epowell Samba Member
Joined: September 23, 2015 Posts: 4733 Location: Czech (mostly) Vancouver (sometimes)
Posted: Wed May 15, 2019 6:17 am Post subject: How much influence does the STICK SHIFT have on shifting? |
Well, obviously you can't even shift without a stick shift... but what I really mean is: "As the stick shift parts get older and looser, how much, and how, does this adversely affect gear shifting?"
I ask because I still suspect that something or other in my linkage is not quite right and adversely affecting shifting - and my stick shift is a bit loose... in that, I can pull up on the knob and it all lifts up 5mm or so.
I am pretty sure my shifting was better before... I totally adjusted the middle and rear part of my linkage, and the parts inside that front "box" are in order, as is my central bushing. But the stick shift itself is a mystery, and kinda loose... probably all original and worn out. Unfortunately I can't get replacement bushing here locally...
Any thoughts? Is this worth digging into and somehow getting my stick shift in top shape - or will the benefits not be anything worth writing home about?
Thanks!
Ed _________________ www.edwardpowell.com |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1282 Location: Right Here
Posted: Wed May 15, 2019 8:10 am Post subject: Re: How much influence does the STICK SHIFT have on shifting? |
A lot.
It's like driving with worn steering components. Your steering wheel will turn, but the wheels will not.
If the shifter is really worn out, it's hard for the linkage at the transmission to align properly. |
tjet Samba Member
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8376 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Wed May 15, 2019 8:24 am Post subject: Re: How much influence does the STICK SHIFT have on shifting? |
It's a known failure point. If you have the symptoms, it's time to do the work...
From another active thread:
Gnarlodious wrote: |
You should examine the plastic ball under the gearshift rod. When it wears out it pops apart from the spring inside. From then on shifting is vague and tricky because the whole shifter is loose. If the rod moves up and down easily that’s your prob. A new owner would be excused in thinking that was normal shift action. You can drive with a broken shifter ball (I did it all winter once), and it is pretty easy when you are used to it, but trying to learn that way would be difficult. A broken shifter ball pretty much looks like this:
You can see the white plastic upper hemisphere stuck up inside the socket, and the spring that keeps it tight like a hinge. A non-broken ball would be held together by hooky tabs, with the spring compressed inside... |
No direct experience, but I can't imagine the diesel shifter is any different. Git 'r done!
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Wed May 15, 2019 8:55 am Post subject: Re: How much influence does the STICK SHIFT have on shifting? |
OK, yes I am concerned about this shifter ball. My shifting, when seen from below (with my vid cam) looks really OK, so I don't quite understand how if the shifting "looks good" it still in not good.
Anyhow, I'll go out right now in the cold and rain and have a good look at this 'half-ball'. PART#39 is the culprit.
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10365 Location: Orbiting San Diego
Posted: Wed May 15, 2019 9:01 am Post subject: Re: How much influence does the STICK SHIFT have on shifting? |
Part number 39 is a typical failure item. That with part 38 and both 36 pieces you cover the usual issues. A full kit with more than you need may be the most economical in spite of not needing a lot of it.
Didn't see that stuff on the T3technique link. Other places have it for sure, such as VanCafe who lists both the early 12mm kit and the more common 14mm kit.
Mark |
Posted: Wed May 15, 2019 9:31 am Post subject: Re: How much influence does the STICK SHIFT have on shifting? |
I just went out to have a quick peak at the BALL.
I still seams definitely intact - but there is a significant amount of play... check this video:
My shifting is not THAT bad, but bad enough to be concerned. Replacing both hydraulic cylinders definitely helped - but didn't 100% return it to the smooth shifting I had before.
Here is a video from below of my shifting:
crazyvwvanman wrote: |
Mark |
OK, I will try to find a "kit"... I guess there is an "early version" (12mm?)? That would be for me As usual. _________________ www.edwardpowell.com |
Jeffrey Lee Samba Member
Joined: February 04, 2014 Posts: 1520 Location: Wisconsin
Posted: Wed May 15, 2019 9:55 am Post subject: Re: How much influence does the STICK SHIFT have on shifting? |
The Vanagon shifter was probably never great to begin with, and is compounded by the Rube Goldberg system necessitated by the sheer length. Old, hard grease, a bit of dirt, 30+ years of wear and neglect, can all add up to a sloppy shifting mechanism.
