VanagonPDX Samba Member
Joined: April 25, 2012 Posts: 114 Location: Portland Oregon
Posted: Sat Mar 21, 2020 6:54 am Post subject: Vanagon Cabinets 3.0 |
Third van, third time making cabinets. After pulling up the piece of linoleum laid down by the PO, my father, I found that there was a fair bit of mold and water damage to the original cabinets. The leak was coming in sliding middle window, above the kitchenette, and was running inside the wall and under the flooring. At that point I knew it was time for a full renovation. Gutted the interior, had the holes welded up, insulated the walls, and began cabinet build 3.0.
My last van had a somewhat similar design, but different construction method, and was written about here: https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= The last set were one width fron to back, where as the new set juts out in front of the bed to accommodate the Engel 45. This is the final outcome of that cabinet build:
Here are some photos of the most recent build. All of which is built out of 5/8", 1/2", and 3/8" European spec Birch plywood. I used thinner where I could get away with in order to shave weight here and there.
Original cabinets being removed
Image of the carpet condition
Floor trimmed in aluminum to protect the edges.
The first box to be made was a replacement for the westy bed.
Posted: Sat Mar 21, 2020 7:01 am Post subject: Re: Vanagon Cabinets 3.0 |
The European Baltic Birch has a more veneers per sheet, less voids, and nice thick veneers for the faces, as opposed to a thin sheet.
Building the kitchenette box.
Drilling holes for fridge ventilation as well as a little weight reduction.
Particularly proud of this little joint that runs along the top of the middle cabinet.
More cutouts for weight cuts, plus these allow me to see into the water tank.
hdenter Samba Member
Joined: October 14, 2008 Posts: 2966 Location: San Luis Obispo, CA
Posted: Sat Mar 21, 2020 8:44 am Post subject: Re: Vanagon Cabinets 3.0 |
WOW! Impressive! I'd love to see more pictures of the build. I have some cabinet ideas that involve similar elements to your frig set up. What brand/weight capacity of drawer slides did you use and what kind of locking mechanism will keep yours from sliding out while driving?
Hans _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10524 Location: Sunshine Coast B.C.
Posted: Sat Mar 21, 2020 8:57 am Post subject: Re: Vanagon Cabinets 3.0 |
Thanks for sharing and showing those details. Nice looking work!
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN |
Posted: Sat Mar 21, 2020 9:10 am Post subject: Re: Vanagon Cabinets 3.0 |
| hdenter wrote: |
Hans |
Thank you! The slides are just the ball bearing slides from Home Depot, so rated at 100lbs. Fridge with food should be less than that, but may opt to purchase some heavier duty slides with the locking mechanism built in. These are just what I had handy.
Currently, I have a slide latch in place that goes into the platform to keep it from moving. |
Posted: Sat Mar 21, 2020 9:11 am Post subject: Re: Vanagon Cabinets 3.0 |
| Vanagon Nut wrote: |
Neil. |
Thank you Neil! This is my third time every making cabinets, and each time they look significantly different in their construction method. |
jimf909 Samba Member
Posted: Sat Mar 21, 2020 9:51 am Post subject: Re: Vanagon Cabinets 3.0 |
Beautiful! I love seeing good ideas executed well. It also looks like you kept things fairly simple and effective.
Was the water tank a custom build or did you find one that fit perfectly? Where did it come from, a marine tank provider? _________________ - Jim
| Butcher wrote: |
| This is the main fault with DIY'ers, they get together on these forums and pat themselves on their backs spreading bad information. |
Guilty as charged.
