canadadude Samba Member
Joined: November 21, 2015 Posts: 41 Location: Regina ,Sasktachewan
Posted: Sat Feb 08, 2020 2:41 pm Post subject: 73 Bay Window Transporter |
H
Recently purchased this 73 Bus ,1700 engine.Complaint was that it was leaking fuel out the bottom.Appears some parts are missing like throttle cable return spring ?Anyone school me on what the round canister with relay on it and the fuel lines going into it is for?I see where the return spring attaches to the throttle cable but where does the other end hook onto?Looks like the EGR pump is seized are people removing these or what’s best?Thanks! _________________ 66 VW Beetle |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52833 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Feb 08, 2020 3:34 pm Post subject: Re: 73 Bay Window Transporter |
Wow!, that's a really clean and original looking bus! (for the most part).
The throttle spring attaches to a hole in the reinforcement rib in the engine compartment roof, there's a little square plastic ferrule in the hole.
The canister is an Eberspacher BN-4 gas heater, score!
There's not many running a smog pump these days, makes a great decoration though. (the EGR is another system under the engine on the left and then along the firewall to each manifold). _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Feb 08, 2020 3:39 pm Post subject: Re: 73 Bay Window Transporter |
Wow forgot all about the heaters on some these VW!So if I remove the air pump can I remove EGR valve and hoses and plug everything?I will have to go look for the spring hook up. Thanks a lot for the response and great answers to my questions! _________________ 66 VW Beetle |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42625 Location: at the beach
Posted: Sat Feb 08, 2020 3:46 pm Post subject: Re: 73 Bay Window Transporter |
smog pump injected air into the exhaust stream at the heads to assist in burning any CO into CO2, and HC into H20 and CO2. The technology in general was replaced with catalytic converters. EGR injects burned gases that have no oxygen left into the intake. It maintains the compression ratio but lowers combustion temperature to reduce NOX.
Might look at the manufacturer date - could be a 1974. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin
Yes, you can remove the afterburner system and the EGR system as well, you'll have to plug the holes in the heads for the afterburner pipes and cap the manifolds and exhaust where the EGR connected, you'll also need a 72 style crossover pipe for the central idle system (no takeoff for the afterburner pump).
Try to take it off nicely, some day you may want to have all the correct parts. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent  Samba Member
Posted: Sat Feb 08, 2020 4:00 pm Post subject: Re: 73 Bay Window Transporter |
I'd go slowly on that bus. It looks pretty clean and you may want to think thru any changes. Even the paint looks like it may buff out.
There are things like the nut on the oil strainer that if tightened by hand too tight can destroy the engine instantly. 9 ft lbs only. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Posted: Sat Feb 08, 2020 4:05 pm Post subject: Re: 73 Bay Window Transporter |
Ya the original owner had it all undercoated and it’s falling off now but underneath is beautiful .Maybe I will inspect the seized air pump and leave that system on there.I found the plastic insert where the return spring connects just need to find a proper spring now. _________________ 66 VW Beetle |
honestcharlie56 Samba Member
Joined: September 24, 2017 Posts: 87 Location: Houston, Tx
Posted: Sat Feb 08, 2020 4:15 pm Post subject: Re: 73 Bay Window Transporter |
Wow, what a hell of a score. _________________ 1982 Vanagon Westy
1974 Transporter
1971 Tin Top Westy |
rustbus Samba Member
Posted: Sat Feb 08, 2020 5:37 pm Post subject: Re: 73 Bay Window Transporter |
Looks super great, wish something like that would fall in my lap.
And is this a Saskatchewan bus?? Thats Wild if so.
Maybe the driver side and nose has been repainted or am I tripping?