The more 'soft' parts (plastic, rubber) that you can replace in the shifting system, the more precise less imprecise it will become. _________________ Camp Westfalia
Camping Tips • Newsletter • Cool Campervan Apparel
www.CampWestfalia.com |
Posted: Wed May 15, 2019 9:59 am Post subject: Re: How much influence does the STICK SHIFT have on shifting? |
Jeffrey Lee wrote: |
The more 'soft' parts (plastic, rubber) that you can replace in the shifting system, the more precise less imprecise it will become. |
I get ya!
Time to just replace this old crap. _________________ www.edwardpowell.com |
Posted: Wed May 15, 2019 10:12 am Post subject: Re: How much influence does the STICK SHIFT have on shifting? |
...just that 'half ball' Number 39 (251 711 645) is available at many sites for around 5 - 10 $... but it is necessary to get a whole set I wonder... this is around $50 from Poland.
The full kit is 251798116A
Posted: Wed May 15, 2019 10:39 am Post subject: Re: How much influence does the STICK SHIFT have on shifting? |
Wow, thanks Mark! I don't know how you found those... this one is really cheap. 27eur incl tax and shipping.
With these new part numbers, if my parts guy can find the stuff, I will get this one from ebay and just rebuild the whole thing...... ....looks pretty tricky to do that however!  _________________ www.edwardpowell.com |
Posted: Thu May 16, 2019 9:29 am Post subject: Re: How much influence does the STICK SHIFT have on shifting? |
Good news is that my parts guy can find that JP made one... thanks Mark for that number!
So tomorrow I will install.... I am a bit intimidated so I will begin studying up on how to do this right now > would be very grateful if any knows of any tutorials on this. [sometimes these little fiddly type things with springs etc can be much more difficult than expected] _________________ www.edwardpowell.com |
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3456 Location: OR & CA (Oregon/California)
Posted: Thu May 16, 2019 10:03 am Post subject: Re: How much influence does the STICK SHIFT have on shifting? |
EXCELLENT! Thanks so much! _________________ www.edwardpowell.com |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 18696 Location: Retired South Florida
Posted: Thu May 16, 2019 10:47 am Post subject: Re: How much influence does the STICK SHIFT have on shifting? |
Take one of your spares and shift it through all the gears with your hand to get a feel for how precise the movement is to select each gear from 14 feet away. What complicates your situation is the modified transaxle mount and the one picture above looks like the last section of shift rod has been modified.
I’m able to visually adjust one, but have a lot of experience setting them. You may need to trial and error the adjustment to find that sweet spot.
And yes, wear, slop, misalignment all affect how well it shifts. One thing to remember is sitting in neutral. Pushing the shift lever straight forward must select 3rd. Pulling straight back selects 4th. No side movement to the right is required. All side movement should be towards your leg to get 1st, 2nd, and reverse. That assumes left hand drive. |
Posted: Thu May 16, 2019 10:54 am Post subject: Re: How much influence does the STICK SHIFT have on shifting? |
MarkWard wrote: |
From my video above showing the shifting when engine was not running - to me seems like very good shifting..... so what I suspect is that when the engine is actually running, and all other push and pull factors come into play, then under those circumstances the slop, play, and misalignment of the system must show up in bad shifting.... perhaps it is not enough just to get good shifting when the van is on the ground and not running. _________________ www.edwardpowell.com |
Posted: Thu May 16, 2019 11:44 am Post subject: Re: How much influence does the STICK SHIFT have on shifting? |
If you have a helper, set the brake and while you stand behind the van looking down on the engine running. Have your helper select first gear and let the clutch out enough to load the engine. You will see the crankpulley end of the engine moves down quite a bit under load. That changes the shift shaft linkage angles considerably. |
Posted: Thu May 16, 2019 12:03 pm Post subject: Re: How much influence does the STICK SHIFT have on shifting? |
MarkWard wrote: |
aha... there you go.
I was thinking more about how the inner workings, when under load, would affect shifting also >>> like, it's one thing to shift thru the gears when the engine is not running, but with the engine under load there must be varying types of resistance on the shifter which might not like the balls being moved at a certain angle?
Anyhow, tomorrow I will change the stick shift, and if that doesn't help it I'll have another look at the entire linkage. _________________ www.edwardpowell.com |
michaelbteam  Samba Member
Posted: Thu May 16, 2019 2:44 pm Post subject: Re: How much influence does the STICK SHIFT have on shifting? |
A couple of years ago, my shifting seemed to become a little looser and I ignored it, UNTIL: a few days later the shifter broke clean off close to the boot. Luckily I was in a parking lot about a mile from home, and was able to limp home in second gear. Even more fortunately I happened to have a spare shifter at home.
Which reminds me, I need to find another spare! |
