NWA78Bay Samba Member
Posted: Sat Mar 16, 2019 7:00 pm Post subject: Start Type 4 Fuel Injection Engine outside of bus |
Does anyone have any like that have already started in this topic? I’ve searched and have not had any luck finding anything. I’m rebuildong my first engine. It is a 1978 Type 4 FI engine. Does anyone have pictures of their setups to start it outside of the bus? I’ve seen a lot for carburetors, but is it possible to do with the FI? |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17745 Location: San Diego, California
Posted: Sat Mar 16, 2019 9:00 pm Post subject: Re: Start Type 4 Fuel Injection Engine outside of bus |
Yes, I’ve done it with help from an electrical genius. I have lots of pictures to share. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
tommu  Samba Member
Posted: Sat Mar 16, 2019 9:09 pm Post subject: Re: Start Type 4 Fuel Injection Engine outside of bus |
Here's mine:
Control box and adapter from here:
http://www.zalexindustries.com
You could use a bell housing instead of the adapter ring. _________________
Posted: Sat Mar 16, 2019 9:48 pm Post subject: Re: Start Type 4 Fuel Injection Engine outside of bus |
I like your set up _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3630 Location: San Diego (Encinitas)
Posted: Sat Mar 16, 2019 10:46 pm Post subject: Re: Start Type 4 Fuel Injection Engine outside of bus |
Yes. You need to make up a cable to connect to the chassis side of the double relay to provide power, fuel pump, starter, etc. connections. While you can do this with individual wires, I prefer to use the proper connector block and terminals (salvage block from a parted out bus or FI harness, or buy new). With the block, you only have to figure out the connections once. Avoids embarrassing mistakes... _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 6041 Location: Brooklyn
Posted: Sun Mar 17, 2019 5:35 am Post subject: Re: Start Type 4 Fuel Injection Engine outside of bus |
| tommu wrote: |
Here's mine:
Love a sweet sounding Type 4 with FI and no exhaust leaks  _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Sun Mar 17, 2019 6:26 am Post subject: Re: Start Type 4 Fuel Injection Engine outside of bus |
That is impressive! What is the white wire running from the start around the engine? Also where did you mount your fuel pump? |
Posted: Sun Mar 17, 2019 6:41 am Post subject: Re: Start Type 4 Fuel Injection Engine outside of bus |
| The double relay can be replaced with two generic relays or even just switches. Basically you need 12v to the coil, the ECU and the ballast resister pack, and to the fuel pump, plus you need a start circuit. No need for a charging circuit if you have an other way to charge the battery, or just don't intend to run it down. |
tommu  Samba Member
Posted: Mon Mar 18, 2019 1:00 pm Post subject: Re: Start Type 4 Fuel Injection Engine outside of bus |
| telford dorr wrote: |
| Yes. You need to make up a cable to connect to the chassis side of the double relay to provide power, fuel pump, starter, etc. connections. While you can do this with individual wires, I prefer to use the proper connector block and terminals (salvage block from a parted out bus or FI harness, or buy new). With the block, you only have to figure out the connections once. Avoids embarrassing mistakes... |
Yes, this absolutely the best approach. I didn't leave myself enough time to find that connector.
| NWA78Bay wrote: |
Thanks. That's 86A on the double relay to the starter IIRC. This is an excellent resource to illustrate: https://www.itinerant-air-cooled.com/viewtopic.php?f=50&t=5459 I cable tied the fuel pump to the leg of the engine stand. Top tip is not to drop your spare pump on the floor. It will leak massively if it lands on the crimped connections!
I wish I'd built a test stand sooner. I needed to split the case a couple of times after my first build and dropping it from the Bus each time was becoming a chore. _________________
