Mr. Okrasa  Original Old Speed
Joined: May 20, 2000 Posts: 745 Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
Posted: Sun Aug 11, 2019 10:48 pm Post subject: "Full Circle 36hp Weber Crankshaft |
I recently picked up this full circle 36hp Weber crankshaft. Unusual that it only has 4 dowels instead of eight
which suggests it's only a 64mm stroke??? The journals are all STD. @ 50mm and use a 36hp rod.
Click on this link below for photos:
https://www.instagram.com/p/B1DWn3xJJVQ/ _________________
See my Instagram: https://www.instagram.com/okrasa/
1959 VW Karmann Ghia Coupe / Bamboo-Green / Denzel 1300cc / OG. owner, paint
Denzel engine running. See this link: https://youtu.be/DgUlsQDTXTE
VW www.Okrasa.com |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7843 Location: Videbaek Denmark
Posted: Wed Aug 14, 2019 9:53 am Post subject: Re: "Full Circle 36hp Weber Crankshaft |
Looks like a VERY OLD Scat crank. |
gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1466 Location: San Carlos, CA
Posted: Wed Aug 14, 2019 10:15 am Post subject: Re: "Full Circle 36hp Weber Crankshaft |
Mr. O'
What's your plan for the crankshaft?
Cheers,
Paul _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
motofly196 Samba Member
Joined: June 01, 2008 Posts: 1467 Location: Eastern WA
Posted: Wed Aug 14, 2019 12:52 pm Post subject: Re: "Full Circle 36hp Weber Crankshaft |
Wasn't that listed on Samba for some crazy low price...think it was $250 or $350. It went fast... |
Posted: Wed Aug 14, 2019 10:06 pm Post subject: Re: "Full Circle 36hp Weber Crankshaft |
gimmesomeshelter wrote: |
Mr. O'
Cheers,
Paul |
Don't know. I purchased it more out of curiosity than function / use. I see that it's stamped: 3.000" which I'm assuming is the stroke? If that's the case, the stroke comes out to be: 76.2mm which is possible since someone mentioned earlier that it looks like an old SCAT crankshaft. Interesting that I once opened up a 36hp longblock built buy SCAT way back in the late 80's that had a (SCAT stamped) 76.2mm Porsche 356 crankshaft that had it's 53mm rod journals off-set ground to 50mm to give it that extra 2.2mm and used "clearenced" 36hp rods instead of Porsche 356. BTW: Because of the severe working angle of the conn. rod with that stroke and stock rod, 1 rod was severely bent!  _________________
VW www.Okrasa.com |
Posted: Wed Aug 14, 2019 10:35 pm Post subject: Re: "Full Circle 36hp Weber Crankshaft |
motofly196 wrote: |
When I saw the listing, I noticed that I was the 1st. person that had viewed it! It had "make offer" so I made an offer of $250 and he accepted.
It looked familiar and thought "that's a WEBER crankshaft". I had to go back and search and found some photos in the gallery.
Here are some photos. The first photo shows the crankshaft with a lightened flywheel. The second photo shows some other parts.
I purchased the Denzel heads with intake manifolds and original full flow oil filter set-up.
The crankshaft is currently at my crank grinder being magnafluxed to be sure it ain't broken.
VW www.Okrasa.com |
FritzCP Samba Member
Joined: October 23, 2005 Posts: 478 Location: Wisconsin
Posted: Thu Aug 15, 2019 11:40 am Post subject: Re: "Full Circle 36hp Weber Crankshaft |
Quote: |
BTW: Because of the severe working angle of the conn. rod with that stroke and stock rod, 1 rod was severely bent! |
The rod ratio of 130mm 36hp rod/ 74mm stroke is about 1.75
The rod ratio of 137mm 1600 rod/ 82mm storke is about 1.65
why would that rod ratio be so detrimental in a 36hp when a smaller ratio is commonly used in 1600 based 2L engines all the time without issue?
would the AA H beams solve the bent rod issue? _________________ Fritz Custom Products
Fritz Custom Products |
type4split Samba Member
Joined: May 23, 2007 Posts: 726 Location: Hamilton, Indiana
Posted: Tue Sep 03, 2019 7:29 pm Post subject: Re: "Full Circle 36hp Weber Crankshaft |
The crank and flywheel in those pictures are in my barn. It’s 8 dowel. . I was told those cranks are not worth the time. And they crack. I had it ‘fluxed and is shows ok. Who knows.....build it an see what happens 💥
The heads ended up with Raby at some point I was told. Don’t know where the bee hive is?? _________________ '67 deluxe bus w/the little windows
'52 beetle
'55 convertible
'50-something convertible (*need ribbed 'vert quarter panel )
'63 "milo" beetle
Part, parts and more parts |
Posted: Thu Sep 05, 2019 2:54 pm Post subject: Re: "Full Circle 36hp Weber Crankshaft |
Found my paper that I got with crank. Seller told me it was 78.4 Weber crank. _________________ '67 deluxe bus w/the little windows
'52 beetle
'55 convertible
'63 "milo" beetle
Posted: Sun Sep 08, 2019 7:53 pm Post subject: Re: "Full Circle 36hp Weber Crankshaft |
type4split wrote: |
The heads ended up with Raby at some point I was told. Don’t know where the bee hive is?? |
I ended up with the Denzel heads, intakes, oil fllter and lines.
