[CHASSIS] Frame Head Replacement Jig
matumorales
matumorales is offline
PostPosted: Thu Oct 17, 2019 6:31 am    Post subject: [CHASSIS] Frame Head Replacement Jig Reply with quote
Hello;
I'm in the process of replacing the frame head of my 1966 type-1 sedan. some previous owner did a lousy job on replacing it and I'm sure this has to be revisited. It's begining to rot anyways and I plan to do the entire frame restoration for good.
However, I realize this is a delicate intervention, and I know that there was a jig blueprint available online some time ago, however, I can't find it anywhere now (small picture of it is attached)
There was also a complete workshop manual in finnish dedicated to the replacement of this component... does somebody still has this .pdf document?
Can somebody give me a hand locating these?
tzepesh
tzepesh is offline
PostPosted: Thu Oct 17, 2019 6:49 am    Post subject: Re: [CHASSIS] Frame Head Replacement Jig Reply with quote
I would be interested in the same topic, but for Super frame head replacement.
'74 1303S, L98B Viperngrun (extra glitter), German Look
'64 1200, Sea Blue, under restoration
benchracer1
benchracer1 is offline
PostPosted: Thu Oct 24, 2019 1:10 pm    Post subject: Re: [CHASSIS] Frame Head Replacement Jig Reply with quote
a while back, maybe a year, hot vw mag had the blueprint for making this tool
tzepesh
tzepesh is offline
PostPosted: Fri Oct 25, 2019 12:56 am    Post subject: Re: [CHASSIS] Frame Head Replacement Jig Reply with quote
I tried to contact Hot VWs Mag but there is an issue with the contact form (it does not accept my address no matter what I write in). Hopefully we can get some more info here.
67rustavenger
67rustavenger is offline
PostPosted: Sat Oct 26, 2019 5:29 am    Post subject: Re: [CHASSIS] Frame Head Replacement Jig Reply with quote
Here ya go,
https://www.thesamba.com/vw/archives/manuals/local_manufacture/670a.jpg
https://www.thesamba.com/vw/archives/manuals/local_manufacture/670b.jpg
https://www.thesamba.com/vw/archives/manuals/local_manufacture/670c.jpg
Always search the archives. When looking for VW related tools.
Good Luck.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
tzepesh
tzepesh is offline
PostPosted: Sat Oct 26, 2019 10:38 pm    Post subject: Re: [CHASSIS] Frame Head Replacement Jig Reply with quote
Hm, I never can navigate to that section in archives unless I have a link.
Anyway, I did not find a similar tool for Superbeetle frame head. Is there one?
67rustavenger
PostPosted: Sun Oct 27, 2019 10:13 am    Post subject: Re: [CHASSIS] Frame Head Replacement Jig Reply with quote
I tried searching for the tool that you are looking for. The only reference I could find was in a tool catalog. But there was no image.
FYI, when you look at the tools list. Read the instructions. They tell you how to navigate that section of the samba archives.
Good Luck.
Buy Once, Cry Once!
tzepesh
tzepesh is offline
PostPosted: Sun Oct 27, 2019 12:04 pm    Post subject: Re: [CHASSIS] Frame Head Replacement Jig Reply with quote
Thanks for the hint on how to look in the calaog tool. I was looking under Archive instead of Technical. What was the tool number in the catalog, because I still can not find it.
Dibaltic
Dibaltic is offline
PostPosted: Sun Oct 27, 2019 1:05 pm    Post subject: Re: [CHASSIS] Frame Head Replacement Jig Reply with quote
VW 670 is the name of the tool. It says it on the blue print and the other links that 67rustavenger linked.
When you are in the technical tool listing section you click on the hyperlink to Page 7 (600 series) to find this specific tool.
tzepesh
tzepesh is offline
PostPosted: Sun Oct 27, 2019 11:05 pm    Post subject: Re: [CHASSIS] Frame Head Replacement Jig Reply with quote
I was asking for the tool number for superbeetle frame head jig. The one without pictures. 670 is the one for beam frame head.
tzepesh
tzepesh is offline
PostPosted: Mon Feb 17, 2020 1:47 am    Post subject: Re: [CHASSIS] Frame Head Replacement Jig Reply with quote
A friend sent me a body repair workshop manual which covers Super Beetles also. There is a pic of a frame jig used for frame head replacement. However there are no dimensions on it. Does anybody have more detailed information on this tool?
VeeDee
VeeDee is offline
PostPosted: Mon Feb 24, 2020 4:18 pm    Post subject: Re: [CHASSIS] Frame Head Replacement Jig Reply with quote
I have access to VW/Sonner jig, similar to the one above, with interchangeble front parts for both frame heads. It is very easy to use and is the way for best results.
Unfortunatly for you, my workshop is in Wolfsburg, Germany.
