Engine number sequence and what would be correct
latinporsche911
latinporsche911 is offline
PostPosted: Tue Mar 03, 2020 3:31 pm    Post subject: Engine number sequence and what would be correct Reply with quote
I have a November 56 oval (57 bug).
Base on the body and chassis numbers: Body was made around 2nd week of month and Chassis was made around 4th week. Its a matching body and chassis due to the vin plate up front.
Engine is February... so wrong one.
My Question is: What approximate engine number would correspond with this bug? Would it be around 2nd week - 3rd week or 4th week?
Not being picky, but if a few options are available, then why not chose something close enough.
Thanks for your help and input
Also, I use to assume that the quantity of bodies, chasis and engines would have been pretty close in quantity per month. But having checked the numbers for November 56, there were: (if my math is correct).
26761 Bodies
30167 chasis
36,950 engines
Other than verts (But where did those bodies come from) I can assume some chasis and engines were used for the convertibles. But what about the rest of engines or chasis.
Just curious.
Thanks
PostPosted: Tue Mar 03, 2020 3:52 pm    Post subject: Re: Engine number sequence and what would be correct Reply with quote
I can't speak to Ovals specifically but on other cars I have seen with original engines, the engine # matched up within the same week as the VIN/Chassis #.
latinporsche911
PostPosted: Tue Mar 03, 2020 4:19 pm    Post subject: Re: Engine number sequence and what would be correct Reply with quote
Ah ok...
Thanks Everett... Helps me narrow the search.
Best
R
PostPosted: Tue Mar 03, 2020 10:26 pm    Post subject: Re: Engine number sequence and what would be correct Reply with quote
Honestly if you find the same month I think that is good but I wouldn't really want an engine from late in the month if you have something from early.
Since you say the chassis # is from the 4th week you have some leeway.
Check out these 2 threads too and see if they mention the chassis # and engine # to see how they fall in the charts on the site:
https://www.thesamba.com/vw/forum/viewtopic.php?t=419739
https://www.thesamba.com/vw/forum/viewtopic.php?t=571100
latinporsche911
PostPosted: Tue Mar 03, 2020 11:38 pm    Post subject: Re: Engine number sequence and what would be correct Reply with quote
Ok....
I'd figured anything during third week or early 4th week would be ok.
Thanks for the links and advice
R
