Tcash Samba Member
Joined: July 20, 2011 Posts: 12846 Location: San Jose, California, USA
Posted: Sun May 19, 2013 9:03 am Post subject: Brake Caliper ID T2 |
To link to this thread
Code: |
[url=http://www.thesamba.com/vw/forum/viewtopic.php?t=556225&start=0&postdays=0&postorder=asc&highlight=]Brake Caliper ID T2[/url] |
With the information available at the time of writing. What I can surmise is as follows.
1971 started out with a small caliper, 12mm mounting holes and 1 bleeder valve, that when mounted bleeder must be on top.
Sometime in 71 they retained the small caliper, 12mm mounting holes but installed two bleeder valves.
1972. 12mm mounting holes with 2 bleeders. Small calipers.
1973-79 larger calipers, 14mm mounting holes and 2 bleeders.
Two manufacturers were available.
ATE 1973-75
GIRLING 1976-79
Note: check your calipers before ordering parts because both will fit 1973-79.
Brake pads are the same for both the ATE and Girling.
Note that these parts are different.
#8 Retaining pin note: girling 8a retaining spring (hairpin), ate uses an expanding collar to hold the Retaining pin in place.
#6 Retainer
#7 Spreader spring
#20-21
It has been reported that VW was known to use up the parts from the previous year. Model year changes occurred in Aug. So if you have a build date close to Aug. check to see if you have the earlier parts.
VdubEngineering. Allows the fitment of more common and economical 74-79 disks/hubs/calipers on 71-72 spindles.
How to identify GIRLING and ATE calipers.
Refer to the parts diagram above. ATE #8, Girling #08 and #8A
#8 ATE Brake pad Retaining pin 73-79 prt 211 615 261 A
Note the little round split compression ferrule on the end. This is what holds the pin in the caliper.
ATE Note the brake pad retaining pin uses a compression furrel to retain the retaining pin.
Girling (Note the Hairpin cotter pin) that retains the Brake pad retaining pin. This identifies it as a Girling caliper.
This One's a Girling later Bay. Note: 14mm mounting holes.
Notice the 14mm mounting holes.
This piston retaining plate is from a Girling caliper. Arrow points in the direction the wheel travels.
71 Caliper
71 ATE notice the 12mm mounting holes.
Note wear the brake line attaches looks like a cows head.
71 bay window
71 only Ate Bus calipers
[/quote]
72 Bus calipers. Early 71 had smaller 12mm mounting holes and the single bleeder. In mid -'71 they installed 2 bleeders.
Note: 14mm mounting holes and two bleeder valves.
Tcash Samba Member
Posted: Sun May 19, 2013 9:04 am Post subject: |
Moved Down
Tcash Samba Member
Posted: Sun May 19, 2013 9:05 am Post subject: CSP Disc Brakes |
Tcash wrote: |
Posted in 2008
Rwheeler wrote: |
Installed a set of CSP Disc brakes from Wolfsburg West. Started yesterday and finished this afternoon. Vey high quality kit from Germany. And expensive at $1,400 bucks!
Go to the galley under baywindow campers and I'll have some pics there in a few minutes. |
Tcash Samba Member
Posted: Sat Oct 26, 2013 4:00 pm Post subject: 73 Calipers |
73 Caliper exploded view. Note wave washers for the mounting bolts are not present. Also one bolt is a shoulder bolt and the other is a threaded bolt. I think this is not by design but rather one of the bolts was from another vehicle?
73 Piston Locating plates
73, note wave washers present, retaining pins have compression retainers to locate the pins.
73 Piston Locating plate on piston illustration.
73 Piston Locating plate on caliper illustration.
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 4087 Location: Seattle, WA
Posted: Sat Oct 26, 2013 4:23 pm Post subject: |
Nice clear photos! W/regard to shoulder bolts, I believe they were
used on all the bus/vanagon calipers, from the very beginning. I've also seen (in a shot of some VW service literature posted right here in this forum) that they appeared at both the top and bottom position at various points in time. The latest Brazilian ATE calipers for late bays have but a single bleeder screw. _________________ '67 bug: seized by the authorities
Tcash Samba Member
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8586 Location: All Across The Country
Posted: Tue Jan 28, 2014 10:42 am Post subject: Re: 14 mm caliper mounting bolts |
Tcash wrote: |
Thanks kreemoweet, forgot about this.
12mm shoulder bolts go on top. |
I just posted elsewhere on this that the early disk brake buses had smaller calipers with 10mm thick pads and 12 mm bolts with the shouldered ones on the bottom. They torque to 94 ft/lbs.
The '73 models on up were supplied with larger calipers that take 14mm thick pads, 14mm bolts with the shouldered ones now installed on the top. They torque to 103 ft/lbs.
