Radiator Fan Won't Shut Off
Page: Previous  1, 2
crazyvwvanman
crazyvwvanman is offline
PostPosted: Sun Jun 21, 2020 8:38 am    Post subject: Re: Radiator Fan Won't Shut Off Reply with quote
If your van came with factory A/C then the fan high speed relay is mounted separately to the body of the van above and to the left of the fuse/relay panel.
It is hard to see it.
Mark
damagd
damagd is offline
PostPosted: Sun Jun 21, 2020 8:56 am    Post subject: Re: Radiator Fan Won't Shut Off Reply with quote
Yeah, I think I found it. I can access it through the dash vent, but I have been pulling and wiggling it and can not get it to come out. I'll give it another try.
crazyvwvanman
PostPosted: Sun Jun 21, 2020 9:03 am    Post subject: Re: Radiator Fan Won't Shut Off Reply with quote
You can borrow the "18 relay" from the main relay panel as a test replacement for that fan relay.
The power feed to that relay socket is live all the time, so careful!
Disconnect the battery ground cable when working in that area.
Mark
damagd
damagd is offline
PostPosted: Sun Jun 21, 2020 9:38 am    Post subject: Re: Radiator Fan Won't Shut Off Reply with quote
Well, I did get the fan to shut off by taking off the driver side headlight and unplugging the green tube thing back there, the name escapes me. The alternator problem is solved. When I looked at it I discovered a wire had broken. Reconnected that and it's charging fine now. Certainly I cannot use the 18 relay and drive with it in place of the fan relay, right? Even if I can get the fan relay off, which I am still struggling with. What about pulling the switch at the bottom of the radiator behind the lower grill and cleaning it? Someone suggested to me that it sounded like a stuck switch.
damagd
damagd is offline
PostPosted: Sun Jun 21, 2020 9:49 am    Post subject: Re: Radiator Fan Won't Shut Off Reply with quote
The resistor? I think that's what the green thing is called. Anyway I just plugged it back in and the fan is not running. But, once the fan kicks on again is it going to stay on again?
crazyvwvanman
PostPosted: Sun Jun 21, 2020 12:14 pm    Post subject: Re: Radiator Fan Won't Shut Off Reply with quote
You said that unplugging the temp switch low on the radiator didn't turn off the fan.
That means the temp switch isn't the problem.
Mark
pdm777
pdm777 is offline
PostPosted: Wed Jun 24, 2020 11:24 pm    Post subject: Re: Radiator Fan Won't Shut Off Reply with quote
wild stab --- if the AC pressure is too high,
the fan will remain 'on' after shutdown. For very long time.
Trinary AC presure switch might be sending bad signal.
1990 Westy Full Camper
pbooth59
pbooth59 is offline
PostPosted: Thu Dec 31, 2020 1:25 pm    Post subject: Re: Radiator Fan Won't Shut Off Reply with quote
Hi all, new owner here. I'm having the same issue with the fan not turning off. Pulling the fan switch turns it off, as does pulling the #1 fuse. What does this mean? - Thanks!
pdm777
pdm777 is offline
PostPosted: Thu Dec 31, 2020 1:34 pm    Post subject: Re: Radiator Fan Won't Shut Off Reply with quote
if your AC pressure is too high,
For very long time.
Enough to kill your battery.
Put a set of AC gauges on it and see.
I recall unplugging the AC pressure switch
behind the rear cabinets would turn off the fan.
Lowering the AC pressure got it fixed,
On hot days, climbing hills, the high speed fan
should stay on for no more than 5 minutes after shut down.
Using a refrigerant like EnviroSafe (hydrocarbon AC alternative)
will lower pressures and cool much better than 134.
fxr
fxr is offline
PostPosted: Thu Dec 31, 2020 1:36 pm    Post subject: Re: Radiator Fan Won't Shut Off Reply with quote
Fan switch faulty - same happened to me. Cheap, easy quick swap-out.
Jim Crowther
Vespa GTS 300
pbooth59
pbooth59 is offline
PostPosted: Thu Dec 31, 2020 1:38 pm    Post subject: Re: Radiator Fan Won't Shut Off Reply with quote
Awesome thanks, it does have factory A/C but I haven't used it yet and the problem wasn't there when I first bought the Van. I'll look into that fix and the switch and report back.
