Unique numbers on generator pulley
Mister.64
Mister.64 is offline
PostPosted: Wed Jan 30, 2019 2:27 pm    Post subject: Unique numbers on generator pulley Reply with quote
Long time reader and first time posting- looking for some information. Restoring a ‘64, numbers matching car. Looking closely at the generator pulley when I got the car, I noticed painted numbers. All odd, 1-35 some are very visible. Can anyone share what these are for? I’ve never come across this before in pictures and not seen these on another. They look original.
( i hope there is enough resolution ) I don’t plan to paint the pulley or clean it...don’t want to risk removing them!
KTPhil Premium Member
KTPhil is offline
PostPosted: Wed Jan 30, 2019 3:11 pm    Post subject: Re: Unique numbers on generator pulley Reply with quote
It's a code for ancient mysteries relating to the children of Jesus.
vwfreek61
vwfreek61 is offline
PostPosted: Wed Jan 30, 2019 4:16 pm    Post subject: Re: Unique numbers on generator pulley Reply with quote
My numbers matching '64 has the numbers on the pulley also.
Kenneth
1964 Bug with Saxomat
1976 VW/Harley Trike Autostick
1987 Vanagon Westy w/Subaru EJ25 and reversed 4EAT
VeeDubability on YouTube
View user's profile Send private message Instagram YouTube Gallery Classifieds Feedback
sjbartnik
sjbartnik is offline
PostPosted: Wed Jan 30, 2019 5:40 pm    Post subject: Re: Unique numbers on generator pulley Reply with quote
Are they 4, 8, 15, 16, 23, 42?
1965 Volkswagen 1500 Variant S
2000 Kawasaki W650
Eric&Barb
Eric&Barb is offline
PostPosted: Wed Jan 30, 2019 7:03 pm    Post subject: Re: Unique numbers on generator pulley Reply with quote
Would you post a good close up of that pulley as straight on as possible?
Our DEC62 built single cab had those markings, but since have faded away over the last three decades.
In Stereo, Where Available!
iowegian Premium Member
Samba Curmudgeon
iowegian is offline
PostPosted: Wed Jan 30, 2019 8:54 pm    Post subject: Re: Unique numbers on generator pulley Reply with quote
What's the Powerball number?
h~moto
h~moto is offline
PostPosted: Wed Jan 30, 2019 9:15 pm    Post subject: Re: Unique numbers on generator pulley Reply with quote
What is the dohickey that is mounted on the left firewall?
KTPhil is offline
PostPosted: Wed Jan 30, 2019 9:48 pm    Post subject: Re: Unique numbers on generator pulley Reply with quote
Autostick plumbing?
Eric&Barb
PostPosted: Wed Jan 30, 2019 10:32 pm    Post subject: Re: Unique numbers on generator pulley Reply with quote
KTPhil wrote:
Autostick plumbing?
Pre-1968 should be Saxomat, not Auto-Stick.
mukluk
mukluk is offline
PostPosted: Wed Jan 30, 2019 11:02 pm    Post subject: Re: Unique numbers on generator pulley Reply with quote
Eric&Barb wrote:
KTPhil wrote:
Autostick plumbing?
And if you go down into vwfreek61's signature line and click on where it says "1964 Bug with Saxomat", you can read all about the car.
Wink
Smurf
Smurf is offline
PostPosted: Thu Jan 31, 2019 7:31 am    Post subject: Re: Unique numbers on generator pulley Reply with quote
Someone is a Lost fan Laughing
1962 Beetle
1977 Westfalia (Subaru Conversion)
"Traveling in a fried-out Kombi
On a hippie trail head full of zombie"
-Men at Work
panicman
panicman is offline
PostPosted: Thu Jan 31, 2019 8:40 am    Post subject: Re: Unique numbers on generator pulley Reply with quote
Careful guys, if you run the engine backward, you’ll hear a satanic message.
vwfreek61
PostPosted: Thu Jan 31, 2019 1:05 pm    Post subject: Re: Unique numbers on generator pulley Reply with quote
I'll get a close up when it warms up, might be a couple weeks.
Kenneth
Eric&Barb
PostPosted: Wed Nov 06, 2019 9:55 pm    Post subject: Re: Unique numbers on generator pulley Reply with quote
Did it get warm enough to get that shot?? Wink
bnam
bnam is offline
PostPosted: Thu Nov 07, 2019 4:43 am    Post subject: Re: Unique numbers on generator pulley Reply with quote
Looks to me like 1,3,5... to 31,33,35. This corresponds to degree markings if each is multiplied by 10. Not sure why.
Click to view image
1952 Citroen TA 11BL
Snort
Snort is offline
PostPosted: Thu Nov 07, 2019 10:08 am    Post subject: Re: Unique numbers on generator pulley Reply with quote
Moved from the Ghia zone.
Here is a photo of a 40hp generator rear pulley half. It's from a 1962 Ghia engine which from all appearances it seems to be a relatively unmolested July 1962 motor.
John Moxon Premium Member
John Moxon is offline
PostPosted: Thu Nov 07, 2019 12:00 pm    Post subject: Re: Unique numbers on generator pulley Reply with quote
This reminds me of the numbers to be found on Judson Supercharger rotors. They were balanced on a Gishault Balancing Table. The end of the rotor had numbers printed on it and the numbers illuminated by the strobe light on the balancer indicated the area where metal had to be removed to balance the unit.
You'll only find these numbers on a NOS rotor as gas washed off the numbers very quickly.
However I can't imagine a generator pulley would need to be balanced.
John.
Eric&Barb
PostPosted: Thu Nov 07, 2019 1:41 pm    Post subject: Re: Unique numbers on generator pulley Reply with quote
Wonder if the factory unit of pulley and armature of the gen installed in each VW were balanced together??
Snort
Snort is offline
PostPosted: Fri Nov 08, 2019 4:12 pm    Post subject: Re: Unique numbers on generator pulley Reply with quote
OK, this is totally speculation and faded memories but I seem to recall reading that VW balanced the generator/fan/pulley assembly by adding weight to the outside pulley half, like the weight shown in my photo above. I don't see how that much weight on such a small diameter pulley would be an effective balancing mechanism but maybe those fans were really close to being balanced and it only took a little but of weight to make them run smoothly. I'm not sure how the numbers would work into that but maybe John Moxon's Judson rotor balancing theory would fit into this.
pastellgreen
pastellgreen is offline
PostPosted: Sun May 15, 2022 1:06 pm    Post subject: Re: Unique numbers on generator pulley Reply with quote
Also found these numbers on the generator pulles.
I read 27 29 31 33 35
Still a question for what these are standing for
