Deanaha Samba Member
Posted: Mon Feb 17, 2020 6:20 am Post subject: Battery Box |
Does anyone have their battery in a protective box so the seat coils do not touch the battery? I am looking for an idea of battery box but can not find one that fits my battery and is not too tall since the battery is under the driver's seat |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21521 Location: Oklahoma City
Posted: Mon Feb 17, 2020 7:40 am Post subject: Re: Battery Box |
Deanaha wrote: |
Thought about lt that many times...but came to the same issues with commercially available boxes.
However....if you have the correct battery and are using the proper connector cover....I have never had an issue. Its supposed to look and work similar to the red cap on the battery in this autozone add. It typically has 3 legs that fit into holes.
https://m.autozone.com/batteries-starting-and-char...a/516423_0
But....what I will be adding....is a sheet of thin, chemical proof, tough, dielectric plastic that can be zip tied to the seat springs to keep any oddities from happening.
If you go to Wal Mart....look in the Kitchen department. They have packs of 4 of these polypropylene "cutting matts" or sheets. They are about .015"-.020" thick (they vary a little) very flexible....are made of polypropylene....which is chemical proof all the way up through nitric acid.....pretty damn high dielectric capability.....which they should be because the battery case is made of glass filled polypropylene. Same material without the glass filling.
https://www.walmart.com/ip/Mainstays-Color-Flexible-Cutting-Mat/20531370
Three sheets to a pack (used ro be four) 15.75" x 13.25".....they list 0.002" thick....but that is a typo....one too many 0's. I just measured one my current ones are about .017". I use a lot of these at work as chemical proof mixing sheets and barrier sheets. Ray |
vwrenault Samba Member
Posted: Mon Feb 17, 2020 11:49 am Post subject: Re: Battery Box |
I moved my battery to the rear passenger side behind the seat but not for everyone I also put race trim seats in to . |
Posted: Mon Feb 17, 2020 4:13 pm Post subject: Re: Battery Box |
Thank you, Ray, an excellent idea! |
Lars S Samba Member
Posted: Tue Feb 18, 2020 10:44 pm Post subject: Re: Battery Box |
Good idea to ensure the + pole is well protected!
I had the backrest wire end come lose under the drivers seat in my 411, it hit the + pole and within seconds the seat was on fire
Luckily I could quickly get a bucket of water...
Lars S
_________________ Porsche 914 -72, Bahia Red daily driver
VW411 2-d -70, White, sold
VW412 4-d, -73, Gold Metallic, daily driver
Suzuki T500, -69, Candy Gold, sold
Suzuki K50, -77, Black, daily driver
BMW R69S -69, White, sold
Husqvarna 118cc, -47, Black, Sold |
Posted: Wed Feb 19, 2020 4:52 am Post subject: Re: Battery Box |
The flexible cutting boards from Walmart are not in store. But can find them at Amazon or Tuesday Morning or Walmart online. An update. |
Posted: Wed Feb 19, 2020 7:15 am Post subject: Re: Battery Box |
Deanaha wrote: |
Check more than one Walmart. I have the same issue. Some stores stock them and some do not. If not....even plastic supply houses have stocks of sheet goods for polypropylene and either high density polyethylene or UHMW polyethylene (this last one is slightly less flexible). Ray |
Racing Dreamz Samba Member
Joined: August 02, 2016 Posts: 34 Location: Mountain City, Tn.
Posted: Tue Mar 10, 2020 12:31 pm Post subject: Re: Battery Box |
How does the driver's seat lift up to get to battery? Having an issue with this. |
Lars S Samba Member
Posted: Tue Mar 10, 2020 12:35 pm Post subject: Re: Battery Box |
Posted: Tue Mar 10, 2020 3:15 pm Post subject: Re: Battery Box |
Found it. THANKS!!! |
