Lowering with T-1 spindels.
Page: Previous  1, 2, 3
mr. warehouse
mr. warehouse is offline
PostPosted: Sun Feb 02, 2020 9:15 am    Post subject: Re: Lowering with T-1 spindels. Reply with quote
Terry Gaudet wrote:
Oh, and one more question. What is the overall width difference between the stock barndoor beam and a beetle k&l beam? I am also going to consider modifying an early beetle beam to fit barndoor chassis so I can use beetle spindles to mount my 356 brakes.
I run 356 spindles and brakes on this with a stock BD beam. No need to swap to a beetle beam.
mr. warehouse
PostPosted: Sun Feb 02, 2020 9:18 am    Post subject: Re: Lowering with T-1 spindels. Reply with quote
Terry Gaudet wrote:
Thanks for posting the picture Mr. Warehouse. It helps me see the mods.
So these will fit on 55-63 bus front beam arms?
They will work on early arms.
I have spindles ready to bolt on if you need/want a set that are done.
I have 356 and T1 beetle. Whichever suits your needs.
djfordmanjack
djfordmanjack is offline
PostPosted: Sun Feb 02, 2020 10:59 am    Post subject: Re: Lowering with T-1 spindels. Reply with quote
that is a terrific looking early truck ! loving the bias ply on white steelies over aluminium drums. perfect stance too!
54 Oval project
62 Dickholmer, Seeblau L360
mr. warehouse
PostPosted: Sun Feb 02, 2020 11:02 am    Post subject: Re: Lowering with T-1 spindels. Reply with quote
Thanks. I have a set of slotted 356 16's as well. I may run them instead. I'm still in the "mocking up" stages.
djfordmanjack
PostPosted: Sun Feb 02, 2020 11:28 am    Post subject: Re: Lowering with T-1 spindels. Reply with quote
These days it is very rare for people to run bias ply on steelies under a somewhat lowered bus ( I know yours is already severly lowered considering the tall tires). the pie-crust of bias ply tires just kills me all the time. I personally just don't like the looks of the average modern low cross section radial tires at all. Really refreshing to see your set up. imho the factory steelies work just great over the Porsche drums and without hubcaps. all serious business.
54 Oval project
mr. warehouse
PostPosted: Sun Feb 02, 2020 11:55 am    Post subject: Re: Lowering with T-1 spindels. Reply with quote
I'm going the "Vintage Speed" route with a Porsche internal 1500cc 36hp based dual P-11 engine for power so, I wanted to keep the tire with the correct look as well. It took quite a while to find Firestone's that matched the rear in a "low profile"
djfordmanjack
PostPosted: Sun Feb 02, 2020 12:16 pm    Post subject: Re: Lowering with T-1 spindels. Reply with quote
They are probably 4.50/4.75 -16 Also use them on hotrods and going to put on my Barndoor project. it is not easy to cope with the tall tires on a lowered bus.
54 Oval project
mr. warehouse
PostPosted: Sun Feb 02, 2020 12:27 pm    Post subject: Re: Lowering with T-1 spindels. Reply with quote
Correct.
PostPosted: Sun Feb 02, 2020 4:40 pm    Post subject: Re: Lowering with T-1 spindels. Reply with quote
Correct.
I tried to post a photo but the Samba software didn't like toe URL
Post a link without making it an image link with [img]
bally
bally is offline
PostPosted: Mon Dec 21, 2020 1:46 am    Post subject: Re: Lowering with T-1 spindels. Reply with quote
Greg. Are those stock 15" rims with stock tyres? I like the look! I'm wondering if I can run stock 16s with stock tyres on a barndoor lowered with type 1 spindles and tubs? Has anyone done this? I'd live to see some pictures if they have please.
Cheers. Dave
mr. warehouse
PostPosted: Mon Dec 21, 2020 8:25 am    Post subject: Re: Lowering with T-1 spindels. Reply with quote
Cheers. Dave
They are stock 16's with stock tires in the rear and smaller tires in the front.
I've switched it up a bit since that photo. It's now running a hybrid dropped spinde setup with 16x5.5's and low profile radials.
I was waiting on tires when I took this photo
Fronts on, still tweaking the rear.
My point being, if you're looking for stock tires. I have the stock rears and smaller front that were on this single cab earlier. I may even have 4x stock sized tires available.
bally
bally is offline
PostPosted: Mon Dec 21, 2020 6:54 pm    Post subject: Re: Lowering with T-1 spindels. Reply with quote
Thanks Greg, it looks great on those stock 16s and bias plus. I'm aiming for using coker's new bias look radials. I assume you used the smaller front Tyres to avoid rubbing? The Coker Tyres are about 17mm (3/4") taller than your fronts soba mild tub should sort that out.
Cheers. Dave
mr. warehouse
PostPosted: Mon Dec 21, 2020 10:36 pm    Post subject: Re: Lowering with T-1 spindels. Reply with quote
Cheers. Dave
Correct, smaller front tires to avoid rubbing. My new set up is 6" of bolt-on drop at the spindles. Still a factory VW barndoor beam. I will be doing a minimal tub as well to clear the low profile 16" tires.
mr. warehouse
PostPosted: Wed Feb 16, 2022 7:07 pm    Post subject: Re: Lowering with T-1 spindels. Reply with quote
Last photos before tucking it away in storage and ultimately selling...
Dropped T1 spindles with a 4" narrowed/adjustable "stock" barndoor beam.
The new owner has since finished it off and has been cruising it with no issues. Plenty of photos and videos can be found on IG
johnny d
johnny d is offline
PostPosted: Thu Feb 17, 2022 12:46 am    Post subject: Re: Lowering with T-1 spindels. Reply with quote
sits pretty awesome Greg!
GermanRestoKommando
Der Barndoor Führers - Slamm Society
VWKernzentrale since 2007
bally
bally is offline
PostPosted: Fri Oct 21, 2022 10:12 pm    Post subject: Re: Lowering with T-1 spindels. Reply with quote
What discs are people using with type 1 spindle conversions? Type 1 discs?
Many thanks,
Dave
mr. warehouse
PostPosted: Sat Oct 22, 2022 8:32 pm    Post subject: Re: Lowering with T-1 spindels. Reply with quote
Many thanks,
Dave
Correct.
There are plenty of off-the-shelf 5x205 kits that work.
For 5x130 I use my own kit, as seen here.
bally
bally is offline
PostPosted: Sun Oct 23, 2022 3:31 am    Post subject: Re: Lowering with T-1 spindels. Reply with quote
Many thanks,
Dave
Correct.
Thanks Greg. I’m after 5x205 Smile
Page 3 of 3
