Subaru Swap
Page: Previous  1, 2, 3 ... 13, 14, 15
WithTheFlow
WithTheFlow is offline
PostPosted: Tue Jul 16, 2019 10:57 pm    Post subject: Re: Subaru Swap Reply with quote
skills@eurocarsplus wrote:
WithTheFlow wrote:
Thoughts?
go for the 2.5 I wouldn't mess with what you have
I put the 1.8 for sale. Maybe someone will want it for their bug
The fastest thing you can do is slow down.
“The secret is here in the present. If you pay attention to the present, you can improve upon it. And, if you improve on the present, what comes later will also be better."
-- The Alchemist”
Wags74
Wags74 is offline
PostPosted: Mon Dec 16, 2019 7:42 am    Post subject: Re: Subaru Swap Reply with quote
Has anyone ever used the fuel pump from a Subaru? I pulled the pump assembly out of my donor car and separated the pump from it. The only place I see for a potential issue is on the suction end where it looks like the shaft comes through the case. When i have a chance I'm going to hook some hoses to it and pump water through it to see if it leaks. Unless someone with more experience tells me this is a bad idea.
clonebug
clonebug is offline
PostPosted: Mon Dec 16, 2019 8:49 am    Post subject: Re: Subaru Swap Reply with quote
Pumping water through a fuel pump will kill it.
richardcraineum wrote:
I'm so ignorant of efi I don't even know the difference between batch, sequential blah blah blah ..
cbeck wrote:
His user name in a previous life was dick head.
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936
Wags74
Wags74 is offline
PostPosted: Mon Dec 16, 2019 11:01 am    Post subject: Re: Subaru Swap Reply with quote
Good to know. I don't want to pump gas through it near an open container because the terminals are exposed. Is there anything I can use? Looking for something with a really low viscosity.
Page 15 of 15
