Diagnose Codes. Is it a timing chain?
Vanagons rule
Vanagons rule is offline
PostPosted: Mon Jun 22, 2020 7:12 pm    Post subject: Diagnose Codes. Is it a timing chain? Reply with quote
To all the knowledgeable Eurovan owners out there,
I have acquired my dad’s old 2003 eurovan weekender this past year. He had passed away in 2012 and it was sold to another party, but it is now in my possession. Just had an oil change after the van sat for 99.9% of the last year. I was focusing on selling my ‘82 camper before jumping into this one. The Check Engine light had come on a while back during the handful of times I actually drove it, with a code of P0340 Camshaft position sensor A circuit, according to Autozone. The code disappeared, maybe because it was sitting awhile after that and I had to re-charge the battery.
Recently, I had the oil changed at the VW dealership. They were able to grab the codes (stored?) in it.
“Technician has 5 codes from ECM. P1340, P1570, P0300, P0305, P0303, Needs further Diagnosis to fix concerns.”
I brought it back in a week later.
“Scanned for codes, found P1340-cam position sensor incorrect correlation, P0305-cylinder 5 misfire and P0303 cylinder 3 misfire, will need to remove valve cover and upper timing cover to inspect timing to determine if timing has jumped or if chains have stretched.
Estimate to further diagnose $915
Estimate if chains are needed $3500”
It currently has 139,100 miles. Drives just fine, though a little slower to get going when I start to press the gas pedal compared to my 2011 subaru. If I press harder on the on the gas, it really goes! I don't hear any popping sound with engine.
I would love to keep it and drive it. I am a single mom with a daughter and don't want to get stranded anywhere, hence why the '82 camper was just sold.
Any thoughts on paying the $915 to have it further diagnosed and possibly $3500 if it is the chain? Shocked
I have read some of the old posts about timing chain issues.
Thanks for your help!
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Mon Jun 22, 2020 9:40 pm    Post subject: Re: Diagnose Codes. Is it a timing chain? Reply with quote
Do yourself a favor and save that bucket of cash for a good VAG code reader and a MkIV Bentley. Sadly, the EV Bentley doesn't cover the 24v VR6 engines, so you have to use the Golf/Jetta manual.
Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE.
jmciii
jmciii is offline
PostPosted: Tue Jun 23, 2020 1:36 pm    Post subject: Re: Diagnose Codes. Is it a timing chain? Reply with quote
Consider looking at this thread:
https://www.thesamba.com/vw/forum/search.php?search_keywords=cam&search_forum=48
I am in the process of working through some related codes. And my van had the timing chain replaced before I bought it.
I am (still) working on getting some good cam positioning sensors to see if that solves it. (Covid-19 has complicated an Amazon order coming out of Lativia for some reason. I want the Bosch sensors.)
Anyway, I found good guidance in the thread that I referenced above.
-John
2002 EV MV Weekender Westfalia
Abscate
Abscate is offline
PostPosted: Wed Jun 24, 2020 1:43 pm    Post subject: Re: Diagnose Codes. Is it a timing chain? Reply with quote
Nancy
Hold onto the money for now. Post your general location to see if someone nearby can guide you through the code process.
It’s normal for codes to pop up once in a while on a weathered car, and that cam code is one of the more common.
The diagnostic capabilities of the dealers on T4s usually isn’t good , so save your money.
When we had our 5th an d6th child together SWMBO said no more, and no puppies, but I did manage to get her to buy a T4
Vanagons rule
PostPosted: Wed Jun 24, 2020 8:45 pm    Post subject: Re: Diagnose Codes. Is it a timing chain? Reply with quote
@Zeitgeist 13, I got a code reader off of Groupon but it doesn't do anything when I plug it in. Probably a piece of crap, oh well. I'm not sure the Bently will help as I cannot do any of the work. I left that up to my ex-husband but that was on older vw's. Also, not really a "bucket of cash" as that '82 was running on 3 cylinders and the last of the air-cooled. Yellow Vanagon
@jmciii, The link you posted had several threads, was there a specific one?
I'd love to hear more about your van and the new cam position sensors. How hard are those to swap out?
@Abscate, Nice Van! I really do want to just drive it and go on my first camp out in it. Smile I loved my '82 camper but sold it thinking that the eurovan would be more reliable and safer for my daughter and I.
My worry is if I can get away with driving it and still catch it in time if something does need replacing before I ruin it. Maybe I would hear something? The Popping noise I read people mention?
Thank you each for your insight
I live in Grand Junction, Colorado
Nancy
'03 Weekender
Past VW's: '82 Camper x2, '88 Syncro weekender, '88 Syncro, '86 Weekender, few baywindows, split window, couple bugs, and a thing Smile
Hänsel
Hänsel is offline
PostPosted: Thu Jun 25, 2020 2:18 am    Post subject: Re: Diagnose Codes. Is it a timing chain? Reply with quote
Hi, have anyone tried OBDeleven?
