Engine case corrosion?
jbillow
jbillow is offline
PostPosted: Sat Mar 07, 2020 9:29 pm    Post subject: Engine case corrosion? Reply with quote
Has anyone seen this before? Any thoughts on if it’s toast or how I could repair it?
jimmyhoffa
jimmyhoffa is offline
PostPosted: Sat Mar 07, 2020 9:33 pm    Post subject: Re: Engine case corrosion? Reply with quote
I'd say that might be close to a goner, if not a goner. I had some minor corrosion of a very similar style, just less advanced. I made surfacing tool to level it, and did what I could. In addition, instead of using m6 studs, I through-bolted from the inside of the case with a longer m6 bolt, just so the "case meat" was sandwiched between the bolt head and sump plate.
You can kinda see my "bolt-studs" in the lifter picture
1974 Chenowth 2RL #1244 Street Legal
My other car isn't ridiculous.
RWK
RWK is offline
PostPosted: Sat Mar 07, 2020 9:51 pm    Post subject: Re: Engine case corrosion? Reply with quote
got one worse then that ! caused by moisture, from oil not burning it off, forming acid, or just condensation and water getting in engine, water is heavier goes to bottom, why you should change oil every year even if it's not run, especially in damp climates.
73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530
jbillow
jbillow is offline
PostPosted: Sat Mar 07, 2020 9:57 pm    Post subject: Re: Engine case corrosion? Reply with quote
thanks for the reply, any idea what caused this?
jbillow
jbillow is offline
PostPosted: Sat Mar 07, 2020 10:05 pm    Post subject: Re: Engine case corrosion? Reply with quote
car had been sitting for several years before I got it, cylinders were froze so was/am in the process of rebuilding and found this. I'm thinking of making some metal split gaskets placing one inside with bolts through holding each half in place and one on the outside and filling void with JB weld. Am I nuts?
bugguy1967
bugguy1967 is offline
PostPosted: Sat Mar 07, 2020 10:20 pm    Post subject: Re: Engine case corrosion? Reply with quote
Try it, let us know how it goes. Did you ask this on FB? If so, it seems like you just want one confirmation to do what you know you already want to do. It will probably seal. Go for it.
"A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine"
jbillow
jbillow is offline
PostPosted: Sat Mar 07, 2020 10:50 pm    Post subject: Re: Engine case corrosion? Reply with quote
Don't know why you have that impression bugguy, and why I would ask on FB is beyond me. But thanks for your informed response.
mukluk
mukluk is offline
PostPosted: Sun Mar 08, 2020 12:37 am    Post subject: Re: Engine case corrosion? Reply with quote
https://www.thesamba.com/vw/forum/viewtopic.php?t=505703
txoval
txoval is offline
PostPosted: Sun Mar 08, 2020 6:20 am    Post subject: Re: Engine case corrosion? Reply with quote
Yes, see link above, it has been done several times before.
If you can afford the Belzona product, it would be better, but it’s about $200 for the same amount as a $6 JB Weld package
jbillow
jbillow is offline
PostPosted: Sun Mar 08, 2020 11:52 am    Post subject: Re: Engine case corrosion? Reply with quote
thanks guys
bugguy1967
PostPosted: Mon Mar 09, 2020 8:30 pm    Post subject: Re: Engine case corrosion? Reply with quote
There are a lot of specific VW groups on FB and someone asked that same question as soon as you posted this. It also looked the same as your pics. Just a coincidence...
