New to forum. A few questions.
Chillispud
Chillispud is offline
PostPosted: Tue Oct 08, 2019 1:34 am    Post subject: New to forum. A few questions. Reply with quote
Hi. I have been a viewer for long time but never posted. However seems there are some very knowledgeable people on here so thought would seek some advice. Number one. I have a reconditioned motor, just had it so done less than 50 km. . It has a small oil leak. Is this expected and are my expectations of a leak free engine unrealistic or should I not accepted it with oil leak.
Number 2, the van (1969 bay) smells of petrol, I have only just got the van back after a full restoration so havenโ€™t tested it much but seems worse on full take and when cornering. Thinking breather. Itโ€™s had all new fuel lines, tank etc. however I noticed the breather on the fuel filler next is open to atmosphere so probably leaking and spilling behind the filler flap?
Abscate
Abscate is offline
PostPosted: Tue Oct 08, 2019 3:43 am    Post subject: Re: New to forum. A few questions.1969 Bay Reply with quote
Gooday!
We like to see pictures here because it tells a lot about your rebuilder, from what parts they use, etc. get some nice clear , welllit pictures of your engine bay,five or six.
No reason for a rebuild to leak oil. This can range from the trivial to engine-out again.
Chillispud
PostPosted: Tue Oct 08, 2019 4:53 am    Post subject: Re: New to forum. A few questions. Reply with quote
Wasted youth
Wasted youth is offline
PostPosted: Tue Oct 08, 2019 5:00 am    Post subject: Re: New to forum. A few questions. Reply with quote
Don't know if this helps...
Pay attention to parts 23, 24 - A lot of time these hoses and tubes are found disconnected or with rotted rubber hose.
https://www.thesamba.com/vw/forum/viewtopic.php?p=4196358#4196358
Chillispud
PostPosted: Tue Oct 08, 2019 5:21 am    Post subject: Re: New to forum. A few questions. Reply with quote
Thanks. Basically all new system. Doesnโ€™t have the vapour risers in the air intakes though. Was wondering if a hose was missing between the pipe and hose in the Pic . Cheers.
Wasted youth
PostPosted: Tue Oct 08, 2019 5:32 am    Post subject: Re: New to forum. A few questions. Reply with quote
Yes, it appears you are missing a hose line there. But looking at the nipple on the body, I do not see enough pipe on it for a hose to slip over it, unless it is supposed to pass through the pipe, and not actually connect.
Wildthings
Wildthings is offline
PostPosted: Tue Oct 08, 2019 5:44 am    Post subject: Re: New to forum. A few questions. Reply with quote
I think the pipe is just a drain to the ground, so yes the hose should go into it just a bit.
I think you need to understand that just because you got an engine rebuild it doesn't mean everything on the car or even the engine has been fixed. You likely need to spend weeks fixing little stuff as it crops up.
Wasted youth
PostPosted: Tue Oct 08, 2019 6:05 am    Post subject: Re: New to forum. A few questions. Reply with quote
Well, it wasn't just an engine rebuild.
Chillispud wrote:
... the van (1969 bay) smells of petrol, I have only just got the van back after a full restoration ...
Seems like the usual deal. Paid for something, and didn't quite get what you paid for.
SGKent Premium Member
SGKent is offline
PostPosted: Tue Oct 08, 2019 6:12 am    Post subject: Re: New to forum. A few questions. Reply with quote
better post the bears Smile
George Carlin:
Skills@EuroCarsPlus:
Wildthings
PostPosted: Tue Oct 08, 2019 6:24 am    Post subject: Re: New to forum. A few questions. Reply with quote
A full restoration is a very big grey area, often with lots of smoke and mirrors. One person's full restoration might be $5000, while another's might be $60,000.
Wasted youth
PostPosted: Tue Oct 08, 2019 6:57 am    Post subject: Re: New to forum. A few questions. Reply with quote
Yep!
In my book, a 'full restoration' means bone stock, perfect, as factory delivered.
Chillispud
PostPosted: Tue Oct 08, 2019 1:20 pm    Post subject: Re: New to forum. A few questions. Reply with quote
It was a full bare metal restoration. $50k ish. Anyway. Was hoping someone Had a pic off their bus showing how that breather should connect. Thanks
BYeaton
BYeaton is offline
PostPosted: Tue Oct 08, 2019 2:50 pm    Post subject: Re: New to forum. A few questions. Reply with quote
Chillispud wrote:
The painted inlet on the left side may be where your tank is vented. I have never seen a vent on the filler neck like the one pictured in black. I would guess that that may just vent to the fill well and drain through the bottom hole to the ground? Here is a picture I found while researching my own venting issues of a 68 double cab vent, may be similar? Is your bus right hand drive? You could try and introduce some light air pressure through some of the vent openings/ filler neck and see where it blows out?
tommu Premium Member
tommu is offline
PostPosted: Tue Oct 08, 2019 8:04 pm    Post subject: Re: New to forum. A few questions. Reply with quote
In that case - it should not leak oil or smell of petrol! Smaller things might be easier for you to sort yourself. But it is always worth letting the restorer know about oil leaks etc. If they're reputable they'll want a chance to fix it for you.
We are missing pictures of the the Bus itself!
Green Bay Bus Yellow Ghia
Chillispud
PostPosted: Tue Oct 08, 2019 8:19 pm    Post subject: Re: New to forum. A few questions. Reply with quote
thanks for the feedback. the van will go in for a retune soon and already have raised rthe issues with restorer, howeve just wanted to see about the fuel smell in the short time as i am driving the van around and not overly keen on waiting to fix the smell. as requested a few pics of the van
Wildthings
PostPosted: Tue Oct 08, 2019 9:15 pm    Post subject: Re: New to forum. A few questions. Reply with quote
Someone doing major body work may have little knowledge of the mechanical side, I would say that that is very common.
Abscate
Abscate is offline
PostPosted: Wed Oct 09, 2019 3:46 am    Post subject: Re: New to forum. A few questions. Reply with quote
Itโ€™s a six picture series of the engine, left to right and then two of the bottom that will tell us the tale.
New paint always looks good,itโ€™s 12months later that tells that tale.
SamboSamba22
SamboSamba22 is offline
PostPosted: Wed Oct 09, 2019 6:46 am    Post subject: Re: New to forum. A few questions. Reply with quote
Morning gents. Your fuel leak, is it coming through the cap itself? I recently had to replace my seal in the cap as it was leaking on 1/2 a tank or more, and especially in turns and cornering.
Picked up the 70mm seal from Wolfsburg West, no more leaks. Being in my 68 double cab, I pulled the parcel panels off to validate that all that fuel smell was in fact just coming from the gas cap leak. Which completely surprised me.
All is well now.
Beautiful bus. I imagine itโ€™s probably something small. Good luck
The Bus Barn Ltd. Co.
Oct. โ€™67 Double Cab (โ€™68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL]
jtauxe Premium Member
jtauxe is offline
PostPosted: Wed Oct 09, 2019 7:11 am    Post subject: Re: New to forum. A few questions. Reply with quote
You've got that right!
OP your newly rebuilt engine should not leak oil.
John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus
, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Chillispud
PostPosted: Wed Oct 09, 2019 1:17 pm    Post subject: Re: New to forum. A few questions. Reply with quote
Thanks all. Will start with fuel cap and work back from there.