I use it on my eurovan and audi,
It cost £70 for android, unfortunately more for ios .
It works well, and connects to the web , great little diagnostic tool
Abscate
Abscate is offline
PostPosted: Thu Jun 25, 2020 2:56 am    Post subject: Re: Diagnose Codes. Is it a timing chain? Reply with quote
If they could read codes at the dealer then your diagnostics are working, it sounds like your Groupon reader should go back
The cam sensor is an easy replacement with some guidance but don’t jump on that yet.
If it’s purring with no noises don’t sweat the cam chains , you will get warning.
Zeitgeist 13
PostPosted: Thu Jun 25, 2020 10:19 am    Post subject: Re: Diagnose Codes. Is it a timing chain? Reply with quote
I'll second the recommendation for OBD Eleven.
Casey--
'89 Bluestar ALH
NEAT, no ICE.
jmciii
jmciii is offline
PostPosted: Fri Jun 26, 2020 6:08 am    Post subject: Re: Diagnose Codes. Is it a timing chain? Reply with quote
Nancy, I step aside and defer entirely to Abscate's guidance and recommendations. I have crawled Abscate's contributions throughout these forums and trust the information mightily. (Electrical subject matter, in particular, seems to be an area where Abscate thrives.)
That said, FedEX literally just dropped off my Bosch OEM sensors from FCPEuro minutes ago.
-John
Abscate
Abscate is offline
PostPosted: Fri Jun 26, 2020 10:30 am    Post subject: Re: Diagnose Codes. Is it a timing chain? Reply with quote
Ive met Telford, Senator, and you are no Telford..
Very Happy Very Happy Very Happy
Bay Humor
jmciii
jmciii is offline
PostPosted: Wed Jul 01, 2020 7:34 am    Post subject: Re: Diagnose Codes. Is it a timing chain? Reply with quote
I have updated both of my cam positioning sensors with Bosch OEM and cleared the codes. I headed out for a weekend jaunt and the check engine light is back. Sad
Some of you may recall this work being done on my van with the previous owner:
Nancy, to make sure this thread is completely on topic, here are all of the steps that were taken for my timing chain repair. Replacing my sensors did not eliminate any codes for me. I am told that I might have a cam gear issue. I have started a thread on that back in December in hopes to learn more.
https://www.thesamba.com/vw/forum/viewtopic.php?t=728713
-John
Abscate
Abscate is offline
PostPosted: Wed Jul 01, 2020 8:43 am    Post subject: Re: Diagnose Codes. Is it a timing chain? Reply with quote
You monitor it by removing the inner drain plug and topping off until it starts to drain from that. Sort of like a pipe standing up in a lake, when the lake reaches the right level, it goes into the pipe.
Find where the leak is coming so you can address it. Trans fluid levels have to be right for an AT to be happy, not just 'enough' like engine oil.
Zeitgeist 13
PostPosted: Wed Jul 01, 2020 8:46 am    Post subject: Re: Diagnose Codes. Is it a timing chain? Reply with quote
I may be wrong, but it's my recollection that the later 24v engines are less prone to t-gear wear than the 12v. Mine was perfect @ 160k.
You need to crawl under there and determine where the trans oil is leaking. My bet's on either the pan gasket, or the speed sensor o-ring.
I installed a trans dipstick kit, which I think was purchased from Poptop Heaven.
Casey--
'89 Bluestar ALH
NEAT, no ICE.
Stripped66
Stripped66 is offline
PostPosted: Wed Jul 01, 2020 8:54 am    Post subject: Re: Diagnose Codes. Is it a timing chain? Reply with quote
jmciii wrote:
When I called the shop that did it, the timing gear was not addressed alongside all of this work which is probably regrettable.
It says right on the invoice "intermediate gear". Perhaps you've experienced a failure with one of the other timing gears (I'm not suggesting you have), which would be surprising; it's the intermediate gear that is known to fail prematurely, and they replaced it.
jmciii wrote:
(Worth noting that one of the sensors that I removed is for a Porsche Cayenne and not a part number that I can attribute to my van at all. This shop is a Porsche-first place as far as I can tell and I reckon they just threw whatever they had in there for the previous owner.) Evil or Very Mad
The Cayennes shared the same VR6 engine, so the sensor is probably the same part but with a Porsche part-number.
Get the proper scan-tool and figure out what's wrong. Piecing together random part-replacements with non-descript CELs and then fuming about what the shop may or may not have done, when you don't understand what the shop may or may not have done, isn't going to diagnose or fix the problem(s).
66brm wrote:
Bodacious wrote:
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor.
