texastomeh Samba Member
Joined: November 20, 2018 Posts: 302 Location: Dallas, TX
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11114 Location: Huntington Beach, CA
Posted: Thu Aug 15, 2019 10:28 pm Post subject: Re: Comments re Distributor?? |
For 40 bucks, I would use it. But it won’t last long. Either plan for a better unit or buy several of them. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
sb001 Samba Member
Joined: May 19, 2011 Posts: 10457 Location: NW Arkansas
Posted: Thu Aug 15, 2019 10:54 pm Post subject: Re: Comments re Distributor?? |
You may have missed the part in the description where it says that price is for a case lot only, you must buy 20 minimum. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79428 Location: Sneaking up behind you
Posted: Fri Aug 16, 2019 3:07 am Post subject: Re: Comments re Distributor?? |
You may not get what you pay for, but you always pay for what you get" _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Fri Aug 16, 2019 7:25 am Post subject: Re: Comments re Distributor?? |
GEEZ!
Sorry guys! I should have been more clear(?). I was really looking for some "technical" comments/advice re my specific application. My BAD!!
No, I did not miss the 20 unit minimum buy.
Our club is considering doing a "Group Buy" of 20 (use some and sell rest at swap meets).
Seems to be the situation in our society today - Long on pseudo-philosophy and short on real advice.
Thanx,
Tom |
Fiddlestyx Samba Member
Posted: Fri Aug 16, 2019 7:39 am Post subject: Re: Comments re Distributor?? |
From the website:
"This distributor WILL NOT work properly with aftermarket carburetion systems unless a correct vacuum port is installed into one of the carburetors. DO NOT TRY THIS YOURSELF, only an expert with proper experience on the brand of carburetor you have will be able to tell you if this can be done, and how to do this."
and
"Will work properly with any 13-1600cc Beetle, Bus or Ghia engine with the stock 34-PICT carburetor."
That's your answer, I guess, I don't know how much your carb sucks. _________________ 1983 Vanagon Westfalia Air-cooled
1973 Super Beetle |
dubsteez79 Samba Member
Joined: November 22, 2017 Posts: 194 Location: star nc
Posted: Fri Aug 16, 2019 7:56 am Post subject: Re: Comments re Distributor?? |
My bosch 043 905 205 SVDA works well with my 1600 DP and 34 EPC's. I have vac signal from both carbs with a .035 orifice right before the vac can to hopefully smooth out the vac signal. Not sure about the CIP distributor in particular but if its a copy, I think it would be fine. _________________ It drinks the coffee.
Then Engineers the things.
Then drinks the beer to forget the things. |
windfish Samba Member
Posted: Fri Aug 16, 2019 7:58 am Post subject: Re: Comments re Distributor?? |
texastomeh wrote: |
Seems to be the situation in our society today - Long on pseudo-philosophy and short on real advice. |
The vast majority of cheapie Chinese clones are poor quality.
There's been many, many posts on this board complaining about them.
imo the distributor makes such a huge difference in how well the engine runs it's not the best place to cheap out, but if you'd like to roll the dice on these please do so and report back. |
Glenn  Mr. 010
Posted: Fri Aug 16, 2019 7:59 am Post subject: Re: Comments re Distributor?? |
texastomeh wrote: |
Thanx,
Tom |
They are junk, you can't get any kind of quality for $40.
They are advertised as "one size fits all", they are not. You need to have a carb with the "correct" vacuum signal. The internals are poorly made, the vacuum canisters have a high failure rate. So while you'll only spend $40, how much will a towing bill and motel room cost when you're stuck on the side of the road. _________________ Glenn
Member #1009
#BlueSquare
atari Samba Member
Posted: Fri Aug 16, 2019 10:17 am Post subject: Re: Comments re Distributor?? |
texastomeh wrote: |
Anyone care to comment/complain/recommend/condemn |
some very well respected samba members wrote: |
They suck |
texastomeh wrote: |
Seems to be the situation in our society today - Long on pseudo-philosophy and short on real advice |
Cheap Chinese distributors suck. Period. You'll be ripping off the people at "shows" that you re-sell them to who might not know better.
If you are serious about getting a replacement distributor for yourself (and not to re-sell to make a couple of bucks), get a real refurb'd dizzy from Glenn or another trusted samba member, or go with a quality electronic points set-up.
There are LOTS of discussions here on this topic, as it is an absolute critical component to our vehicles running properly.
But please, remember to enjoy your pseudo-Bugatti with our pseudo-philosophy!  _________________ 1974 Sunbug (Standard) |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Fri Aug 16, 2019 12:45 pm Post subject: Re: Comments re Distributor?? |
I wonder if the vacuum cans are any good, or can be swapped to a SVDA (OG 034). The NOS ones are getting pricy.. |
Glenn  Mr. 010
Posted: Fri Aug 16, 2019 12:48 pm Post subject: Re: Comments re Distributor?? |
Pruneman99 wrote: |
They have a high failure rate. _________________ Glenn
Member #1009
#BlueSquare
Posted: Fri Aug 16, 2019 12:52 pm Post subject: Re: Comments re Distributor?? |
Glenn wrote: |
Pruneman99 wrote: |
They have a high failure rate. |
Is this something you've experienced working with them, or just conjecture? Definitely not trying to imply anything here, just looking for discussion/info. |
Xevin  Samba Member
Posted: Fri Aug 16, 2019 1:08 pm Post subject: Re: Comments re Distributor?? |
Looks like CIP1 did a little dumpster diving. Now we know what was in the brown boxes
https://www.instagram.com/p/B1H3IYTHjiB/?utm_source=ig_web_copy_link _________________ Keep on Busin'
Clatter wrote: |
Damn that Xevin...  |
skills@eurocarsplus wrote: |
SGKent wrote: |
Posted: Fri Aug 16, 2019 1:15 pm Post subject: Re: Comments re Distributor?? |
Hahahaha  |
Glenn  Mr. 010
Posted: Fri Aug 16, 2019 2:10 pm Post subject: Re: Comments re Distributor?? |
Pruneman99 wrote: |
Glenn wrote: |
Pruneman99 wrote: |
I've personally tested a dozen that were sent to me by the owner to see why the distributor doesn't work correctly. All were under 3 months old.
I've also read many posts here reporting the same thing. _________________ Glenn
Member #1009
#BlueSquare