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12177 Location: Port Manteau
Posted: Sat Mar 21, 2020 11:53 am Post subject: Re: Vanagon Cabinets 3.0 |
Has anyone here used this software to design an interior layout?
https://vanspace3d.com/home-v3d
Crank up the headphones for the groovy musak _________________ Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE. |
RoryGirl Samba Member
Joined: October 14, 2016 Posts: 1018 Location: WestWorld Nanaimo BC
Posted: Sat Mar 21, 2020 12:08 pm Post subject: Re: Vanagon Cabinets 3.0 |
The toilet is through the well and into the wheel in that video  _________________ 1991 Twin Slider VR6
1985 Audi 4k |
SCM Samba Member
Joined: January 26, 2011 Posts: 3483 Location: Bozeman MT
Posted: Sat Mar 21, 2020 1:37 pm Post subject: Re: Vanagon Cabinets 3.0 |
I’ve been putting off a pantry remodel at my house. Are you passing through Montana any time soon? _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Posted: Sat Mar 21, 2020 8:09 pm Post subject: Re: Vanagon Cabinets 3.0 |
| jimf909 wrote: |
Was the water tank a custom build or did you find one that fit perfectly? Where did it come from, a marine tank provider? |
Thank you for the kind words. Definitely trying to keep things simple and light as possible.
The van was originally an ASI Riviera, so the water tank that I used is the one that it was originally built with, so is custom shaped to fit the contours of the firewall. |
Posted: Sat Mar 21, 2020 8:11 pm Post subject: Re: Vanagon Cabinets 3.0 |
| SCM wrote: |
| I’ve been putting off a pantry remodel at my house. Are you passing through Montana any time soon? |
Haha, depending on how this Coronavirus thing pans out, we may hit the road in search of new employment  |
erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
Posted: Sat Mar 21, 2020 8:45 pm Post subject: Re: Vanagon Cabinets 3.0 |
Really nice work! I've been following along on IG but it's nice to see the detail and pics here. Thanks for sharing.
How is the cabinet anchored to the van?
Are you planning to build out more storage at the hatch end? |
Posted: Mon Mar 23, 2020 5:47 pm Post subject: Re: Vanagon Cabinets 3.0 |
| erste wrote: |
Yeah, building a base cabinet now to take up that rear third, next to the bed. Going to do bypass sliding doors so I can access the contents without having to swing anything outward towards the bed. There is now a divider panel halfway to add support to the countertop. Once this is done, I will begin building a small cabinet that sits on top with cubby holes. The top of that cabinet will also, likely, house my solar charge controller. (it will also hide the ugly torn headliner.)
Posted: Mon Mar 30, 2020 6:23 pm Post subject: Re: Vanagon Cabinets 3.0 |
Got around to painting this weekend, as well as building the upper cabinet in the back. I originally had planned, and built, a little cubby, but found it to feel awkward size wise. Went bigger, and am currently happy with that choice. The panel on the upper cabinet will hinge from the bottom, making a small table perfect for watching a movie in the back.
erste Samba Member
Posted: Mon Mar 30, 2020 6:34 pm Post subject: Re: Vanagon Cabinets 3.0 |
Love the color.
thanks for sharing the build! |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8549 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Tue Mar 31, 2020 5:20 am Post subject: Re: Vanagon Cabinets 3.0 |
Likewise! Beautiful work!
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Tue Mar 31, 2020 6:23 pm Post subject: Re: Vanagon Cabinets 3.0 |
| erste wrote: |
Love the color.
Thank you, happy with the color choice... less happy about my choice to go matte finish. Looks cool, but may show dirt a bit too easy. |
| dhaavers wrote: |
- Dave |
Thank you! |
SyncroBouree Samba Member
Joined: August 25, 2017 Posts: 26 Location: Alongside Monterey Bay
Posted: Wed Apr 01, 2020 2:24 pm Post subject: Re: Vanagon Cabinets 3.0 |
So many terrific ideas, well executed! Thank you very much for sharing your ideas and documenting the outcomes.
I'm so glad I didn't see this thread before I started my camper refresh this past Winter -- I'd never get it completed this year, hihihi. _________________ --Liam
1990 Vanagon GL Syncro Westy VW1.8T Triple-Knobber
1975 911S Widened Turbo/RSR Hybrid
1979 Harley Lowrider -- Donated to a good home
1969 Ford Bronco Half-Cab 351W, Toploader, Dana 44 FE, Detroit Locker, Duffy’s Suspension – wish I still had it
1962 GMC 3/4T Fleetside, V6<-Chevy 409 w/factory headers, Camper/Tow Rig – ditto |