I don't think electrickery works that way
jmciii
jmciii is offline
PostPosted: Wed Jul 01, 2020 10:10 am    Post subject: Re: Diagnose Codes. Is it a timing chain? Reply with quote
Thanks, everyone.
Stripped66, please note that I have engaged the shop in conversation in addition to evaluating their invoice.
I might be wrong about "fuming" about the sensor. You've been right to call me out on that. But, the shop itself is telling me that they recommended that the previous owner replace the (a) timing gear and he declined. This was through phone conversations. I think I'm doing a thorough and responsible job engaging the shop, which is unfortunately in a different city, to understand what they did and didn't do. So, I think you're being a little dismissive and harsh in your response.
I have a set of detailed codes. I've shared them elsewhere in the forums. here. I came into this thread to ask about transmission fluid and I appreciate the guidance. -John
-John
Stripped66
PostPosted: Wed Jul 01, 2020 11:28 am    Post subject: Re: Diagnose Codes. Is it a timing chain? Reply with quote
So, that is not the actual invoice of work that was previously done to your van by the shop in question?
Allow me to be a bit more dismissive: Start your own thread. This thread has never been about transmission fluid. Your comments related to the engine timing components were initially on-topic, but the whole transmission discussion is off-topic and not related to the original poster's inquiry in the least.
ocelotpotpie
ocelotpotpie is offline
PostPosted: Wed Jul 01, 2020 11:30 am    Post subject: Re: Diagnose Codes. Is it a timing chain? Reply with quote
This is definitely a myth. I've seen many 24v timing chains/gears worn first hand.
Can you confirm where you got this?I thought the dipsticks were no longer available.
If still an option, it's definitely something I'd recommend jmciii pick up. It's easy to drain excess fluid but otherwise pretty tough to know if you're low.
jmciii - I definitely recommend getting a proper scan tool or getting in touch with someone who has one. The generic readers give you generic codes like "cams out of sync" or "O2 sensor failing" whereas the VCDS tool will tell you which sensor is failing, and where. It's a LOT easier to pinpoint issues. Often times there are other issues that might not be obvious, like transmission codes which may signal some other impending problem.
Looking at the shop invoice and hearing about your dripping I'd be a little worried that it's the torque converter seal. But the best thing to do is to clean the area very well and then see where it's dripping. It could be as simple as a drain plug that needs to be snugged.
Remove the belly pan if it isn't already removed, and then it's pretty easy to slide underneath. Being able to work on the Eurovan without jacking it up is one of its many charms. Smile
jmciii
jmciii is offline
PostPosted: Wed Jul 01, 2020 11:58 am    Post subject: Re: Diagnose Codes. Is it a timing chain? Reply with quote
I have upset Stripped66 by bringing up transmission fluid on this thread. He or she has urged me to start my own thread. This seemed like an organic progression in the discussion and it seems to be continuing just fine. This is the first time I've run into some fuss with other forum members here.
I chimed in to try to help Nancy early on as I had tangential issues. I thought that by sharing my actual invoice I could also add some value about what might happen if/when Nancy addresses the timing chain.
So, all apologies if I'm out of line. It seemed relevant to me.
I'm going to head over to my Cam Gear thread from December which wasn't very interesting at the time. If anyone wants to join me there I would appreciate any feedback.
https://www.thesamba.com/vw/forum/viewtopic.php?t=728713&highlight=cam+gear
-John
Stripped66
PostPosted: Wed Jul 01, 2020 12:12 pm    Post subject: Re: Diagnose Codes. Is it a timing chain? Reply with quote
You seemed to take offense at me commenting on your cam gear experience. And you seemed to only want comments on your transmission experience.
And, you didn't tell anybody that you only were here to talk about your transmission experience:
jmciii wrote:
here. I came into this thread to ask about transmission fluid...
I don't think I'm making a fuss. I'm simply not as clairvoyant as the rest of the forum members you deal with.
jmciii
jmciii is offline
PostPosted: Wed Jul 01, 2020 12:29 pm    Post subject: Re: Diagnose Codes. Is it a timing chain? Reply with quote
I apologize again for introducing trans fluid into this thread. I absolutely invite commentary on my cam gear thread and I've rekindled an original inquiry specific to that topic.
I read the following comment from you as rude and dismissive and not something I've experienced here yet. If I read it wrong so be it.
I have an invoice. I have phone conversations with the shop. I have feedback from the prior owner. I have codes, however vague, so I'm doing what I can to understand what the shop did and didn't do. I don't think I'm asking for clairvoyance. I think the shop that did something to create a transmission leak when they repaired the timing chain. I think the sensor codes that Nancy is experiencing has something to do with the timing chain repair on my van as well. I think it's all related.
-John
