DirkBlaze Samba Member
Joined: May 12, 2017 Posts: 8 Location: West Chester, PA
Posted: Tue Jun 18, 2019 6:51 am Post subject: Front Beam Swap on '64 Split ? |
I'm thinking about swapping the front beam on my ''64 split as the current has been modified and damaged and stock steering pivot pin and steering are very, very sloppy
I actually have a good replacement beam in hand (with a good pin) sans t.bars etc.
So how hard would it be to remove the trailing arms on one side, slide the whole assembly out of the other side, drop out and replace the axle and reassemble, sliding in both t.bars at once, arms still attached on one side? Would that work or more disassembly first??
I realize I'd have to take off drums, brakes and steering, as well as shift coupling at least first.
Have reassembled ball joint bug axle before but not king pin. |
flemcadiddlehopper Samba Member
Joined: December 05, 2011 Posts: 2345 Location: Kelowna, BC. Canada.
Posted: Tue Jun 18, 2019 6:24 pm Post subject: Re: Front Beam Swap on '64 Split ? |
Would it not be easier to fix the centre pin?
Gordo. _________________ Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others. |
campingbox  Samba Member
Joined: November 14, 2000 Posts: 10249 Location: Petaluma, CA
Posted: Tue Jun 18, 2019 7:10 pm Post subject: Re: Front Beam Swap on '64 Split ? |
The springs are under pressure, with some serious struggling, cursing, hammering, breaking parts you might get one side apart as a complete unit but you will never get it back together like that. |
