nonfatmatt Samba Member
Joined: September 24, 2014 Posts: 7 Location: Hewitt / Waco TX.
Posted: Sun Mar 17, 2019 8:19 am Post subject: Fuel hose / grommet questions for 1977. |
I have a 1977 Kombi that I'm working on changing out a fuel pump / fuel filter.
I was able to get some 5/16 hose to go from the tank to the fuel filter that fits fine, but I'm having trouble finding the 11mm hose that goes from the filter to the intake of the fuel pump.
I've found this locally:
https://www.oreillyauto.com/detail/b/safety-stripe...05/4348871
However, I'm concerned that it's only rated for 35PSI. Is this enough for my bus?
Also, I've been doing some research on fuel line replacement kits from Bus/Vanagon suppliers. Apparently there's a grommet that connects the gas tank through the firewall. Now that the tank is drained, would it be a good time to replace this? Thanks for your help. |
rustbus Samba Member
Posted: Sun Mar 17, 2019 9:00 am Post subject: Re: Fuel hose / grommet questions for 1977. |
thats on the intake side of the pump, so it won't really see any pressure at all. _________________ May of '72 Deluxe. 2.0L L-Jet CS & 091 trans conversion
my Bus thread |
Posted: Sun Mar 17, 2019 10:37 am Post subject: Re: Fuel hose / grommet questions for 1977. |
| I have found that 30r7 or 30r6 hose will only last for a few years in that application because it can not handle the ethanol laced fuel we have to buy these days. Some people say that they don't have a problem with it though, so it may vary by brand. As Rustbus days, there is little pressure at that location, somewhere about 1 psi. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53256 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Mar 17, 2019 2:23 pm Post subject: Re: Fuel hose / grommet questions for 1977. |
Ok, thanks for the info. I've decided to do it anyway because the bus needs to be inspected so it can be registered. Quick question, does anyone have any idea which wire is ground and which is hot?
I've got a black wire and a reddish/orange looking wire that went to the last pump, but everything was so corroded it's impossible to know, and we can't figure it out using a meter. |
Jetfxr69 Samba Member
Joined: December 28, 2018 Posts: 1294 Location: White mtns nh
Posted: Sun Mar 17, 2019 2:44 pm Post subject: Re: Fuel hose / grommet questions for 1977. |
| Before you consider which hose or which wire,....buy a fire extinguisher. |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42995 Location: at the beach in Northern Wokistan
Posted: Sun Mar 17, 2019 6:45 pm Post subject: Re: Fuel hose / grommet questions for 1977. |
Matt where are you in the Sacramento area? _________________
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"
1971 deluxe (sold)
1977 deluxe |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3451 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Mon Mar 18, 2019 3:08 pm Post subject: Re: Fuel hose / grommet questions for 1977. |
| SGKent wrote: |
| Matt where are you in the Sacramento area? |
Unfortunately I've moved to Texas, haven't updated the profile. Will do so now. If it helps, the black wire is thinner than the brownish wire. Wiring diagrams really aren't helping me. Is there a way to test what goes to what so we wire it correctly the first time? |
Posted: Mon Mar 18, 2019 3:17 pm Post subject: Re: Fuel hose / grommet questions for 1977. |
Somebody'd been messing with your wiring, the fuel pump power is red/blue and the ground is brown, no black wires involved in that part of the system.
The fuel pump is G6 (current track 71) below.
_________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Mar 18, 2019 3:39 pm Post subject: Re: Fuel hose / grommet questions for 1977. |
| busdaddy wrote: |
Yeah, see I wondered about that. The wiring diagram is what I looked at first and it didn't look like anything else. I think this bus is on its second engine, so the 2nd time they wired it they probably used some other wire. The wiring diagram is sort of confusing though. Is there a way I can check which one is ground without turning the engine on? |
