das20v Samba Member
Joined: July 04, 2006 Posts: 151 Location: Garden Grove, Cali USA
Posted: Wed Jun 25, 2014 2:44 am Post subject: |
Hi Henry, thanks. I have some catch-up to do on the heads, and I also have to make the ignition tube mounts (I have the dimensions), as well as the crank pulley, which I also have the dimensions from Capriacci. If I get stuck, I will issue my standard request for dimensions. I am almost to the point where I can make my own dimensions based on associated features and alignment to other parts established in the CAD model.
Stay tuned!  |
RHD Notch Samba Member
Joined: April 06, 2007 Posts: 1415 Location: Joshua Tree, CA
Posted: Sun Oct 12, 2014 7:09 am Post subject: |
Anything new das20v? Everything is looking great so far! Thanks... _________________
| Lind wrote: |
| I am at the point where I hardly want to own anything that isn't original paint. |
| campingbox wrote: |
| I have some other projects I'd like to finish first and I want to drive this bus while I'm working on those to help stay motivated. |
das20v Samba Member
Posted: Sun Oct 12, 2014 11:03 pm Post subject: |
Hi Notch,
I do not have anything new at the moment. My free time resources have been swamped by work and family. I have a lot of measurements to model for most of the engine to get wrapped up. I hope to have an update for everyone soon. Thanks for asking and staying with this project. Much appreciated! |
pig-pen Samba Member
Joined: December 04, 2012 Posts: 587 Location: United Kingdom
Posted: Sun Nov 02, 2014 4:47 am Post subject: |
Hello all...
As this is the thread with THE most measurements I have ever seen... I figured this would be the right place to ask.
I am trying to get a definitive measurement for the offset of 36hp heads on a case. When I measure my case I come up with 45mm offset from left to right...
But my manifold (and those measured on this thread) the flange centres are 33mm offset...
I dont have a crank to measure... without ripping a motor apart...
Is the manifold less because it does not sit straight on the motor? this can't be right surely? or the inlet on a head is not central to the head itself... ie 6mm off making up the missing 12mm?
am I making any sense?
EDIT : 38mm it would seem. If I am wrong then please do chip in |
plasticman1432 Samba Member
Joined: January 19, 2004 Posts: 1180 Location: Nosebleed seats, NY
Posted: Wed Dec 03, 2014 6:12 pm Post subject: |
If you're doing it in 1/16th scale, could a Revell AG '51 Beetle kit provide a donor engine? _________________ Organized people are just too lazy to look for stuff
'68 Meyers Manx: M1689D815E
http://public.fotki.com/VWDave/ |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7124 Location: Lawrenceville, Ga
Posted: Thu Dec 04, 2014 5:31 am Post subject: |
| plasticman1432 wrote: |
| If you're doing it in 1/16th scale, could a Revell AG '51 Beetle kit provide a donor engine? |
a beetle engine would have the wrong distributor, though _________________ regards
Uli
cookiemonster131 Samba Member
Joined: February 13, 2008 Posts: 3 Location: salisbury, nc
Posted: Thu Dec 04, 2014 8:42 am Post subject: |
| DIGGITY DAMN |
das20v Samba Member
Posted: Thu Dec 04, 2014 3:19 pm Post subject: |
Plasticman1432,
The Revell engine would work, but it has the wrong Carburetor and a few other details. Aside from correctness, Revell's molding is a little soft on detail. My choice if I had to rob existing kit parts, would be the Tamiya 1/16 scale Kubelwagen engine. Molding of detail is crisp (the cylinders aren't siamesed together), and it does have many more correct parts, but you would need some things from the Revell kit to do it properly, such as the air cleaner, etc.
The goal here is to have an all-in one extremely detailed and accurate representation. I also want to use this design so it can be used in larger scales as well. |
das20v Samba Member
Posted: Wed Dec 31, 2014 7:04 pm Post subject: |
Happy New Years everyone. A few minutes ago, I discovered that Revell is making a T1 Samba in 1/16 scale, to be released in September 2015. I don't know if it's a Barndoor, but it probably is. They released a new 1/24 Barndoor model recently.
Disapointing, because that was the goal of this project exactly, in 1/16th scale, before they even released a 1/24th version. If I had more time to work on this project, I could have completed this much sooner. I will carry on with finishing the engine at least, and go into making some of these available. I am sure the engine will be way more accurate than Revell's version, unless their designer has been following this forum!
On the bright side, I will be buying one in September for sure. I hope to have the engines available by then.
For my diehard friends that have helped me along (Capriacci, D-Train, Henry, etc.), I will have something for you too. Please be patient. |
D-train Samba Member
Posted: Fri Jan 02, 2015 1:11 pm Post subject: |
hope u had a great new year and xmas too mate.
good to hear that there is a kit finally, but I dare say it wont be up to your standards, so ill be hanging out anyway..
im sure they will miss out on a lot of detail that you have been covering so far even in the engine..
either way I cant wait to see the 1st prototype! _________________ shiny paint doesnt make it worth any more |
das20v Samba Member
Posted: Fri Jan 02, 2015 1:27 pm Post subject: |
Hey Dion,
I hope you had a good Christmas and New Years as well. I will not let all of this engine work go to waste. The good news is that it can be used as a basis to replace any of Revell's kit engines, being Ghia, Kafer, or Bus, or Tamiya's Kubel, or Eduards Schwimmer (with some tweaks of course) but I have an even more grand plan for this that is not Revell related. Be patient, it will be awesome. |
Posted: Fri Jan 02, 2015 1:43 pm Post subject: |
Grand plan??
Has Volkswagen Germany contacted u???? _________________ shiny paint doesnt make it worth any more |
Posted: Fri Jan 29, 2016 11:30 pm Post subject: Re: '52 Panel scale model |
Any progress??
Hehe.. _________________ shiny paint doesnt make it worth any more |
Posted: Sun Jan 06, 2019 12:01 pm Post subject: Re: '52 Panel scale model |
3 years have gone quick.
Is this still going to be going ahead?
Or has work life overtaken pleasure life? Haha _________________ shiny paint doesnt make it worth any more |
das20v Samba Member
Posted: Wed Jan 09, 2019 12:05 pm Post subject: Re: '52 Panel scale model |
Hey D-train!
This project has been stagnant for all this time. However, new life will come soon. One of the holdups was unavailable technology at the time, due to funds needed to acquire such technology.
Fast forward 3 years, to just a month ago.
I now have a high resolution 3D printer, and have been experimenting with some detailed prints, to the point where I am confident that this will work perfectly on this project.
Stay tuned! More coming soon. |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9831 Location: Exit 7, New Jersey
Posted: Mon Jun 24, 2019 9:54 am Post subject: Re: '52 Panel scale model |
Another 5 or 6 months.
Any updates?
I really like the work you were doing here. _________________ Founder and Chairman Emeritus, ECMSAS
| BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
| Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all!  |
Posted: Wed Apr 13, 2022 1:22 pm Post subject: Re: '52 Panel scale model |
Any updates now? _________________ shiny paint doesnt make it worth any more |
henry roberts Samba Member
Joined: February 24, 2003 Posts: 1290 Location: australia
Posted: Sat Apr 16, 2022 3:51 am Post subject: Re: '52 Panel scale model |
| i was thinking about this last week too. |
Fish Samba Member
Joined: December 05, 2000 Posts: 6005 Location: OB. It's beside the point.
Ted2 Samba Member
Posted: Sat May 14, 2022 3:52 am Post subject: Re: '52 Panel scale model |
| I'm curious abut updates also. This is an exciting model project. |
