Double Cab rear seats / floor mats
jayar59
jayar59 is offline
PostPosted: Wed Feb 14, 2018 1:27 pm    Post subject: Reply with quote
Is this a Bay Window rear floor mat or 1961-up Split Bus with the long fingers?
It fits in my '61 Double Cab (which uses an earlier "short finger" mat) but has no visible part # on top like the other mats in the first post of this thread. There is a logo on the underside and the waffle pattern is different than my early mat.
Bay Window?
(Long fingers on sides, some flat portions on underside)
My 68 DC has that exact same mat. Notched in all four corners. Front notches are on the side instead of the front. The mat in my 60 DC has no notches. I hope this helps.
PostPosted: Wed Feb 14, 2018 9:55 pm    Post subject: Re: Double Cab rear seats / floor mats Reply with quote
Thanks. To confirm, does your '68 mat have the same exact logos on the back too?
Alexb1969
Alexb1969 is offline
PostPosted: Fri Jul 06, 2018 3:10 pm    Post subject: Re: Double Cab rear seats / floor mats Reply with quote
Could someone post the dimensions for the front centre panel of the pedestal for a 66 DC - I have the ends but no centre panel so want to get one folded up as it’s just a flat panel looking at the pics - just want to make it the correct dimensions Smile
hitest
hitest is offline
PostPosted: Sun Jul 08, 2018 11:11 am    Post subject: Re: Double Cab rear seats / floor mats Reply with quote
The center panel is not flat. It is pressed all along the upper edge to provide a wider "lip" for the seat frame to rest upon. Take a close look at page 1 of this thread. You could also find the dimensions backwards. Position your two ends and mount them to the bus cab the way they belong- exactly perpendicular to the cab's back panel. With the right alignment you could easily determine the width of what you need. The breaks in the metal mirror what your end panels already have.
FU#5
67ghiaTIV
67ghiaTIV is offline
PostPosted: Mon Jun 24, 2019 12:39 pm    Post subject: Re: Double Cab rear seats / floor mats Reply with quote
Where are you guys getting your rear DC floor mats.
Wolfsburg West has them. Anyone else.
Shipping and the CAD $ is killing it. Not to mention duty.
j.pickens
j.pickens is offline
PostPosted: Mon Jun 24, 2019 9:36 pm    Post subject: Re: Double Cab rear seats / floor mats Reply with quote
This is $26 at Home Depot, Black rubber scraper mat.
Probably available in Canadian home stores.
Looks like it could be cut to fit, and would do the job.
https://www.homedepot.com/p/ClimaTex-Indoor-Outdoo.../304629298
BeaterBarndoor wrote:
Red Fau Veh wrote:
peecee69
peecee69 is offline
PostPosted: Wed Jul 03, 2019 8:08 am    Post subject: Reply with quote
I know these bolts are M8x25. It also looks like it has a round head. I've looked for carriage bolts like these, but the "shoulder" of every one I've tried has been too big to fit into the slot of the retainer. Are these the same bolts as the passenger bus seat clamps?
1973 Standard Beetle - running maintenance thread - https://www.thesamba.com/vw/forum/viewtopic.php?t=675712&highlight=
1966 Doublecab - Starting resto - https://www.thesamba.com/vw/forum/viewtopic.php?t=668518&highlight=
View user's profile Send private message Send e-mail AIM Address Yahoo Messenger Facebook Gallery Classifieds Feedback
PostPosted: Wed Jul 03, 2019 8:50 am    Post subject: Reply with quote
Weird, I had ones from the local Ace hardware on my Truck until I found an original set. They worked great, only the head was larger than normal.
They are not the same as the rear seat bolts - those have a T-head:
zozo
zozo is offline
PostPosted: Wed Jul 03, 2019 8:58 am    Post subject: Re: Double Cab rear seats / floor mats Reply with quote
Do y'all ever do the home electrolysis to de-rust this kind of stuff?
Just curious, since there're several ways to skin the cat.
j.pickens
PostPosted: Wed Jul 03, 2019 11:55 pm    Post subject: Re: Double Cab rear seats / floor mats Reply with quote
There's a lot of threads on here about this. Coca cola, vinegar, molasses, and commercial rust soak products all do about the same.
