blurat Samba Member
Posted: Tue Oct 17, 2017 11:34 am Post subject: Re: 11cent odometer fix |
So, more thought on this. I am assuming if I get a reasonably close diameter rod to push the working axle out of the odo from the GREY gear end, give it a squeeze with my jewelry dikes at point of contact with the gear and re-insert the axle, I will not have to do anything with the nylon gear at the other end as it seems snug right now.
Chris |
blurat Samba Member
Posted: Tue Oct 17, 2017 1:48 pm Post subject: Re: 11cent odometer fix |
OK, pushed the shaft out with a drill bit, came out relatively easily. Put a small crimp, more like a blemish, on the end of the shaft. Upon putting it back in 2 of the numbers moved to halfway in the window.Is there an easy way to straighten the numbers back up? I have been trying for a while now and have no luck.
Thanks
Chris |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1282 Location: Right Here
Posted: Wed Oct 18, 2017 7:48 am Post subject: Re: 11cent odometer fix |
Dikes is what I use to get the gear to hold. Again, making those marks in the wrong portion of the shaft will cause the plastic gears to stick, not good. Making the marks too deep also causes issues getting the shaft thru the gear.
There is no easy way to get the gears to move back to the right position. You're a tooth off and you just got to pull that shaft back out and realign them. |
Bikelamour Samba Member
Posted: Mon Jun 08, 2020 6:37 am Post subject: Re: 11cent odometer fix |
Butcher wrote: |
There is an aluminum gear on the opposite side of the shaft. This gear holds everything in place. If this gear is loose on the shaft two things happen, one the odometer gears do not turn, two the shaft slides out.
It is comical of all the fixes on this shaft coming out issue, but none are fixing the real issue.
Peen the shaft at the location of the aluminum gear. Do not go further than that gear because you will cause the number gears to not to slide on the shaft. |
I have an ‘85 Vanagon, the odometer is not working b/c the aluminum gear is loose as well as the plastic gear of the first digit on the odometer. Which gets hung up on the aluminum gear.. and of course slides the shaft out that the green gear is on...any thoughts on how to secure both the aluminum and first gear to fix this issue.. I have secured the shaft of the gears from sliding but it’s not fixing the real issue..
I was thinking I could place a washer of some sort to hold the spacing? Any thoughts?
89Westy Samba Member
Joined: February 24, 2021 Posts: 11 Location: Garrison, KY
Posted: Wed Mar 31, 2021 2:25 pm Post subject: Re: 11cent odometer fix |
First post since I got back into the Westfalia life 3 weeks ago. Probably could have chronicled my trip home from Portland, OR to Indianapolis with the new Westy, but alas.
Because the eBay seller of this fine automobile was less than honest, I ended up with a van with (among multiple other things, of course) a non-operational odometer.
Anyway, throwing my hat in the ring with this odometer 'hack' and found a slightly more 'stable' bracket (hopefully) utilizing a 'command hook' bought at any walmart/hardware store/home good or office supply store.
My first idea was to use this style hook that the previous owner of my Westy had stuck to one of the cabinets
but i found it was severely lacking in 'support' to attach it to the main housing of the odometer.
i was RIGHT at the point of applying epoxy to it when i had a second thought about PERMANENTLY attaching what is essentially a 'ham & egg' repair to my new friend.
I decided to look at other options and found a hook that the wife had stashed away in a junk drawer
and I got an idea for a mo' betta bracket as seen earlier in this thread
It's lexan plastic and extremely tough for the size/stature...about 10-15 minutes of tedious sanding/test-fitting after I had cut it from the main hook backing, and it was really starting to look like something useable. I sanded both the area that will be making contact with the housing, as well as the area on the top of the 'bracket' so the screw would sit flat on top and not cause any odd torsion issues, and would also have a nice direct line of pressure around the attachment point so it didn't shift in the mounting location.
I utilized one of my 'spare' curtain rod track screws because it's (almost) the perfect length and had just enough bite.
