The Typewriter Business Pumpkin Bus
Page: Previous  1, 2, 3 ... 20, 21, 22
type2rescuemaine
type2rescuemaine is offline
PostPosted: Mon Apr 01, 2019 6:18 am    Post subject: Re: The Typewriter Business Pumpkin Bus Reply with quote
^X2. Exciting stuff
BusJunky
BusJunky is offline
PostPosted: Wed Apr 10, 2019 2:10 pm    Post subject: Re: The Typewriter Business Pumpkin Bus Reply with quote
A friend in PA just sent me this. A pic he took of my bus long before i got it.
Leroux's Autowerks “like us on fb”
https://m.facebook.com/Lerouxs-Autowerks-942149562555768/?ref=bookmarks
rfreddy
rfreddy is offline
PostPosted: Sun Apr 14, 2019 11:33 am    Post subject: Re: The Typewriter Business Pumpkin Bus Reply with quote
Hey Dave,
Since we have a coupla things similar and you have done such an incredible job - I went back thru your thread again. I can't believe how many things I missed. Also noticed some guy dumped a lot of pics on it. Sorry about that - I wasn't trying to hack your thread. Got a little carried away. I know what it's like to get worn down. I have been at mine for 6 years and sometimes I just have to walk away for a bit. The turning point for me was getting the front cage done and the nose and front floor in. That's when I decided to submit my project thread.
It is amazing what you have done. I was never a big fan of phone dials but those white ones are sweet. The 21 window idea was a good one.
When you fabbed the new frame rails - you scored them and bent them then welded up the score lines. Never seen that done, but it makes sense - gives you a clean tight bend and reinforces it at the same time.
Still like to see your shifter solution
Great job.
advCo
advCo is offline
PostPosted: Mon Jun 24, 2019 12:52 pm    Post subject: Re: The Typewriter Business Pumpkin Bus Reply with quote
Whoa, I haven't checked in on this thread in a while and you've been busy! This thing is just looking absolutely killer. This has got to be my favorite thread to come back to for motivation for my bus. Cool Any updates??
"He pulled the mirrors off his Cadillac ‘cause he doesn’t like it looking like he looks back"
'70 Westfalia Restoration
A bunch of vintage motorcycles
'73 Moto Guzzi Eldorado Restoration
braddick
braddick is offline
PostPosted: Fri Nov 08, 2019 3:20 am    Post subject: Re: The Typewriter Business Pumpkin Bus Reply with quote
Any updates mate
One of my favourite build threads and bus here on thesamba
Almarmada
Almarmada is offline
PostPosted: Tue Mar 17, 2020 8:40 pm    Post subject: Re: The Typewriter Business Pumpkin Bus Reply with quote
Update for this amazing bus and the incredible work done by busjunkie. The typewriter bus has found a new home with me and it's in good hands. Work continues at a much slower and unprofessional and unskilled fashion since I'm learning fabrication and methods. But I've been tackling the brake system and tracked down a great set of Porsche 944 turbo calipers from an 86. Ordered new brake lines, 67 MC, hub spacers for the caliper adapters and getting some custom SS brake lines worked up to make it all work. Here's some photos of my shitty fabwork. First time welding/fabwork. Also...it will be turbo'd...
Almarmada
PostPosted: Tue Mar 17, 2020 8:43 pm    Post subject: Re: The Typewriter Business Pumpkin Bus Reply with quote
Bulli Klinik
Bulli Klinik is offline
PostPosted: Wed Mar 18, 2020 8:34 am    Post subject: Re: The Typewriter Business Pumpkin Bus Reply with quote
That brake bracket looks scary to me. You may want to have someone with a bigger welder tackle those welds. You have no penetration.