Sometimes these jigs are offered here in Germany on "ebay" or "ebay-kleinanzeigen" for reasonable prices. But be aware: The jig doesn't do the job alone. Only try to change a frame head if you are a well trained welder! And very often you will need more than a frame head to fix the center of your chassis.
Tvättbjörn
Tvättbjörn is offline
PostPosted: Mon Feb 24, 2020 11:06 pm    Post subject: Re: [CHASSIS] Frame Head Replacement Jig Reply with quote
matumorales wrote:
Hello;
If you are having a second straight pan , you are better of to make your own jig based on that pan and transfer it onto your damaged / bad repaired pan and replace the head than. Even if you have a blue-print you never know if the measurements are correct.
If the frame head is not installed the way it has to be - you are in big trouble on a beam front end. Super beetle head frames are more forgiving since it does not carry a axle beam, but it has to have the correct height to bolt onto the body.
I made my own jig that way back in the 90's, because it was almost impossible to get the factory jigs and frame bench at a decent price. It was always rust damage repair and Klokkerholm had nice replacement frame heads for Super Beetles back than.
The picture shown with the beam installed is the way I did. I just had a different mounting frame style.
tzepesh
tzepesh is offline
PostPosted: Mon Feb 24, 2020 11:36 pm    Post subject: Re: [CHASSIS] Frame Head Replacement Jig Reply with quote
VeeDee, it would be so good to have the measurements of such a jig. The plans are nowhere to be found, and even if it is a proprietary tool, I think that it hasn't been on production for decades. But I realize that is a big task, worth a few hours. However it would help so many restoring their cars. For the beam front end there is a tool with dimensions, but the jig would make it even easier.
In my case, I am pretty good with welding. more than 10 years ago I changed the frame head on my 1303, but I did not have a jig or dimensions. I measured the old bent frame head and tried to use references from the pans. It is centered, but slightly bent down. I would like to correct this now.
Tvättbjörn
PostPosted: Tue Feb 25, 2020 9:12 pm    Post subject: Re: [CHASSIS] Frame Head Replacement Jig Reply with quote
how much is it off? How many mm?
tzepesh
tzepesh is offline
PostPosted: Wed Feb 26, 2020 12:43 am    Post subject: Re: [CHASSIS] Frame Head Replacement Jig Reply with quote
At the Napoleon hat it is at the correct position, but the front of the frame head is down by maybe 10mm. It is not bent sideways, I measured that several times during welding. But somehow the vertical coordinates were not good. Also, I did not have the body on to guide it, and I wouldn't have relied on it because it was bent from an accident (I can just guess that the car was rolled some time, it had the roof on the left side hammered, and the complete front end was crooked).
I have these two pictures to help me, but a jig would make it so much easier and I would have more confidence. I would spend the time to build a jig if I had the dimensions. Problem is that in the second pic, the back looks like the torsion bars housing tubes, but the front looks like the body not the chassis. It puzzles me what I have to measure. I think this mislead me when I did it. I do not understand if dimension A-7 11/16 is to the top or bottom of the frame.
Tvättbjörn
PostPosted: Wed Feb 26, 2020 10:54 pm    Post subject: Re: [CHASSIS] Frame Head Replacement Jig Reply with quote
Datum line is the top of the straightener frame (Richtbank in German). Measurements are from the top of the straightener frame to the lower side of the chassis / platform because the chassis sits usually on jigs and that is how the measurements are taken.
tzepesh
tzepesh is offline
PostPosted: Thu Feb 27, 2020 12:19 am    Post subject: Re: [CHASSIS] Frame Head Replacement Jig Reply with quote
Thank you! That can help me a lot. It was strange how the back end was drawn as the chassis with torsion bars housing and transmission frame horns, and the front with body like sketch. I was mislead that the left side of the drawing would be to the bottom of the body (so top of the frame head)...
So it seems the frame head is actually a bit tilted up.
Then, I guess I have every measurement I need to make a jig or align the chassis properly.
Tvättbjörn
PostPosted: Thu Feb 27, 2020 9:43 am    Post subject: Re: [CHASSIS] Frame Head Replacement Jig Reply with quote
Since only one side of your frame head sits 10mm too low I would use your pan as a rough guide just to see how all the other measurements on the paper turn out. It does not look like VW information and you never know. Good luck.
tzepesh
tzepesh is offline
PostPosted: Thu Feb 27, 2020 11:54 pm    Post subject: Re: [CHASSIS] Frame Head Replacement Jig Reply with quote
I will measure everything before cutting and refitting. But everything was lined up well per measurements and body (at least till splash panel). Anyway I can only measure from fixed chassis points, not from the floor holes, because I also swapped them at that time and I am quite sure they were not the best fit.
