Tool dimensions for stroker case machining?
Jetmech2002
Jetmech2002 is offline
PostPosted: Tue Sep 10, 2019 9:07 am    Post subject: Tool dimensions for stroker case machining? Reply with quote
Does anyone have the tooling for relieving the cases for stroker conversion using the line boring kit? Would you be willing to share pictures, and dimensions so they could be reproduced? Thank you in advance! 😊
DeathBySnuSnu
DeathBySnuSnu is offline
PostPosted: Tue Sep 10, 2019 2:46 pm    Post subject: Re: Tool dimensions for stroker case machining? Reply with quote
https://youtu.be/mXVHNS28Mus
modok wrote:
And look at the SHAPE of the curves, just smooth, like gods own slingshot. .
mark tucker
mark tucker is offline
PostPosted: Tue Sep 10, 2019 3:13 pm    Post subject: Re: Tool dimensions for stroker case machining? Reply with quote
nive vid, sort of....the wife heard it and was giving me some looks.....then came over to see what porno I was watching( to chew on my ass for watching porno).....boy was she supprized when it was vw porn!!!
bugguy1967
bugguy1967 is offline
PostPosted: Tue Sep 10, 2019 3:15 pm    Post subject: Re: Tool dimensions for stroker case machining? Reply with quote
Seems like you're asking for something that bolts onto the line bore bar that can stroke relieve with?
Only way I know how to do it (easy) is with a mill. Use a 1"-1 1/2" full radius endmill and carve it out.
"A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine"
[email protected]
roy@mofoco.com is offline
PostPosted: Wed Sep 11, 2019 6:38 am    Post subject: Re: Tool dimensions for stroker case machining? Reply with quote
I have heard of this technique but it's pretty old school technology. Most people do it with a bridgeport, like the video.
Here at Mofoco, we have been using a CNC machine for the last 25 years. We had to build a dedicated fixture, buy special tooling and then we remove all the studs. All that's left after the machine is to debur all the machined edges. I will have to take another video(I just did one yesterday for a motor) The nice thing is that there is no guesswork and it comes out exactly the same every time.
Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet
nsracing
nsracing is offline
PostPosted: Wed Sep 11, 2019 10:22 am    Post subject: Re: Tool dimensions for stroker case machining? Reply with quote
I still do it w/ my own hands. Laughing
Jetmech2002
PostPosted: Thu Sep 12, 2019 5:41 pm    Post subject: Re: Tool dimensions for stroker case machining? Reply with quote
Thank you all for your replies.
SLAKKER
SLAKKER is offline
PostPosted: Fri Sep 13, 2019 12:34 am    Post subject: Re: Tool dimensions for stroker case machining? Reply with quote
mark tucker
PostPosted: Fri Sep 13, 2019 6:44 am    Post subject: Re: Tool dimensions for stroker case machining? Reply with quote
I wonce tore appart a less than 1000 mile motor that had expired...it was stroker clearanced with a chizzell by the looks of it. you knoe the type of guy...I cant say whoo did it, but it was from up in the "great northwest." and he claims he is a machinest.....ya right, keep smoken that stuff... doing it by hand takes a little while, but works fine.if you have a mill and know how to use it and have some to do it should not be hard to do. I have 2 mills, but as of yet all my bubble top cases dont need it. doing it by hand just takes more tyme.
