harrymarlin Samba Member
Joined: June 07, 2018 Posts: 783 Location: Washington, DC
Posted: Tue Jun 25, 2019 10:14 am Post subject: Replacement emergency flasher relay? |
I am working on restoring my 1967 Beetle, and found the following under the wire cover (red sticker over right one was removed to read words):
What I was expecting to see was:
Looking at the classifieds, it looks like the first picture might be an emergency flasher relay for a 1967 Bus? Or is it just a later replacement? Is the second one the correct, original - or is the first one correct, original for my 1967 Beetle?
Any thoughts would be appreciated!
Thanks!
-Harry |
Joined: May 17, 2003 Posts: 4874 Location: Harmony, PA
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35871 Location: Conejo Valley, CA
Posted: Tue Jun 25, 2019 1:32 pm Post subject: Re: Replacement emergency flasher relay? |
For a while the stock relay boxes were unavailable, and old ones were questionable. As posted, they are available again, just a tad expensive.
That first photo doesn't look like a VW part, but it may be a (well-made) homebrew to use a pair of standard relays and diodes to make a functional replacement.
IIRC, the stock box grounds through the mounting (that hole in the middle of it!), so make sure it's mounted right and properly grounded.
A more involved alternative (not really recommended now that stock boxes can be found) is to use the later system, which used a more complicated switch, but a simple relay. It was more reliable and much easier to replace a cheap common relay when it does fail.
https://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D211%2D953%2D235%2DA
You have to rewire things... so I'd just get a new box and be done with it.
TonyB Samba Member
Joined: December 11, 2018 Posts: 173 Location: Kansas
Posted: Tue Jun 25, 2019 2:28 pm Post subject: Re: Replacement emergency flasher relay? |
Are the diodes to keep the dash light from back feeding over to the other side? |
KTPhil  Samba Member
KTPhil  Samba Member
Posted: Tue Jun 25, 2019 3:36 pm Post subject: Re: Replacement emergency flasher relay? |
Sure does look like it! But now the real thing is cheaper. But if that thing works and you can get instructions from the seller, you may be golden.
It has a VW part number on the box, but since VW didn't do 12V conversions themselves, this is certainly aftermarket, albeit a good one. I'd like to see a little more environmental protection, but a small plastic hobby box would do. |
Jos.Hall Samba Member
Joined: January 29, 2011 Posts: 348 Location: Sunny So Cal.
Posted: Mon Jul 29, 2019 10:55 pm Post subject: Re: Replacement emergency flasher relay? |
Harry, I'm not sure if you settled on the flasher relay yet but your vert DEFINITELY did not come with the two relay system that you have in it now. ALL US beetles came with the 9 pin Hella flasher relay. Now... The question is do you want a black one, blue one or silver? All would be correct but I tend to think the black one would be the most common in early 67 production. |