VW www.Okrasa.com |
Joined: June 24, 2015 Posts: 874 Location: Rialto. CA
Posted: Mon Sep 09, 2019 2:22 pm Post subject: Re: "Full Circle 36hp Weber Crankshaft |
Joe..do you have any spare denzel oil lines ..
I can't seem to find any repros out there 😣 |
ALB Samba Member
Joined: August 05, 2008 Posts: 3499 Location: beautiful suburban Wet Coast of Canada
Posted: Thu Sep 12, 2019 7:12 pm Post subject: Re: "Full Circle 36hp Weber Crankshaft |
How much does that full circle thing weigh? _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
Posted: Thu Sep 12, 2019 8:31 pm Post subject: Re: "Full Circle 36hp Weber Crankshaft |
ALB wrote: |
How much does that full circle thing weigh? |
Don't know. I didn't weigh it so......... _________________
VW www.Okrasa.com |
sled Samba Member
Posted: Thu Sep 12, 2019 10:09 pm Post subject: Re: "Full Circle 36hp Weber Crankshaft |
ALB wrote: |
a lot _________________ drive your split. |
ALB Samba Member
Posted: Sun Sep 15, 2019 9:49 am Post subject: Re: "Full Circle 36hp Weber Crankshaft |
Mr. Okrasa wrote: |
ALB wrote: |
Don't know. I didn't weigh it so......... |
Stock/counterweighted/full circle- you, being the engine guru, would be the guy to have at least a stock crank to compare it to. Doesn't it pique your interest at all? And yeah, I'm sure it weighs a lot. _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
Posted: Tue Sep 17, 2019 6:39 pm Post subject: Re: "Full Circle 36hp Weber Crankshaft |
My full circle is ~20lbs. A stock 36hp crank is ~13lbs. Granted I’m just a guys in the garage with some old produce scales. ... but you get the idea of difference _________________ '67 deluxe bus w/the little windows
'52 beetle
'55 convertible
'63 "milo" beetle
ALB Samba Member
Posted: Wed Sep 18, 2019 7:56 am Post subject: Re: "Full Circle 36hp Weber Crankshaft |
type4split wrote: |
My full circle is ~20lbs. A stock 36hp crank is ~13lbs. Granted I’m just a guys in the garage with some old produce scales. ... but you get the idea of difference |
Thank you for taking the time to find out. _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
Posted: Wed Sep 18, 2019 10:04 am Post subject: Re: "Full Circle 36hp Weber Crankshaft |
ALB wrote: |
As soon as I received the Weber crankshaft, I took it to DPR (Jose) to have it magnufluxed to make sure it was good.
4 days later, Jose called me to let me know the crankshaft was broken in several places so I returned it to the owner
I didn't get a chance to weigh it though. _________________
VW www.Okrasa.com |
TomSimon Samba Member
Posted: Thu Sep 19, 2019 3:17 pm Post subject: Re: "Full Circle 36hp Weber Crankshaft |
Joe, a little footnote to the story of cast iron 36hp cranks: maybe 15yrs ago, I saw a "Whitfield" 36hp stroker crank for sale on Samba, that had me curious. Bud Whitfield (RIP) and I had raced together in the late 90's, early 2000's, he did some machine work for me, so I called him up to get the story, to see if this was his.
He just laughed, affirmed indeed, he had made a run of cast iron cranks in the early 1960's, and was sorry he did. He said "one of my big mistakes, if it wasn't already cracked, it would be shortly after anyone put it into an engine and ran it". Bud manufactured several vw performance parts while in Orange county, oil pumps, several other things that I can't remember. Billet was far too expensive, and custom forged was completely out of the question, people just weren't ready to spend that kind of money on the lowly vw platform back then. In order to make it cost effective, he had to have a pattern made and cast up 20 or 30 or more (he told me, I can't remember), then machine and grind them. Boy did he regret it, because in his words "They were all junk, wrong material, I didn't know any better back then!" he told me. "Volkswagen used cast iron crankshafts during development, but abandoned it because they kept breaking cranks, they didn't want to but, ended up witht he much more expensive forged cranks, from 36hp though to the 1600. The Brazilian factory got it figured out in the late 70's early 80's, so did CB with some densefied casting process I think" he added "they did fine for street and some mild performance, but I'd never use one of those for high rpm race use" _________________ 2-time NASA Pro Racing Champion, Bonneville 130 Club and 150 Club Memeber, BRS Pro Gas racer |
