Nightshift Samba Member
Posted: Mon Jan 13, 2020 4:26 pm Post subject: Pertronix Distrbutor Choices 1915 |
I have a Chenoweth, street driven with a 1915cc/Engle 120/9.5-1/compression/Mofoco Heads. Currently has a 009 mechanical advance and running a Bosch blue coil. I am considering a new Pertronix distributor. I see they have a few choices. Should I change to Vacuum advance or stick with mechanical and still multiples to choose from either way I go?
I would like to keep the blue coil if that helps. What one and why?
Thanks Ken |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79497 Location: Sneaking up behind you
Posted: Mon Jan 13, 2020 4:52 pm Post subject: Re: Pertronix Distrbutor Choices 1915 |
Get the cb magnaspark. The pertronix are of low quality. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Mon Jan 13, 2020 5:06 pm Post subject: Re: Pertronix Distrbutor Choices 1915 |
Glenn wrote: |
Thanks Glen, I will do some research on them. Not much more money. |
JWHracing Samba Member
Joined: September 17, 2008 Posts: 251 Location: Mesa, AZ
Posted: Tue Jan 14, 2020 8:02 am Post subject: Re: Pertronix Distrbutor Choices 1915 |
Agreed with Glenn. Absolute best bang for your buck and great performance. I have had mine for 4 years with 0 issues. _________________ 65 Baja - Class 5 Unlimited Race Car
2021 STORR Pro Air Cooled Buggy Champion
2019 AZOP Unlimited Buggy Champion
2017 SADR 1300 Class Champion
2016 AZOP Limited Buggy Champion
Currently "retired" from racing |
Posted: Tue Jan 14, 2020 6:29 pm Post subject: Re: Pertronix Distrbutor Choices 1915 |
I will be ordering the kit Wednesday. I run the blue coil at this time. Any thought on the one that comes with the kit? Also a light rail like mine driven on the streets mostly, what weight and spring recommendations?
Thanks |
Glenn  Mr. 010
Posted: Tue Jan 14, 2020 6:53 pm Post subject: Re: Pertronix Distrbutor Choices 1915 |
Nightshift wrote: |
Thanks |
It depends on the engine specs, not the vehicle. _________________ Glenn
Member #1009
#BlueSquare
jimmyhoffa Samba Member
Joined: February 16, 2014 Posts: 1178 Location: St. Louis
Posted: Tue Jan 14, 2020 6:56 pm Post subject: Re: Pertronix Distrbutor Choices 1915 |
Nightshift wrote: |
Thanks Ken |
Quite a coincidence! I have a Chenowth rail, street driven, 1915 with MOFOCO heads. Came from an old Bosch 009 to the CB Magnaspark, and love it. Just buy the kit with their coil- nice powerful spark. _________________ 1974 Chenowth 2RL #1244 Street Legal
My other car isn't ridiculous. |
Posted: Wed Jan 15, 2020 2:52 pm Post subject: Re: Pertronix Distrbutor Choices 1915 |
1915cc/Engle 120/9.5-1/compression/Mofoco Heads/1.1-1 rockers,IDF44
Magnaspark is on the way. Happy. |
Posted: Thu Jan 16, 2020 9:56 am Post subject: Re: Pertronix Distrbutor Choices 1915 |
Single 44IDF centermount or duals? _________________ 1974 Chenowth 2RL #1244 Street Legal
Posted: Thu Jan 16, 2020 6:13 pm Post subject: Re: Pertronix Distrbutor Choices 1915 |
Single IDF 44, I had a sacrificial exhaust left over from when I bought the rail. I installed it and did some Delta P testing across the 4 exhaust outlet to the mufflers downstream side to make sure I would have enough exhaust flow.(4"h20 depreciation) I broke out the Tig welder and made some stainless steel piping and welded on a flanges to pipe leaving the #4 ex port and into the downstream side of the muffler. Manifold heat works well. Runs much better. A work in process, Nice car, clean. Engine was a mess when I bought it, it has come around.
New distributor going in and re-jet again. LOL. |
Posted: Thu Jan 16, 2020 7:45 pm Post subject: Re: Pertronix Distrbutor Choices 1915 |
Nightshift wrote: |
Single IDF 44, I had a sacrificial exhaust left over from when I bought the rail. I installed it and did some Delta P testing across the 4 exhaust outlet to the mufflers downstream side to make sure I would have enough exhaust flow.(4"h20 depreciation) |
What will really amaze you is how little Delta P it really takes! Check out some stock VW Thing exhausts, they get the differential they need simply by how the heat flange tube enters the #2 cylinder and exits the #4. I also kind of assume that one direction would be better than the other just based on firing order, if you take the #2 to #4 flange approach. I believe it's Vintage Speed that has an exhaust that uses little scoops kind of like VW did with the Thing, it apparently works well without porting to after the collector like you did. Who would have thought! I like your way too. It's a sure fire way to a result without needing to corral exhaust pulses with a little scoop.
How's that bad boy idle with a Centermount and an Engle 120? I'd love to see a video! _________________ 1974 Chenowth 2RL #1244 Street Legal
Posted: Thu Jan 16, 2020 8:00 pm Post subject: Re: Pertronix Distrbutor Choices 1915 |
The distributor should be arriving next week. A bit of ingenuity out in the shop and I should be able to tune the advance for a bit more lower end. I gave a thought to the 2/4 exhaust pulse. I did not want to deal with any reversion during valve overlap. The fact is I did not have enough cam specs to run it on my simulator. So out the exhaust (Muffler) it went.
Jimmy Hoffa You have a PM |
