JP38 Samba Member
Joined: July 08, 2005 Posts: 33 Location: Grenoble - France
Posted: Tue Jul 12, 2005 7:00 pm Post subject: Judson Supercharger on convertible ? |
Hello,
Is it possible to put a Judson Supercharger on 55 convertible ?
I don't know if it's possible cause the rear hood is different (behind the two air intake vents).
Thank you in advance  |
coolairX2 Samba Member
Posted: Tue Jul 12, 2005 8:04 pm Post subject: Judson |
I have seen Judson's installed on early cabrios but it required metal to be taken out of the air filter or deck lid vents.
-Craig |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
roy kohrogi Samba Member
Joined: September 23, 2000 Posts: 171 Location: TORRANCE CA
Posted: Wed Jul 13, 2005 1:37 pm Post subject: Re: Judson Supercharger on convertible ? |
| JP38 wrote: |
Hello,
I would say "don't do it", very expensive convertible only W-deck lid
is not worth chopping.W conv deck lid rain catcher are non-removable.
we all know Conv W deck lid is much more expensive than Judson kit.
another issue is not just a deck lid but license plate light (threaded stud)
must be grind off about 3mm. otherewise judson pulley might hit.
we went far as grind few mm off the judson air cleaner.
here is our convertible with Judson supercharger, we didn't like Judson.
so now sports a OMT built Auto Teknik motor & W-conv deck lid.
before:
I will post after photo.
Take Care
Roy  |
Posted: Wed Jul 13, 2005 2:07 pm Post subject: |
Judson built by famous engine builder in Orange county CA & Auto Teknik
was built by Al /AKA:OMT: we love OMT motor much better.
current:
Posted: Wed Jul 13, 2005 2:27 pm Post subject: Re: Judson Supercharger on convertible ? |
| roy kohrogi wrote: |
Yes, they are removeable. All you need to do is to drill out the spot welds holding it on. _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Posted: Wed Jul 13, 2005 2:43 pm Post subject: Re: Judson Supercharger on convertible ? |
| [email protected] wrote: |
Yes, they are removeable. All you need to do is to drill out the spot welds holding it on. |
Okay wiseguy drill out the spot weld will remove it.
I want to see you do it on your W Convertible deck lid.
will personally come over to observe it.
can you take it off without drill the hole on the actual deck lid ?
or require additional welding to cover the hole.
is it worth taking it off ? |
Posted: Wed Jul 13, 2005 4:55 pm Post subject: Re: Judson Supercharger on convertible ? |
Yeah, I'm a wise guy. Check out most of the high-performance VW enthusiasts running a convertible W lid on their cars, they all have the rain catches removed. Rob "Dr Decklid" La Grange removes the trays all the time. Check out his web site at: www.sandiegovwparts.com maybe you're just too cheap, scared or both to attempt it yourself.
As for "is it worth it?" Ask the person who wants to have it done. If they want it done, it's for a purpose. Maybe to clear the larger than stock 48IDA velocity stacks for a motor that is substantially larger than a 25 or 36hp motor. _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
JP38 Samba Member
Posted: Wed Jul 13, 2005 5:56 pm Post subject: |
Thank you for all these messages
so now sports a OMT built Auto Teknik motor & W-conv deck lid. |
Why you don't like Judson ?
And if you don't like it, so why you have a Judson supercharger in your convertible ?
we all know Conv W deck lid is much more expensive than Judson kit. |
Here a Judson is more expensive than Conv W deck lid.
we went far as grind few mm off the judson air cleaner. |
Thanks for these details.
current:
Where can I buy this sports a OMT built Auto Teknik motor ?
Is it an Okrasa kit ? please, give me more details
As for "is it worth it?" Ask the person who wants to have it done. If they want it done, it's for a purpose. Maybe to clear the larger than stock 48IDA velocity stacks for a motor that is substantially larger than a 25 or 36hp motor. |
For me, a true restauration is with the rain catches. I don't want remove them. |
John Moxon  Samba Moderator
Joined: March 07, 2004 Posts: 14258 Location: Southampton U.K.
Dave Samba Elder
Joined: July 11, 2002 Posts: 2718 Location: The Forest Moon of Endor, in the Redwoods
Posted: Thu Jul 14, 2005 6:33 am Post subject: |
Roy, that convertible W decklid, looks vaguely familiar...
I had the rain catchers removed by the aforementioned "Dr. Decklid" for my Oval with IDAs, tall manifoilds, air cleaners, no cutting of the body, and no popping open of the decklid, either top OR bottom, and I have also seen him take them out to repair the lid, and when he was done, spot-weld it back in, and you would never know it had been removed, for any reason, when he was done.
