Exhaust advice
KingCarGuyZ
KingCarGuyZ is offline
PostPosted: Wed Jun 26, 2019 3:08 pm    Post subject: Exhaust advice Reply with quote
I’m running a stock engine (no clue what year) with dual bazooka Glasspack exhaust on my 66 fiberglass body buggy, while there great on the road. They get a little annoying in the parades. Any advice on what I could get to quite her down to a reasonable volume for under 200 bucks. Doesn’t have to be all pretty our anything, just good at its job. Thanks!
Danwvw
Danwvw is offline
PostPosted: Wed Jun 26, 2019 3:29 pm    Post subject: Re: Exhaust advice Reply with quote
If you want it quite, put back to stock. Just check your engine S/N against the Vin/Chassis numbers engine numbers link under Technical here on the Samba. Probably a H case so it would be a single port 1500 case. The 1300, 1500, 1600's used the same muffler. Without Heat Riser, With Heat Riser. CarCraft, ACN, AutoHausAZ,
RockAuto.
1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
[email protected]
john@aircooled.net is offline
PostPosted: Wed Jun 26, 2019 3:41 pm    Post subject: Re: Exhaust advice Reply with quote
not enough information. How quiet do you want it?
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
KingCarGuyZ
PostPosted: Wed Jun 26, 2019 4:13 pm    Post subject: Re: Exhaust advice Reply with quote
I’ll check the code this weekend probably, I was thinking quite enough that you could talk could talk over it at idle without shouting, but not much quieter then that. Still talk loudly at each other in first doing about 7 mph. Right now if I stand behind the car and talk I have to yell to be heard with it just sitting there warming up.
oprn
oprn is offline
PostPosted: Wed Jun 26, 2019 4:31 pm    Post subject: Re: Exhaust advice Reply with quote
For our sand rail I just went to a muffler shop and bought a pair of glass pack mufflers that were the right size to slip into the outlet of the Bazooka mufflers. I just pop them in and snap a bungie cord on them to hold them in place. Really quiets them down almost to the stock muffler level.
I can take them off and on in 30 seconds depending on where we are and who is going to have to put up with us. You could screw on or tack weld them in place too for a more permanent installation.
Danwvw
Danwvw is offline
PostPosted: Wed Jun 26, 2019 4:34 pm    Post subject: Re: Exhaust advice Reply with quote
Maybe this one muffler and 1 3/8" Header.
EVfun Premium Member
EVfun is offline
PostPosted: Wed Jun 26, 2019 4:36 pm    Post subject: Re: Exhaust advice Reply with quote
I'm going to run a 1973 VW Thing dual exhaust. I figure since it's a reproduction stock system it should be pretty quiet. I had mine ceramic coated but it is still in a box in the spare bedroom waiting to be installed.
Wildthings wrote:
KingCarGuyZ
PostPosted: Wed Jun 26, 2019 5:46 pm    Post subject: Re: Exhaust advice Reply with quote
I like the idea of being able to switch quickly. What I’m running right now has a roughly 1-1.5 inch inner diameter at its smallest point, do you think they make a Glasspack that would slide into something that small? I tried the inserts from j-bugs and they where to big.
KingCarGuyZ
PostPosted: Wed Jun 26, 2019 5:54 pm    Post subject: Re: Exhaust advice Reply with quote
Here are some old picks of what’s on the car now, they weren’t taken with this purpose in mind, so sorry about the crummy angles.
EVfun is offline
PostPosted: Wed Jun 26, 2019 6:34 pm    Post subject: Re: Exhaust advice Reply with quote
VERY cool old buggy! I love that shaded purple finish -- but I'm partial to purple. Cool
I would look at the intake manifold. If the ends go strait down into the head you have a 40 horse engine. If they go in at an angle it is a 1300/1500/1600 engine. The ends of the 40 horse intake are part of the manifold, braised to it. The end parts of the later intake manifolds pushed down on the ends, but is a stamped part that is separate from the intake and loose when the manifold is removed (but captive, it cannot be removed from the manifold without cutting it apart.) Good advice is easier to give it when the engine is known. Question
Wildthings wrote:
oprn
oprn is offline
PostPosted: Wed Jun 26, 2019 9:04 pm    Post subject: Re: Exhaust advice Reply with quote
Now that I look at these mufflers I think they are actually resonators because you cannot see straight through them like a glass pack.
The problem I see is they might stick out too far. My engine cage goes back further than yours but there may be shorter ones available.
The bungie cord is a bit crude, split washers welded to both and springs would be neater and still be quick to remove.
Hope this helps.
KingCarGuyZ
PostPosted: Thu Jun 27, 2019 11:05 am    Post subject: Re: Exhaust advice Reply with quote
Thanks for the resonator idea, looks like a really good cheap but effective idea. I took some pictures of the intake, it’s a single port and I’m guessing it’s not a 40 based off of what EVfun said. I also took a pick down the Glasspack just to give and idea of what I have now. I’ll try and get the pilot cover off today if I have time, so I can get the block code. But it’s looking less and less likely.
KingCarGuyZ
PostPosted: Thu Jun 27, 2019 12:47 pm    Post subject: Re: Exhaust advice Reply with quote
Just grabbed the block code form underneath the alternator stand. I believe it to be 5737782 but I’ll let you decide if the first one is a 6 or a 5 on your own. That would make it a 1961 1300 engine correct? Is there en even such thing. These model years and engine sizes never did make since to me anyhow.
[email protected]
PostPosted: Thu Jun 27, 2019 12:54 pm    Post subject: Re: Exhaust advice Reply with quote
Something like
http://vwparts.aircooled.net/Tri-Mil-Bobtail-Header-and-Quiet-Pack-Muffler-p/bobtail-quietpack.htm
and
http://vwparts.aircooled.net/Tri-Mil-Bobtail-Muffl...uffler.htm
http://vwparts.aircooled.net/Tri-Mil-Bobtail-Stinger-Stinger-ONLY-3010S-p/bobtail-stinger-only.htm
Danwvw
Danwvw is offline
PostPosted: Thu Jun 27, 2019 1:05 pm    Post subject: Re: Exhaust advice Reply with quote
That's a 40 horse engine probably a 64, it would be these: http://vwparts.aircooled.net/category-s/736.htm?se...amp;page=2
Also See inlet manifolds
oprn
oprn is offline
PostPosted: Thu Jun 27, 2019 5:25 pm    Post subject: Re: Exhaust advice Reply with quote
The 1300 was a one year only engine in this country. 1966. A very desirable engine in my view, if left stock it was pretty torquey and had the longest service life of any factory Beetle engine.
KingCarGuyZ
PostPosted: Thu Jun 27, 2019 6:00 pm    Post subject: Re: Exhaust advice Reply with quote
That’s kind of ironic cause my buggy is registered as a 1966 beetle, though I’m fairly sure the car has gone through at least 2 engine swaps, for various “improvements” I don’t think it ever blew one up
oprn
oprn is offline
PostPosted: Thu Jun 27, 2019 6:14 pm    Post subject: Re: Exhaust advice Reply with quote
Hard to say what is in there then but if it runs good - drive it!
Teeroy Premium Member
Teeroy is offline
PostPosted: Thu Jun 27, 2019 6:30 pm    Post subject: Re: Exhaust advice Reply with quote
Those are 40hp heads, so you need an exhaust that is made for a 40hp 1200cc, because of the width.
Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org
