Who has their battery up front?
jr_vw2
jr_vw2 is offline
PostPosted: Sun Jul 12, 2020 3:53 pm    Post subject: Who has their battery up front? Reply with quote
So I have next to zero options for my battery location. Thinking maybe up front opposite the master cylinder. Who has a battery up there and what model battery fits?
Jeremy
Chattanooga TN
oprn
oprn is offline
PostPosted: Mon Jul 13, 2020 3:57 am    Post subject: Re: Who has their battery up front? Reply with quote
Good question, I may be faced with this too when I convert to IRS.
WMAGRU
WMAGRU is offline
PostPosted: Mon Jul 13, 2020 4:38 am    Post subject: Re: Who has their battery up front? Reply with quote
I use an Odyssey PC680 mounted directly behind the passenger seat. This battery can be mounted in any position except upside down.
jr_vw2
jr_vw2 is offline
PostPosted: Mon Jul 13, 2020 5:36 am    Post subject: Re: Who has their battery up front? Reply with quote
Those dimensions look perfect. My concern should be with only having 170 CCA and a battery cable that's 8 feet long.
Does that battery have any struggle cranking your buggy?
Jeremy
Chattanooga TN
Dale M.
Dale M. is offline
PostPosted: Mon Jul 13, 2020 6:15 am    Post subject: Re: Who has their battery up front? Reply with quote
My solution was to cut about 1.5 inches off bottom of battery box and glassed in new bottom...
At full droop IRS arms cleared battery box...
Putting battery up front creates a situation for excessive long positive battery cable, which ""may"" cause voltage drop,. which ""may"" cause starter cranking problems...
Dale
WMAGRU
WMAGRU is offline
PostPosted: Mon Jul 13, 2020 6:31 am    Post subject: Re: Who has their battery up front? Reply with quote
PC680 is mounted behind the passenger seat so the battery cables are only about 26" long. No problem on cranking power. Fires right up every time.
slalombuggy
slalombuggy is offline
PostPosted: Mon Jul 13, 2020 9:07 am    Post subject: Re: Who has their battery up front? Reply with quote
Mine is over the beam but I don't have a gas tank up there.
I started my race car engine with a lawn tractor battery running through 10 feet of cable for both terminals. But I use #4 welding cable with soldered lugs. No problems even when hot.
brad
jspbtown
jspbtown is offline
PostPosted: Mon Jul 13, 2020 12:30 pm    Post subject: Re: Who has their battery up front? Reply with quote
The Speedster crowd has their batteries up front. Use the correct wiring and on all but the most radical engines you won't have an issue
bim55
bim55 is offline
PostPosted: Mon Jul 13, 2020 5:31 pm    Post subject: Re: Who has their battery up front? Reply with quote
Here’s a pic of my current car with a battery cage I found on Summit.
Boston Bob E.
www.bimelliott.com www.deserterownersgroup.org
Rockbound
Rockbound is offline
PostPosted: Thu Jul 16, 2020 7:34 am    Post subject: Re: Who has their battery up front? Reply with quote
i did mine up front but i also do not have a stock vw chassis
4 bolts under neath to lower it down to change it. welded nuts on top of frame rails
oprn
oprn is offline
PostPosted: Thu Jul 16, 2020 10:47 am    Post subject: Re: Who has their battery up front? Reply with quote
Clever!