The shims with cut-out tabs are used to orient the cut-outs in the piston circle to the bottom (the leading edge of the pads) to reduce squealing.
Colin _________________ www.itinerant-air-cooled.com
www.facebook.com/groups/324780910972038/ |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10797 Location: iT StiNgeD iTseLf tO dEAd
Posted: Tue Jan 28, 2014 12:14 pm Post subject: |
perhaps someone with the yellow late bay service book can find the pics/descriptions and post them? a lot of info in earlier editions of the Bentley manual is not applicable to later model busses.
otherwise, from the 1979 edition Bentley manual. read the text, look at the pic. #15 is the LOCATING BOLT.
Tcash Samba Member
Posted: Fri Jun 06, 2014 9:52 am Post subject: Shoulder bolts and Caliper piston retaining plates |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52731 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Jun 28, 2015 12:04 pm Post subject: |
Has anyone done a side by side comparison of the later ATE seals VS: the early ones?, they are all 54 MM diameter and aside from the width of the casting and the mounting holes they look the same inside, what am I missing? Why 2 different kits offered?
Edit: Nevermind, I just went a blew a late one apart, aside from the piston being 4mm longer there's no difference in the hydraulic or dust seals.
Rockauto here I come, Daddy needs some new dust seals! _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42405 Location: at the beach
Posted: Sun Jun 28, 2015 1:40 pm Post subject: |
my 1971 had ATE style calipers with just pins and no clips. The hardware setup was the same as my 1977 but a smaller caliper. The plates that sat between the piston and pad had the locating tabs. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Ben Middleton Samba Member
Joined: April 11, 2016 Posts: 225 Location: England, UK
Posted: Tue Apr 14, 2020 7:26 am Post subject: Re: Brake Caliper ID T2 |
The pics have unfortunately gone missing from this article.
I have a 1972 model year T2 that was built in August 1971. The front right caliper has two bleed nipples and the front left caliper has one. They both have 14mm bolts.
They are both ATE. The front left is ATE 32 and the front right is ATE 10 3.
Could anyone tell me whether my brake calipers are the 72-79 ones, or are they the earlier models?
Thanks!
EDIT- They are 12mm mounting holes. I guess I have the earlier one  |
ImAddicted Samba Member
Joined: April 24, 2012 Posts: 1199 Location: Unorganized Territory, Maine
Posted: Tue Apr 14, 2020 7:36 am Post subject: Re: Brake Caliper ID T2 |
Reload the page? None of the pics are missing? _________________ 1979 Transporter (sold)
KC1MUR
strfish7 wrote: |
Original condition, which means something different on this forum than anywhere else! |
Posted: Tue Apr 14, 2020 8:50 am Post subject: Re: Brake Caliper ID T2 |
If you have 14 mm bolts, then you have the late 73-79 calipers. The early 71-72 knuckle had 12 mm threads, and
the 14 mm bolts would not fit thru the 71-72 caliper holes.
You really should not rely on vendor descriptions, as many do not seem to grasp the concept of "model years", going
by date of manufacture or something instead.
As noted in a post earlier in this thread, the seals are identical
for all years of bus ATE calipers. The seals are only what most "rebuild" kits contain. I see that one kit contains new
spring washers for the bolts, so that one would be specific to early or late. _________________ '67 bug: seized by the authorities
Posted: Thu Apr 16, 2020 3:08 pm Post subject: Re: Brake Caliper ID T2 |
I bought a the 72-79 kit, although my van was built in August 1971. The outer seals don’t have a metal ring like the originals, is this the same for most kits? |
germansupplyscott Samba Member
Posted: Thu Apr 16, 2020 5:57 pm Post subject: Re: Brake Caliper ID T2 |
Typically only the Girling calipers (which are only used on very late Bay) have the circlip ring that secures the dust seal to the caliper. If you have a '71 with ATE calipers and the dust seals have a ring, that probably means the calipers were repaired at some point, with a non-OEM kit. The Girling dust seals with the circlip tend to fit looser on the caliper, hence the need for the clip. If the dust seals in your new kits fit the caliper snugly - and are not sloppy or wanting to fall off - they are fine to use.
SL |
Joined: January 01, 2007 Posts: 17827 Location: sticksville, ct.
Posted: Thu Apr 16, 2020 9:40 pm Post subject: Re: Brake Caliper ID T2 |
holy fucking shit, is that the ghost of german supply posting? _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Fri Apr 17, 2020 6:53 am Post subject: Re: Brake Caliper ID T2 |
Well that’s interesting- I assumed they were original seals. Very glad I replaced them now. Here is a photo of the old seal and the new:
