lostforfun Samba Member
Joined: June 08, 2004 Posts: 5 Location: Aurora, Colorado
Posted: Sun Sep 29, 2019 11:50 am Post subject: 63' floor pan replacement, who makes the best? |
I have a 63' beetle and I'm replacing the floor pans. Actually, this is a full restoration and I want to keep it as close to factory original as I can. I know I can't get orignial German pans anymore. That being said, who makes the closest to OEM/NOS that I can get my hands on. All i can find are ones made in Mexico, Brazil or Taiwan. I head that the ones from Klokkerholm are from Taiwan. Is that true? I would at-least like to keep the pans European as close to Germany as possible. Any help I can get website links, phone numbers or anything would be awesome.
Thank you! |
67ctbug Samba Member
Posted: Sun Sep 29, 2019 12:02 pm Post subject: Re: 63' floor pan replacement, who makes the best? |
Klokkerholm is Danish. I can assure you, you most likely do not want to keep your pans European 'cause they will suck! I would go with the pans from Wolfsburg West, everyone says they're the best.
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111701061M _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
aa390392 Samba Member
Posted: Sun Sep 29, 2019 1:25 pm Post subject: Re: 63' floor pan replacement, who makes the best? |
Question are you needing fun pans or partial? _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
Posted: Sun Sep 29, 2019 2:04 pm Post subject: Re: 63' floor pan replacement, who makes the best? |
They will be full left and right. |
viiking Samba Member
Joined: May 10, 2013 Posts: 2670 Location: Sydney Australia
Posted: Sun Sep 29, 2019 3:39 pm Post subject: Re: 63' floor pan replacement, who makes the best? |
The ones WW supply are in my opinion the best.
Thick, with crisp stamping and all the holes lined up perfectly. Just use your own rear cross member supports and jack points if possible to maintain as much originality as possible. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
motofly196 Samba Member
Joined: June 01, 2008 Posts: 1467 Location: Eastern WA
Posted: Mon Sep 30, 2019 8:06 am Post subject: Re: 63' floor pan replacement, who makes the best? |
Wolfsburg West pans are the thickest I've used...almost drop right in with very little massaging on the front outside corners. Every pan is welded here at the factory...so it varies from car to car just how thick the weld bead was originally. The WW pans are stamped with just enough extra metal to grind to fit your pan. The thickness and stampings couldn't be any better in my mind... (Unless you are replacing them in a Split or Oval, they lack some originality there) |
andrewda Samba Member
Joined: September 26, 2018 Posts: 54 Location: Middletown, NJ
Posted: Mon Sep 30, 2019 10:42 am Post subject: Re: 63' floor pan replacement, who makes the best? |
Wolfsburg west are solid quality for your year car, they are what I used. For splits and ovals I believe it goes to Klassicfab, but they only make floorpans for those early bugs |
Digger89L Samba Member
Joined: May 16, 2013 Posts: 1130 Location: Western Canada (SK)
Posted: Sun Oct 13, 2019 8:24 pm Post subject: Re: 63' floor pan replacement, who makes the best? |
So ....everyone seems to agree that WW pans are the best ...but no one says where they are made? Are we to believe that WW has invested in the very heavy equipment, and almost-exactly-original metal stamping molds to make VW Beetle floor pans for a quite-limited, narrow VW restoration market? Million$, I would guess .... _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
Meiang Samba Member
Joined: September 27, 2016 Posts: 656 Location: Perth, Western Australia
Posted: Sun Oct 13, 2019 9:02 pm Post subject: Re: 63' floor pan replacement, who makes the best? |
If it does not say where it is made - assume China.
Pans made in Europe or the USA would "scream" that they are made there.
I recently bought a Hella workshop lamp which cost around US$300 and it did not say where it was made. After a bit of research guess what - it was made in China.
splitjunkie Samba Member
Posted: Mon Oct 14, 2019 4:46 am Post subject: Re: 63' floor pan replacement, who makes the best? |
Digger89L wrote: |
So ....everyone seems to agree that WW pans are the best ...but no one says where they are made? Are we to believe that WW has invested in the very heavy equipment, and almost-exactly-original metal stamping molds to make VW Beetle floor pans for a quite-limited, narrow VW restoration market? Million$, I would guess .... |
If you don't want to buy anything made in China then sell your VW right now because more and more stuff is made there. The WW pans are light years better than the Danish pans. There is no comparison. _________________ Chris
Meiang Samba Member
Posted: Mon Oct 14, 2019 5:16 am Post subject: Re: 63' floor pan replacement, who makes the best? |
No Chinese stuff in my VW Beetle. |
Posted: Mon Oct 14, 2019 9:18 am Post subject: Re: 63' floor pan replacement, who makes the best? |
I subscribed to WW's YouTube channel ....lots of 'warehouse' tours ...no factory tours. You'd think a company that advertises "Made by Wolfsburg West" would be proud to show off their factory where they take raw, flat rolled steel sheets and turn it into floor pans and body repair panels ....not to mention all the other bits and bobs "Made by Wolfsburg West". ...Just saying .... _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
