Rusty Brockmann Samba Member
Joined: June 14, 2006 Posts: 12 Location: Longmont, CO
Posted: Wed Jan 23, 2019 10:20 am Post subject: Beetle flatbed truck |
I have been wanting to build a truck with a beetle cab for quite some time. There have been some really interesting and amazing custom trucks built already, that can be found under Volksrods and Rat Rods, but most of them look too short coupled for any real use as a truck. I have a decorative metal business and often need to carry 4x8 foot sheets of steel and also finished pieces of work. With that in mind the truck would need a minimum bed size of 4x8 feet and the bed would have to be flat with tie downs.
vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1479 Location: Richmond, VA
Posted: Wed Jan 23, 2019 2:43 pm Post subject: Re: Beetle flatbed truck |
Thanks, that was the intention. To keep the bed low I wanted to avoid the doghouse cooling so many truck builders keep. Just like the weather, a lot of writers suggest a Type 3 or 4 motor, but no one does anything about it. I opted for the Type 4 because I like fuel injection for mountain driving and I wanted the extra torque for the additonal weight I was going to add.
The motor is essentially a balanced 2 liter with 1977 Type 2 fuel injection. I kept it where all good air cooled motors belong--in the back. Since it was going to be under the bed, I built special shrouding to separate incoming fresh air from outgoing exhaust air.
vaughn bros. Samba Member
Joined: October 13, 2003 Posts: 2398 Location: Hickory, NC
Posted: Fri Jan 25, 2019 9:53 am Post subject: Re: Beetle flatbed truck |
Truck and especially engine look healthy.😎 |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16803 Location: State College, PA
Posted: Sat Jan 26, 2019 7:47 am Post subject: Re: Beetle flatbed truck |
Very nice work. Looks like you constructed pretty much a full frame. How much did you extend it? Looks like at least 2 feet. _________________ D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
Posted: Sat Jan 26, 2019 10:37 am Post subject: Re: Beetle flatbed truck |
Wow, sharp eyes. In actual fact the wheelbase is 22 inches longer. Here are a few pictures, but for a more detailed account you can check out my website at https://idlehandsshop.com/
This gave the cab section a 4 inch lift. I will continue to post here to the Samba on what I did, because I see so many other great ideas and pieces of work here and would encourage anyone else to follow their whim. Or their folly as in my case. Thanks to Everett for this site. |
Posted: Sat Jan 26, 2019 11:22 am Post subject: Re: Beetle flatbed truck |
Dam😎 |
Posted: Sat Jan 26, 2019 5:46 pm Post subject: Re: Beetle flatbed truck |
What really got me moving on this project was watching what others did to create a truck cab. Most seemed to go the route of grafting old truck cab backs and corners onto beetle front body halves. Often this included chopping the cab. I wanted plenty of room in my cab so a chop was not in the picture. I also like the nice tight fit of a VW beetle. I wanted the doors to close with that pneumatic thump, that new beetles had.
Some old time pickups had sort of a squared off back and I also liked that. I had plans to make this puppy look like it could have come from the 30s or 40s. The method I used was to make a rounded tube back corner for the cab. This made the cab back very rigid and gave me a rounded steel corner, that would be easy to finish for body work and paint. It became even more solid, when I welded a single plate of 16ga. sheet steel to the tube frame.
Last edited by Rusty Brockmann on Mon Jan 28, 2019 6:03 pm; edited 1 time in total |
Posted: Sun Jan 27, 2019 10:35 am Post subject: Re: Beetle flatbed truck |
very cool approach on the frame and cab. Wish you had done this a couple years ago and I may have changed my approach to my temporarily stalled hearse project. When I was laying my extension out, I had played with length increases from 14 to 24 inches, so I pretty much had a good idea of where you were. Great work! _________________ D-Dubya Manx clone 1914. Ex wifes car.
MMW Samba Member
Joined: April 30, 2012 Posts: 846 Location: northern NJ
Posted: Sun Jan 27, 2019 6:24 pm Post subject: Re: Beetle flatbed truck |
Very cool. Definitely awesome job and very nice craftsmanship. I would add tool boxes behind the cab/under the bed to fill the space. _________________ Mic
1959 356 coupe
Missing the original engine 72488
Update - third pc. found!