Mike K
Bulli Klinik
Colorado Springs
mandraks
mandraks is offline
PostPosted: Wed Mar 18, 2020 11:53 am    Post subject: Re: The Typewriter Business Pumpkin Bus Reply with quote
those looks more like reminders to go back and weld this.....
regards
Uli
Culito
11010101
Culito is offline
PostPosted: Wed Mar 18, 2020 11:57 am    Post subject: Re: The Typewriter Business Pumpkin Bus Reply with quote
It's probably fine if things are bolting through the bracket, and those tacks are just to hold the nuts in place.
© CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote:
cru62
cru62 is offline
PostPosted: Wed Mar 18, 2020 1:02 pm    Post subject: Re: The Typewriter Business Pumpkin Bus Reply with quote
Suspenders AND a belt. Weld that schiesse up!
"My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
Almarmada
PostPosted: Thu Mar 19, 2020 4:44 pm    Post subject: Re: The Typewriter Business Pumpkin Bus Reply with quote
I knew I should have never posted pics of the bracket haha ....I ground off the primer and redid them today. I cranked up the voltage and went all the way around instead of tacking them and it's much better all around. They were just tacks to hold them in place since it was bolted through the bracket with threads in the bracket and in the nuts. I took your advice though and redid them anyway since I'm self isolating in my garage lol.
Almarmada
PostPosted: Thu Mar 19, 2020 4:47 pm    Post subject: Re: The Typewriter Business Pumpkin Bus Reply with quote
zimblewinder
zimblewinder is offline
PostPosted: Thu Mar 19, 2020 10:39 pm    Post subject: Re: The Typewriter Business Pumpkin Bus Reply with quote
I'd also question the tensile strength of those gal bolts...
58Euro 23 343208 The Ultimate Zimblewinder Machine.
59 mango standard
Wanted- splash pan supports, og pressed bumper coach bolts, ivory blaupunkt knobs (early), armrest alloy strips, NOS door mechanism
Almarmada
PostPosted: Fri Mar 20, 2020 5:57 am    Post subject: Re: The Typewriter Business Pumpkin Bus Reply with quote
All hardware is going to be grade 10.9. For now I was just using whatever metric I had for mock up. I'm also going to weld a rib between the caliper mounting spacers on the bracket.
Bulli Klinik
PostPosted: Fri Mar 20, 2020 9:19 am    Post subject: Re: The Typewriter Business Pumpkin Bus Reply with quote
You're welding 1/4" plate at least. You're machine should be MAXXED unless you have a very heavy duty welder. Not having seen your equipment, that's a struggle for a standard 170 amp/220v machine. A 110 machine is not going to cut it.
You can do a root pass then multiple passes if the material is beveled properly. From what I'm seeing you need to do a little bit more studying on welding thick materials. I'm not trying to be an ass, but things like brake brackets are important. It's not like a weld on your rock and roll bed breaking while your getting down.
Mike K
Bulli Klinik
Colorado Springs
Almarmada
PostPosted: Fri Mar 20, 2020 11:41 am    Post subject: Re: The Typewriter Business Pumpkin Bus Reply with quote
You're right...I appreciate the advice. I'm going to reassess my approach and probably have a local welder redo them. Always love constructive criticism especially on brake brackets. I have learned a lot and enjoyed figuring it out though.
Almarmada
PostPosted: Fri Mar 20, 2020 11:51 am    Post subject: Re: The Typewriter Business Pumpkin Bus Reply with quote
Haha and I like to get down.
Mr Margaret Scratcher
Mr Margaret Scratcher is offline
PostPosted: Sat Feb 25, 2023 7:00 am    Post subject: Re: The Typewriter Business Pumpkin Bus Reply with quote
BusJunky wrote:
ryans65 wrote:
did you use the overlap then cut method on your longside to get the gap that tight?
I did, yes. You should get that floor chunk today. I sent you tracking. Hope it works for ya.
Great build, I read it a while back but always good to go through again, especially now I've started digging into my bus.
Excuse the 'thread from the dead' but I just thought I'd get you to clarify on this - is this like what Fitzee call 'Cut n Butt' ie you cut at a 45 degree angle along the edge of your replacement panel?
Page 22 of 22
