Help please slammed 59 rear shocks
Jason Eden
Jason Eden is offline
PostPosted: Fri Nov 08, 2019 5:47 pm    Post subject: Help please slammed 59 rear shocks Reply with quote
Anyone know a part number so I can but some shocks for a 59 bug ? It’s pretty low The ones I have make it hop Thanks
59 bug slammed with cosmics
mcmscott
mcmscott is offline
PostPosted: Fri Nov 08, 2019 5:56 pm    Post subject: Re: Help please slammed 59 rear shocks Reply with quote
Shocks will not make your car hop, what are you trying to acomplish?
There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
NJ John
NJ John is offline
PostPosted: Fri Nov 08, 2019 6:53 pm    Post subject: Re: Help please slammed 59 rear shocks Reply with quote
Bad trans mounts?
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
Jason Eden
PostPosted: Fri Nov 08, 2019 7:04 pm    Post subject: Re: Help please slammed 59 rear shocks Reply with quote
No it’s all solid mounts raised 2” but big is pretty low
[email protected]
gkeeton@zbzoom.net is offline
PostPosted: Sat Nov 09, 2019 8:27 am    Post subject: Re: Help please slammed 59 rear shocks Reply with quote
While the white KYB gas adjust have a more aggressive rebound than compression, it’s most likely your springplates being rotated to the point that the torsion bar is being significantly unloaded causing the bounce. Koni has adjustable rebound shocks you could maybe try #80-1350.
jason
jason is offline
PostPosted: Sat Nov 09, 2019 12:46 pm    Post subject: Re: Help please slammed 59 rear shocks Reply with quote
Measure the shock bolt distance at ride height. Buy a shock that fits to that.
They hop when they’re on the stops, make sure your not.
Jason Eden
PostPosted: Sat Nov 09, 2019 2:39 pm    Post subject: Re: Help please slammed 59 rear shocks Reply with quote
I have the jerfab drop plates and motor lifted 2” so don’t think it’s bottoming out
