joined: November 03, 2006 Posts: 119 Location: Washington DC
Posted: Wed Jan 02, 2019 3:15 pm Post subject: Getting a discharge light with my new solid state regulator |
| Recently purchased a solid state 6V regulator from Wolfsburg West. Straight forward installation, but when I start the engine the battery discharge light stays on. Pull the ground lead off the battery and the engine stops dead confirming what the light's telling me. Appears to be the same connection layout as the old regulator so I'm baffled as to what's going on here. Anyone have any thoughts? |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36346 Location: Conejo Valley, CA
Posted: Wed Jan 02, 2019 3:18 pm Post subject: Re: Getting a discharge light with my new solid state regulator |
| Good ground on the regulator? |
Posted: Wed Jan 02, 2019 3:40 pm Post subject: Re: Getting a discharge light with my new solid state regulator |
Phil,
I think so. Same connections as with the old regulator and bolted onto the generator as with the old one. |
Posted: Wed Jan 02, 2019 3:46 pm Post subject: Re: Getting a discharge light with my new solid state regulator |
| PS. Discharge light will eventually go out if you run the rpm up high enough. Not old generator brushes either. Just put a new set in a couple weeks ago. |
KTPhil  Samba Member
Posted: Wed Jan 02, 2019 4:25 pm Post subject: Re: Getting a discharge light with my new solid state regulator |
Beats me, then! I'd call Wolfsburg West and ask them before doing anything further that might void a warranty.
Nobody's perfect; give them a chance to make it right. |
Posted: Wed Jan 02, 2019 6:41 pm Post subject: Re: Getting a discharge light with my new solid state regulator |
Phil,
Thanks. Probably the wisest course of action.
Regards,
Sam |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53200 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Jan 02, 2019 7:01 pm Post subject: Re: Getting a discharge light with my new solid state regulator |
Why did you replace the regulator? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Jan 03, 2019 6:26 am Post subject: Re: Getting a discharge light with my new solid state regulator |
| A solid state regulator sounded like a more reliable design than the old electromechanical system. Old regulator was working ok and the discharge light went out at idle. Clearly the solid state one wants more juice before it cuts off the battery which certainly isn't any improvement over the old one. |
tisius Samba Member
Joined: July 11, 2011 Posts: 1570 Location: Rotterdam,NL (+Chicago,IL)
Posted: Fri Jan 04, 2019 7:28 am Post subject: Re: Getting a discharge light with my new solid state regulator |
I think that sounds like a plausible explanation.
If you set the idle speed too low with a stock regulator, the discharge light can come on at idle as well. _________________ drive it like you just robbed the bank
.... if it ain't dutch, it ain't much! |
JPB1 Samba Member
Posted: Sat Jan 05, 2019 12:39 pm Post subject: Re: Getting a discharge light with my new solid state regulator |
This happens with mine on the '53, increase the choke on starting (increase idle) no problems. Seems that you have to be above the std 800 rpm for the regulator to cut in. Apart from that, it works just fine.
(note it you using LEDs on the speedo panel, which I am, you will get a low-level glow, due to their voltage sensitivity, but when they are on, you'll clearly notice the difference - way better than tungsten bulbs, and less juice) |
Posted: Sat Jan 05, 2019 4:54 pm Post subject: Re: Getting a discharge light with my new solid state regulator |
| Would that it was just low rpm. When it starts, the discharge goes out as expected. Then in a few seconds it begins to glow brighter and brighter until it's fully illuminated. No amount of rpm will put this out. Replaced the generator brushes and double checked both are properly seated. Tried both the solid state and old electromechanical regulators with no improvement. Checked the belt for looseness...even checked the pulley key to ensure it hadn't sheared. Well at least I know it isn't the solid state regulator.... |
DDub Samba Member
Joined: January 06, 2005 Posts: 320 Location: central pa.
Posted: Sat Jan 05, 2019 6:20 pm Post subject: Re: Getting a discharge light with my new solid state regulator |
| Put the original back on and send this one back. |
