blinkwatt Samba Member
Posted: Fri Oct 04, 2019 3:51 pm Post subject: Left Turn Signal |
Hi,
My cars left turn signal was working, when bought 3-4 months ago, but the automatic release(to indicate not turning anymore) doesn't work. I was told when the Momo steering wheel was put on they lost the auto release feature.
Now that I've driven the car a far share the left turn signal indicator flashes once, then stops.
Anyone have a clue? I'm not opposed to just replacing the steering switch if need be, but from searches it seems the aftermarket aren't as good as OEM. I just want it to work.
70'. |
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11470 Location: Huntington Beach, CA
Posted: Fri Oct 04, 2019 5:00 pm Post subject: Re: Left Turn Signal |
Have you looked at the bulbs and the wiring attached to the housing and the ground points?
My bet is a ground issue. _________________ Jimbo
| TDCTDI wrote: |
| Basically, a whole bunch of fuckery to achieve a look. |
| 67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
Posted: Fri Oct 04, 2019 5:35 pm Post subject: Re: Left Turn Signal |
| VW_Jimbo wrote: |
My bet is a ground issue. |
I can take a look tonight.
As far the turn signal releasing, I was told when they put the Momo wheel on they didn't have a specific part for it to work. Do you know what they were referencing? |
Posted: Fri Oct 04, 2019 6:48 pm Post subject: Re: Left Turn Signal |
| VW_Jimbo wrote: |
Thank you good sir! The driver side rear turn signal bulb was loose. |
Posted: Sat Oct 05, 2019 10:15 am Post subject: Re: Left Turn Signal |
The cancellation ring. It screws onto the bottom of the steering wheel and has a tab which directly interacts with the cams of the turn signal switch.
| TDCTDI wrote: |
