JohnB53 Samba Member
Joined: March 22, 2009 Posts: 56 Location: North Dakota
Posted: Sat Jun 01, 2019 10:21 am Post subject: What to set timing to?? |
| Hi All This winter I rebuilt a VW motor for my home made trike. It was based on a 1500 single port motor I was given. I ended up with a 1641 single port with stock dissy 5-67 bug, stock 30 Pict-2 carb, stock vw cam from Appletree parts. I have an alt so I needed the carb spacer for clearance. I am wondering what should I time this bad boy at? 7.5 BTDC or 0 TDC also with these distribs do you unhook the vacuum line while timing . I hope these questions are not too dumb as I am new to this vw way of life. Thanks John |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80674 Location: Sneaking up behind you
Posted: Sat Jun 01, 2019 10:45 am Post subject: Re: What to set timing to?? |
please post the actual model number of the "dissy". _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
ekacpuc Samba Member
Joined: December 08, 2010 Posts: 1414 Location: ketchikan alaska
Posted: Sat Jun 01, 2019 11:03 am Post subject: Re: What to set timing to?? |
| Glenn wrote: |
| please post the actual model number of the "dissy". |
Post the numbers on the side. Incase you didn’t know where to look to figure out the model. |
Posted: Sat Jun 01, 2019 11:04 am Post subject: Re: What to set timing to?? |
Sorry this is what is on the dissy
JUV-4
0-231-137-009
113-905-205-K |
Glenn  Mr. 010
Posted: Sat Jun 01, 2019 11:58 am Post subject: Re: What to set timing to?? |
| JohnB53 wrote: |
JUV-4
0-231-137-009
113-905-205-K |
Timing Set At:: 7.5deg BTDC Static or @ 800-950rpm w/strobe w/vacuum hose disconnected and plugged _________________ Glenn
Member #1009
#BlueSquare
Posted: Sat Jun 01, 2019 12:09 pm Post subject: Re: What to set timing to?? |
| THANK YOU |