Drilled out the end of the bracket with what I believe ended up being a 3/32" drill bit, and screwed the bracket to the housing. The screw was touching the housing when i put it in all the way, so I took it back out and ground down the tip (just the tip, hah).
And viola!
Ham and egg odometer operation was a success!
Onto the next project...but hopefully minimizing the ham and egg approach moving forward. But when it came down to trying this or spending $225 on a speedo rebuild, I opted to give it a whirl. |
Radim Samba Member
Joined: June 15, 2022 Posts: 1 Location: Prague, Czech Republic
Posted: Wed Jun 15, 2022 7:02 am Post subject: Re: 11cent odometer fix |
Here's another method:
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8411 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Wed Jun 15, 2022 8:00 am Post subject: Re: 11cent odometer fix |
^^^ F’n brilliant…
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
steve244 Samba Member
Posted: Wed Jun 15, 2022 8:23 am Post subject: Re: 11cent odometer fix |
Yeah but when his son sees what he did to his star wars lego set... |
markz2004 Samba Member
Joined: November 13, 2007 Posts: 947 Location: Portland, OR
Posted: Mon Aug 07, 2023 11:03 am Post subject: Re: 11cent odometer fix |
Here's my fix.
I used a medium sized paper binder clip. I broke one of the legs off and then used a pair of tin snips and gently bent the modified leg to fit into position. I notched the metal such that it would fit under the screw.
I'm hopeful I didn't mess up my speedo when I removed/re-installed the needle.
jwallis Samba Member
Posted: Sun Jul 07, 2024 6:50 pm Post subject: Re: 11cent odometer fix |
I have an '84 with a working odometer and I'm wondering if there's preventative maintenance I can do to avoid failure...? _________________ 50+ YouTube videos - brakes, bearings, CV joints, 1.9/2.1 cooling system, mods, Bostig and more... |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 4412 Location: ABQ NM USA.... Except when not
Posted: Sun Jul 07, 2024 8:35 pm Post subject: Re: 11cent odometer fix |
jwallis wrote: |
I have an '84 with a working odometer and I'm wondering if there's preventative maintenance I can do to avoid failure...? |
Know that the early odometer has a metal case that needs different versions of the solutions above. I designed and 3d printed a slide-in retainer for the early odo.
The shaft retainer can be installed before failure to keep it in place. No reason not to do it. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Posted: Sat Jul 13, 2024 8:30 pm Post subject: Re: 11cent odometer fix |
Hey Andy, that odometer part doesn't seem to be on www.supervanagon.com and it doesn't look like you advertise on the samba, what up with that? _________________ 50+ YouTube videos - brakes, bearings, CV joints, 1.9/2.1 cooling system, mods, Bostig and more... |
Posted: Sat Jul 13, 2024 8:58 pm Post subject: Re: 11cent odometer fix |
jwallis wrote: |
Hey Andy, that odometer part doesn't seem to be on www.supervanagon.com and it doesn't look like you advertise on the samba, what up with that? |
its something I just whipped up. you want one printed of the file?
email me direct [email protected]
.....Happenstance I was up late looking at this topic, I don't read everything so could have missed your post. PMs also work OK but email/call is better. I have contact info on the webpage. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
KBM Samba Member
Joined: August 09, 2019 Posts: 8 Location: Vancouver Island BC
Posted: Fri Jun 27, 2025 11:01 am Post subject: Re: 11cent odometer fix |
This great information. Post back to top. $300 plus to get fixed for my 87 2.1 2W _________________ Annie a 87 Vanagon Camper - 2.1 Auto 2W |
Backtotheeightiesagain Samba Member
Posted: Mon Jun 30, 2025 2:16 pm Post subject: Re: 11cent odometer fix |
Make a mould of the shape you need with masking tape.
Fill with GRP filler. File to final shape.
Anyways the bus preferred to be like Joan Collins.
Not get any older/mileage.
Confuses the powers that be =a good thing.
Ps that's the only use for lego apart from inflicting pain on parents bare feet.
I built real cars cheaper than a child built a lego one. |
