Timing light with petronix
patricke1971
patricke1971 is offline
PostPosted: Fri Sep 13, 2019 4:36 am    Post subject: Timing light with petronix Reply with quote
Can I use a timing light with a petronix ignition module? Will or can it somehow short the thing out? If it is kosher to use ,any special way to do it?
slalombuggy
slalombuggy is offline
PostPosted: Fri Sep 13, 2019 4:56 am    Post subject: Re: Timing light with petronix Reply with quote
Yes, No, No.
grandpa red
grandpa red is offline
PostPosted: Fri Sep 13, 2019 6:17 am    Post subject: Re: Timing light with petronix Reply with quote
This is what I use on mine.
'72 Beetle
andk5591
andk5591 is offline
PostPosted: Fri Sep 13, 2019 6:28 am    Post subject: Re: Timing light with petronix Reply with quote
Time it as usual...assuming your are using the correct method for your distributor, like if an 009, forget about static timing.
D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
There's more, but not keeping them...
mark tucker
mark tucker is offline
PostPosted: Fri Sep 13, 2019 6:29 am    Post subject: Re: Timing light with petronix Reply with quote
I use my snappon ,works fine. I tried the mac tools but had to return it ,the dealer said it only works on diesels....
patricke1971
PostPosted: Fri Sep 13, 2019 8:06 am    Post subject: Re: Timing light with petronix Reply with quote
That's what I thought.... but I didn't want to fry the damn thing
Lo Cash John
Lo Cash John is offline
PostPosted: Fri Sep 13, 2019 12:52 pm    Post subject: Re: Timing light with petronix Reply with quote
I used to have that exact same Sears/Penske timing light and white case. Old school rules!!!
www.LoCashRacing.org
Lo' Cash Racing Team on Facebook
More brains than bucks...Believe it or not!!
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone.
grandpa red
PostPosted: Fri Sep 13, 2019 1:30 pm    Post subject: Re: Timing light with petronix Reply with quote
I have the tach/dwell meter too.
'72 Beetle
KingCarGuyZ
KingCarGuyZ is offline
PostPosted: Fri Sep 13, 2019 2:07 pm    Post subject: Re: Timing light with petronix Reply with quote
Used a Penske Just like that to time mine, my only advice is to time it at full advance at 43 degrees and then see what the idle is like, my pertronix SVDA likes about 6 degrees at idle which I have been told is not common.