*Update* Got the new switch in, and it seems to be working! Thanks!
chrowe
chrowe is offline
PostPosted: Mon Sep 06, 2021 11:51 am    Post subject: Reply with quote
My fan came on high and would not shut off unless I disconnect the battery.
Based on this thread I pulled out what I think is the high speed/3rd stage relay (see attached photos). Is there any way to test it to see if it has actually failed?
I have an 89 Syncro with no AC so I guess it is normal to have no relay in position 5. Is there a low speed/2nd sage relay somewhere else in my van?
It looks like those links to autohausaz no longer work. The current one is 70 Amps. I assume that is what is needed.
Maybe this one https://www.hansautoparts.com/357906381BRelay.aspx but it looks different.
or https://parts.vw.com/p/Volkswagen_1989_Vanagon/Relay/48302346/4H0951253A.html
or https://www.busdepot.com/8d0951253my (but it doesn't say the amps)
or https://www.busdepot.com/8d0951253 (but it has that extra metal tab)
crazyvwvanman wrote:
All 89 vans should have the relay in position 5 unless they are Syncros without A/C. That relay you linked to is not the right one for position 5, as far as I know.
In any case the missing position 5 relay isn't causing this problem. The high speed relay is up inside the dash area at the left end. It is hard to see without removing something. Look at Bentley page 87.5 and the drawing on the upper right shows the relay behind the left dash vent. That is the highest speed rad fan relay, 3rd stage.
chrowe
chrowe is offline
PostPosted: Fri Sep 10, 2021 7:16 am    Post subject: Re: Radiator Fan Won't Shut Off Reply with quote
I tested the relay and it seems to make a connection when power is supplied to it. Does anyone know what activates the relays? It seem like in my case that might be the broken part?
crazyvwvanman
PostPosted: Fri Sep 10, 2021 8:24 am    Post subject: Re: Radiator Fan Won't Shut Off Reply with quote
MarkWard wrote:
First step would be to unplug the radiator fan temp switch and see if the fan shuts off. You need to remove the "LOWER" grill. If you haven’t done this, you need to learn. Report back.
chrowe
chrowe is offline
PostPosted: Mon Sep 13, 2021 11:20 am    Post subject: Re: Radiator Fan Won't Shut Off Reply with quote
Ya, I already tried that and it makes no difference.
I talked to a mechanic who thinks it is the resistor but I can't seem to find one online.
crazyvwvanman
PostPosted: Mon Sep 13, 2021 12:53 pm    Post subject: Re: Radiator Fan Won't Shut Off Reply with quote
The resistor can't really make the fan run all the time.
When the resistor fails it keeps the fan from running on the lower speed(s).
If the lower speed doesn't work that can make high speed run a lot so that is something that can result from a bad resistor.
Mark
aarroonn
aarroonn is offline
PostPosted: Wed Jul 02, 2025 7:17 pm    Post subject: Re: Radiator Fan Won't Shut Off Reply with quote
Revisiting this topic. I am having the 'can't stop ,won't stop' issue with my rad fan as well.
I started with removing the switch from the lower radiator. - That did not stop it from running.
I removed Fuse#1 and the fan stopped.
Any insight on what step to go to next? I did not see a previous scenario where this symptom was described.
crazyvwvanman
PostPosted: Thu Jul 03, 2025 3:56 pm    Post subject: Re: Radiator Fan Won't Shut Off Reply with quote
What year and model do you have, does it have A/C?
How long have you had it, when did the problem first start?
Mark
aarroonn
aarroonn is offline
PostPosted: Thu Jul 03, 2025 5:08 pm    Post subject: Re: Radiator Fan Won't Shut Off Reply with quote
It is a 1986 Westy 2wd. It does have A/C albeit is the SCP dash version.
I have had it about 3 years
I did recently charge the A/C system and that is when this started. I thought maybe the Trinary tripped due to being overcharged so I evac'd the system.
That did not change the fan status.
I then disconnected the Trinary wiring to the radiator.
I then thought maybe the fan switch so I pulled that.
That's when i read about Fuse #1 in this thread. I pulled that fuse.
This DID turn the fan off.
That's where I am at.
Page: Previous  1, 2
Page 2 of 2