Care to share about how it came to be in your possession? I like these kinds of stories, gives me a false sense of hope that more of them are out there in my long lost family members shed. _________________ May of '72 Deluxe. 2.0L L-Jet CS & 091 trans conversion
my Bus thread |
Posted: Sun Feb 09, 2020 7:18 pm Post subject: Re: 73 Bay Window Transporter |
Yes bus was sitting in Regina parked for 11 years.The previous owner had young family and no time to get it on the road.Hopefully be ready to fire it up next weekend .Takes some time figuring out some of the things like the vacum lines.Eventually install a lowered adjustable front beam and lower the rear somehow! _________________ 66 VW Beetle |
Vee Dub Nut Samba Member
Joined: April 25, 2004 Posts: 1196 Location: Dallas, GA
Posted: Mon Feb 10, 2020 10:15 am Post subject: Re: 73 Bay Window Transporter |
canadadude wrote: |
Yes bus was sitting in Regina parked for 11 years.The previous owner had young family and no time to get it on the road.Hopefully be ready to fire it up next weekend .Takes some time figuring out some of the things like the vacum lines.Eventually install a lowered adjustable front beam and lower the rear somehow! |
Great looking Bus!
Just be warned, your going to get some hate around here for lowering it. But absolutely go for it! I've got full Wagenswest slam bay on my 74, and it rides fantastic. _________________ Fightin' Texas Aggie Class of 2006
67 Beetle (TBD)
74 Transporter (EJ25 Swapped) - Build Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
See all my VW pics on Instagram @ vee_dub_nut |
Posted: Mon Feb 10, 2020 10:36 am Post subject: Re: 73 Bay Window Transporter |
Thanks I won’t be chopping anything and keeping original parts around so it could go back to stock anytime ! _________________ 66 VW Beetle |
Posted: Sun Feb 16, 2020 2:36 pm Post subject: Re: 73 Bay Window Transporter |
Anyone know what wire supposed to be hooked to this connection _________________ 66 VW Beetle |
SGKent  Samba Member
Posted: Sun Feb 16, 2020 3:38 pm Post subject: Re: 73 Bay Window Transporter |
no hate - the value of that bus is in its originality -it is a once is a decade find based on your photos. Cleaned, waxed, any rust taken care of, worn out parts restored you may have a $35K bus. Lowered and tweaked its a $16K - $18K bus. You do the math. I wish I was rich enough to be able to throw $15K-20K in the fireplace on a whim just to see what it looked like burning. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
KentABQ  Samba Member
Joined: September 11, 2016 Posts: 2483 Location: Albuquerque NM
Posted: Sun Feb 16, 2020 4:43 pm Post subject: Re: 73 Bay Window Transporter |
canadadude wrote: |
Anyone know what wire supposed to be hooked to this connection |
That is just a ground connection.
Ground wires are brown, so look for one laying around.
If not, the wire may have been be rerouted to some other ground. |
Posted: Sun Feb 16, 2020 4:46 pm Post subject: Re: 73 Bay Window Transporter |
canadadude wrote: |
[pic]
What are we discussing?. the coiled up blueish wire in the background?, the spade terminal peeking out from behind the fuse holder?, or something on the fuse holder? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Feb 16, 2020 4:47 pm Post subject: Re: 73 Bay Window Transporter |
Spade terminal beside fuse holder _________________ 66 VW Beetle |
SGKent  Samba Member
Posted: Sun Feb 16, 2020 5:01 pm Post subject: Re: 73 Bay Window Transporter |
it would be brown whatever it is because that is a ground. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Posted: Sun Feb 16, 2020 5:09 pm Post subject: Re: 73 Bay Window Transporter |
It's for test network terminal #17 (trans ground strap condition), it'll be a brown/white wire most likely. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Feb 16, 2020 5:27 pm Post subject: Re: 73 Bay Window Transporter |
I’ll have to look some more didn’t see that color of a wire near there,but I do have some wires near battery that weren’t used and taped all up.The brass fitting for the distributor advance is snapped off also so I will have to drill that out.Does anyone know what the threaded hole is for on side of carb?It appears to have no hole inside there but just not sure if I can’t see it?