Roy, if you want Rob's e-mail or phone number, PM me, and I'll get it to you. _________________ 2003 Samba Chummie Winner- Best Story
"Those that matter, don't mind,
and those that mind, don't matter" |
Posted: Thu Jul 14, 2005 7:02 am Post subject: |
You're vert lid can't be worth that much. Look at all those non-factory holes on the side of the rain catch. I know those aren't stock. It'll be easier having Rob re-install a rain catch that having those things patched up. _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
restojohnny Samba Member
Joined: February 13, 2004 Posts: 2848 Location: SPLITSVILLE , SON !!!!
Posted: Thu Jul 14, 2005 7:57 am Post subject: |
You're vert lid can't be worth that much. Look at all those non-factory holes on the side of the rain catch. I know those aren't stock. It'll be easier having Rob re-install a rain catch that having those things patched up. |
I think those holes are for the carb's to breath alittle more air better (I think)
But fuggit all that Glenn & Roy !!!! You two better play nice on the keyboards or it's a TIME OUT for both of you this weekend missing Pomona on sunday ya little brats Then you guy's can't comeover to my swap space and check out my crap !!!!! maybe buy something and help my ass put my kid's through college ! Sheeesh  _________________ $$$ HUSTL'N AIN'T EAZEE $$$
** HELL YEAH I'LL SELL IT TO YOU**
O.G. POMONA VULTURE
MAGNESIUM BRM HOARDING BASTARD !!!!
$$ SWAPMEET MAFIA $$
48 split $$$$
53 LHD, LH cargo door standard kombi
54 Pre-A Porsche
55 oval ribbed door non-semiphore
56 semiphore ragtop
63 notchback (work in progress)
67 original Empi GTV beetle convertible !!
67 deluxe walkthru (work in progress)
67 convertible ghia (work in progress)
"STAY OUTTA MY BACKYARD !!! " |
Posted: Thu Jul 14, 2005 10:46 am Post subject: |
Thanks for the kind comment, Glenn, Johnny I will see you at Pomona.
I admit Scare to cut the rain catcher on W deck lid.
but, far as cheap I disagree because changed the motor just for the deck lid. (as shown on the above photo)
cheap guy will butch the rain catcher.
Thanks Dave but while back you already introduced Dr.Deck Lid.
recalled he was former rock star.saw 67 convertible deck lid
created by him and it was amazing work.
JP38 will PM you.
no intention to start the stock vs Custom thread.(beacuse never ending) |
Dave Samba Elder
Posted: Thu Jul 14, 2005 12:51 pm Post subject: |
That's right, Roy, I DID introduce you to "Dr. Decklid, the former bass player for Ted Nugent... I forgot, senility and all that carb cleaner must be taking it's toll on me
BTW, if the holes in the side of that decklid bother you at all, I had spoken with Rob before, and he said he could remove the rain catch, make plugs for the holes, weld them in, and metal-finish it on BOTH sides, so you would never, ever, know they were there. _________________ 2003 Samba Chummie Winner- Best Story
Posted: Thu Jul 14, 2005 1:15 pm Post subject: |
Thanks Dave
The convertible will be "weekend driver" and no intentions to show again.
therefore, the holes on the side doesn't bother me a bit.
very busy restoring the split window & the split windshield (pre A)
as always working on our car is most relaxing and temporary escape from
reality. I do better on wrenches than a key board that's why less than 100 posts in last 5years.
Take Care
Roy  |
CALI47 Banned
Posted: Thu Jul 14, 2005 3:53 pm Post subject: cost |
| how much would an OMT like that run? i an getting a stock 36hp and iam looking to "soup" it up. |
Posted: Thu Jul 14, 2005 6:25 pm Post subject: I was in the same boat |
I didn't want to cut open a perfectly good newly painted 58 Ghia engine lid, but I cut anyway.
Since then, I took the Judson off as well and just left the 36hp engine. It was just easier and less worries for what is now a weekend driver as well. I don't really miss the hp.
-Craig |
OMT Samba Member
Posted: Thu Jul 14, 2005 7:25 pm Post subject: |
| restojohnny wrote: |
But fuggit all that Glenn & Roy !!!! You two better play nice on the keyboards or it's a TIME OUT for both of you this weekend missing Pomona on sunday ya little brats Then you guy's can't comeover to my swap space and check out my crap !!!!! maybe buy something and help my ass put my kid's through college ! Sheeesh  |
I couldn't have said it better myself!
Later,
Al |
DMNCLNR Sir Camp'alot
Joined: November 12, 2003 Posts: 2897 Location: Newport Beach Ca
Posted: Sat Nov 24, 2007 2:10 pm Post subject: Re: Judson Supercharger on convertible ? |
| JP38 wrote: |
Hello,
before:
Take Care
Roy  |
Was it nessecary to remove the rain catcher on the later decklid? I notice you don't have a decklid on there at all?
Just curious. _________________ To his their own PBJ
Pl@y@ #1 |