Now just need the case halves.
1965 fenderless beetle |
Posted: Tue Jan 29, 2019 7:26 pm Post subject: Re: Beetle flatbed truck |
andk5591 wrote: |
very cool approach on the frame and cab. Wish you had done this a couple years ago and I may have changed my approach to my temporarily stalled hearse project. When I was laying my extension out, I had played with length increases from 14 to 24 inches, so I pretty much had a good idea of where you were. Great work! |
Thank you. Having just looked at your hearse project, I see some pretty interesting engineering. My method of extending the wheelbase might be a little more straightforward, but unfortunately it causes quite a bit of lift. This is OK for my project, because I wanted the lift for the truck look. Yours is going to look better for the hearse idea, because to lower height will make it look longer. I look forward to seeing you finish it. Great carpentry and some pretty clever ways of dealing with the engine. |
Posted: Wed Jan 30, 2019 8:55 am Post subject: Re: Beetle flatbed truck |
Thanks - and type 4 would have been an easier way to do the engine, but why make it easy LOL. Hoping to get back to it this year...but I said that last year.  _________________ D-Dubya Manx clone 1914. Ex wifes car.
Posted: Fri Mar 01, 2019 8:48 am Post subject: Re: Beetle flatbed truck |
MMW wrote: |
Very cool. Definitely awesome job and very nice craftsmanship. I would add tool boxes behind the cab/under the bed to fill the space. |
I agree. I had planned to add tool boxes as they are definitely a thing for flat bed trucks.
Yesterday I put this diamond plate door on the right side. It has a lift and turn cam latch. My intent was to provide some weather protection for the air intake, brain box, etc., that are on that side of the motor compartment. I will leave the left side open to allow unrestricted air access. It is after all an air cooled truck. |
dawgofwar71 Samba Member
Posted: Sat Mar 02, 2019 3:09 pm Post subject: Re: Beetle flatbed truck |
i have always like the concept of the truck from a bug. i think i would have at least made it an extended cab though. that way you have more legroom and extra room in period. |
Posted: Sun Mar 03, 2019 7:58 am Post subject: Re: Beetle flatbed truck |
dawgofwar71 wrote: |
Because I made the extended frame, I already have a 4 inch lift. With the BMW seats I used I had to build separate frames to lift the seats so I wouldn't be looking through the steering wheel. Unless you're an NBA player leg room is not a problem. Plus there is plenty of room behind and under the seats. If you need more room than a 4 x 8 flatbed, I think you are going to need a bigger boat!
whozawhat Samba Member
Joined: September 19, 2015 Posts: 39 Location: Ontario, Canada
Posted: Sun Mar 03, 2019 9:58 am Post subject: Re: Beetle flatbed truck |
Great looking build.
Do you have pictures showing the truck from the front and what you did with the headlights? |
Posted: Fri Mar 15, 2019 6:28 am Post subject: Re: Beetle flatbed truck |
whozawhat wrote: |
Oh yeah, we got pix. Documentation so I can remember what I did. As mentioned I wanted the look of 30s or 40s trucks. Along with the squared off cab and spoked steel wheels I figured the headlights needed to be mounted in separate buckets or in nacelles on the fenders. I grafted a pair of nacelles from a 1946 Chevy pick up onto the fenders and covered up the VW buckets. The turn signals are from VW either late 50s or early 60s with yellow LED flashy things, so they can be seen. Yellow fog lights seemed old fashioned, too. The flat faced Hella headlights seem proportioned right for the smaller front end, but I,m wondering, if I can make them LED instead of halogen.
Posted: Fri Mar 15, 2019 7:01 am Post subject: Re: Beetle flatbed truck |
Posted: Sat Mar 16, 2019 12:11 pm Post subject: Re: Beetle flatbed truck |
You are getting that 2CV kind of vibe with those. And I love those cars. Very unique. Not sure I would do it myself, but its a cool look. Very very nice work. The more I look at it, the more I am digging it. Almost seems like the cab needs a folding ragtop. That would REALLY mess with peoples heads....  _________________ D-Dubya Manx clone 1914. Ex wifes car.
