44'rs..... or 40's. best all around use.
raunchy57'
raunchy57' is offline
PostPosted: Mon Nov 25, 2019 3:54 pm    Post subject: 44'rs..... or 40's. best all around use. Reply with quote
Made minor changes to my motor, ( 1968cc), 74mm Forged Crank, 92mm pistons, Mag case sleeved lifter bores, VZ-25 cam, 041 heads 39x35 dual springs, UN-ported, 9:1 comp, Magnum Straight-cuts,.. Not for track use, for weekend cruz, with lots of pounding..!! Smile . Thanks for everyone's opinions Very Happy
Bama Dave
Bama Dave is offline
PostPosted: Mon Nov 25, 2019 4:33 pm    Post subject: Re: 44'rs..... or 40's. best all around use. Reply with quote
I say Weber or Dell 40s...unless you plan on driving at high rpms all the time. Even then, 40s for that size engine. Here comes a bunch of other opinions...
David Richerson
!964 Beetle Sedan
1970 Beetle Sedan
1971 Super Sedan
1972 Baja
hellthorne wrote:
First off, I know i made stupid decisions that led to my predicament, so while you are welcome to tell me that I am an idiot for doing the things I did, please know that I am already aware of this.
Casting Timmy
Casting Timmy is offline
PostPosted: Mon Nov 25, 2019 4:59 pm    Post subject: Re: 44'rs..... or 40's. best all around use. Reply with quote
The Dell 40's sound really nice. You could get away with dual weber 40's, but in the end some people run 48 ida's on smaller motors so larger carbs will let it run.
If you plan on bigger motors down the line, do the 44's.
T1 IRS Rebuild Book on Lulu.com
http://www.lulu.com/shop/tim-marshall/t1-irs-transaxle-book/paperback/product-24055997.html
As seen in Volks America Issue 14 Page 11 (Full page review)
vwracerdave
vwracerdave is offline
PostPosted: Mon Nov 25, 2019 5:02 pm    Post subject: Re: 44'rs..... or 40's. best all around use. Reply with quote
36 Dellorto or 40 IDF would work best. Upgrade to larger 30-32mm venturies.
40 Dels or 44 IDF's are too big.
raunchy57'
PostPosted: Mon Nov 25, 2019 10:18 pm    Post subject: Re: 44'rs..... or 40's. best all around use. Reply with quote
How about if I slapped in a set of 32mm venturies in a set of 44'rs..?
vwracerdave
PostPosted: Mon Nov 25, 2019 11:58 pm    Post subject: Re: 44'rs..... or 40's. best all around use. Reply with quote
You can get them to work fairly close, but you ask for "BEST".
mark tucker
mark tucker is offline
PostPosted: Tue Nov 26, 2019 7:35 am    Post subject: Re: 44'rs..... or 40's. best all around use. Reply with quote
40's and port the heads properly for the usage....why waste the $$ to build it or stroke it if the heads wont support it....thats how oh somany engines get blown up and run hot. from trying to make more power than they can flow air. air= hp=tq
[email protected]
roy@mofoco.com is offline
PostPosted: Tue Nov 26, 2019 9:55 am    Post subject: Re: 44'rs..... or 40's. best all around use. Reply with quote
With this combo; your best option is the dual 40 IDF's.
Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet
Dale M.
Dale M. is offline
PostPosted: Tue Nov 26, 2019 10:04 am    Post subject: Re: 44'rs..... or 40's. best all around use. Reply with quote
I always considered anything under 2000cc to be candidates for 40's (Weber's or HPMX), over 2000cc 44's...
Dale
raunchy57'
PostPosted: Tue Nov 26, 2019 11:23 am    Post subject: Re: 44'rs..... or 40's. best all around use. Reply with quote
Got it..! Very Happy
raunchy57'
PostPosted: Tue Nov 26, 2019 11:25 am    Post subject: Re: 44'rs..... or 40's. best all around use. Reply with quote
True ... ! Smile Thanks.!!
raunchy57'
PostPosted: Tue Nov 26, 2019 11:26 am    Post subject: Re: 44'rs..... or 40's. best all around use. Reply with quote
Thanks..!!! Very Happy
raunchy57'
PostPosted: Tue Nov 26, 2019 11:27 am    Post subject: Re: 44'rs..... or 40's. best all around use. Reply with quote
Dale
Thanks..!! Very Happy
raunchy57'
PostPosted: Tue Nov 26, 2019 11:30 am    Post subject: Re: 44'rs..... or 40's. best all around use. Reply with quote
raunchy57'
Thanks..! Very Happy
raunchy57'
PostPosted: Tue Nov 26, 2019 4:11 pm    Post subject: Re: 44'rs..... or 40's. best all around use. Reply with quote
I'm gonna go with the 40 idf's,... 30 or 32mm venturies?.. for BEST.? ( the stock jets should be alright.?
mark tucker
PostPosted: Tue Nov 26, 2019 5:36 pm    Post subject: Re: 44'rs..... or 40's. best all around use. Reply with quote
jet it for what it needs. rarely do they come with the correct jetting.always check it along with the plug heat range reading.
raunchy57'
PostPosted: Wed Nov 27, 2019 12:25 pm    Post subject: Re: 44'rs..... or 40's. best all around use. Reply with quote
good call. tnx. Very Happy
[email protected]
PostPosted: Wed Nov 27, 2019 12:45 pm    Post subject: Re: 44'rs..... or 40's. best all around use. Reply with quote
With your specs, the way it is set up out of the box(assuming you are buying REAL GENUINE webers) is going to be VERY close. I wouldn't change anything until you try and run it.
www.mofoco.com
raunchy57'
PostPosted: Wed Nov 27, 2019 3:03 pm    Post subject: Re: 44'rs..... or 40's. best all around use. Reply with quote
Alright..! good to hear that., Tnx lots. ( real Weber's ) Very Happy