Red Fau Veh wrote:
zozo
zozo is offline
PostPosted: Thu Jul 04, 2019 5:34 am    Post subject: Re: Double Cab rear seats / floor mats Reply with quote
Yes, there are many ways to skin the cat.
As I’d said, I’m just curious.
62DoKaGuy
62DoKaGuy is offline
PostPosted: Thu Feb 13, 2020 7:23 am    Post subject: Re: Double Cab rear seats / floor mats Reply with quote
Braukuche wrote:
Rear floor mats:
Part # 265 863 731
Early style - short ends - 59-61
Late style - longer ends, 61-67
Does anyone have anything more specific on the date range of the short-to-long end transition for the DC rear floor mat?
Oh about 2003, I bought a rear pedestal, seats, and possibly even the floor mat off TheSamba for my '62 DC...been so long I don't remember from whom or what all came with it (Can you even look that ad up anymore, Everett?). I just needed them and didn't sweat the details. The pedestal is an earlier version, with the "innie" mounting tabs, which I made simple plates to adapt to "outie." The floor mat is earlier version too, with the short ends - no markings that I recall, will have to check that out.
What I'm getting at is, where does it say that '61 is the cutoff for short ends? I assume from my research that it is incorrect for my '62, but why!?!? Any PR, Parts Catalog, or other reference to the switch to long ends?
,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there...
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold)
PostPosted: Thu Feb 13, 2020 1:16 pm    Post subject: Re: Double Cab rear seats / floor mats Reply with quote
Yes, I could try to look up the ad but I would need more information - location, etc. Seller's email address would be optimal. PM me if you have any details.
On the transition period, I haven't seen anything formal.
I think the "up thru 1961" reference was gotten from examining Trucks known to be original.
It may even have changed during 1961.
If anyone knows more, I would update the first post in this thread.
cru62
cru62 is offline
PostPosted: Thu Feb 13, 2020 5:53 pm    Post subject: Re: Double Cab rear seats / floor mats Reply with quote
My 10-61 had the original mat and stand which was the long one.
"My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
PostPosted: Thu Feb 13, 2020 10:07 pm    Post subject: Re: Double Cab rear seats / floor mats Reply with quote
I should say that I have seen several known original early/mid 1960 DCs with the short mat so pretty sure on that for 1960 period
bally
bally is offline
PostPosted: Tue Aug 18, 2020 11:49 pm    Post subject: Re: Double Cab rear seats / floor mats Reply with quote
Great thread but seems to be missing some details on 64-67 rear seat base (not the pedestal). Does anyone have a picture of the underside of one please? Is there anything else that does the job or is it just a case of finding an original or fabricating something - if I'm to fabricate something a picture would be great to see how it should be please.
Cheers, Dave
PostPosted: Wed Aug 19, 2020 11:24 am    Post subject: Re: Double Cab rear seats / floor mats Reply with quote
64-67 has a flat base all around.
I dig up these pics in the gallery of an original salt & pepper rear seat
Back rest (same as earlier seats):
Bottom, notice frame is totally flat instead of having the dip in front like earlier rear seats or 58-62 front seat bottoms:
Front of seat here is on the bottom in the pic - Also seen is the truck-only rear seat bar for mounting.
bally
bally is offline
PostPosted: Wed Aug 19, 2020 3:08 pm    Post subject: Re: Double Cab rear seats / floor mats Reply with quote
Thanks Everett, very useful.
I'm curious as to why the back seats had that additional support brace along the back. They mount the same way as a front bench seat which doesn't need (or have) that support.
Cheers. Dave
hitest
hitest is offline
PostPosted: Thu Aug 20, 2020 7:21 pm    Post subject: Re: Double Cab rear seats / floor mats Reply with quote
Cheers. Dave
I wondered the same thing too a while back. I'm thinking since the seat mounts to a permanent part of the vehicle in the front of a bus, but a "floating" portable (backless) base in a DC, that the seat simply requires more stiffness to survive when I pick up my posse' on 23rd and Jackson.
FU#5
bally
bally is offline
PostPosted: Thu Aug 20, 2020 9:09 pm    Post subject: Re: Double Cab rear seats / floor mats Reply with quote
Good theory - thanks.
Dave
Page 3 of 4
