Marlin Samba Member
Joined: May 22, 2010 Posts: 85 Location: Braselton Ga
Posted: Sat Jul 04, 2020 10:25 am Post subject: Oct '68 13S Manx 1 |
I found this body back in 1994 or 1995 in a small field beside a barn.
It was the body itself just sitting there. I purchased for a small sum, brought it home, and put it with the rest of the bodies/buggies I had at the time. When I moved in 2005, all were sold but My 1st fiberglass buggy, which is a Spatz, and this one. We moved again in 2008 where I stored it in the basement. In 2010, I sent pictures to Winnie for verification and to be added to the registry. In June, I joined the Manx club, and by July the family and I were on our way to Big Bear to meet Bruce and Winnie for the first time.
Taking into consideration its original, survivor condition, I chose not to restore the buggy but to preserve it. It is a little banged up, scratched up, and cracked but it is original.
The ID plate and rear emblem was intact but the front badge was missing.
The abs dash was there but in poor condition.
I would like the end result to look as if the buggy was pulled out from a barn, cleaned up, and put back on the road. The build has been challenging in the sense of preserving and acquiring period correct parts. To find a true survivor in a barn or garage is few and far between. Finding one is a challenge in itself.
I decided to build one (Barn Find Looker).
Pictures are just prior to buffing the gel coat.
Here is a link to the pan shortening process
https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
Marlin Samba Member
Posted: Sat Jul 04, 2020 10:32 am Post subject: Re: Oct '68 13S Manx 1 |
I added only one adjuster to the beam. I like to start my cuts with pipe cutters.
This gives a true guide for the rest of the cutting all the way through with a port-a-band or sawzaw.
Perfectly in place welding |
mackmix Samba Member
Joined: June 10, 2008 Posts: 537 Location: San Diego California (SO CAL)
Marlin Samba Member
Posted: Sat Jul 04, 2020 11:03 am Post subject: Re: Oct '68 13S Manx 1 |
Thank you Mackmix
There's something about original old school buggies that's just got that cool factor about them. |
Marlin Samba Member
Posted: Sat Jul 04, 2020 2:59 pm Post subject: Re: Oct '68 13S Manx 1 |
I made a new dash frame
The ABS dash is in really sad shape
Tried plastic welding the cracks and patched a hacked radio hole
All repairs made, will be spraying with a textured peal coat to cover it |
oprn Samba Member
Joined: November 13, 2016 Posts: 15297 Location: Western Canada
Posted: Sat Jul 04, 2020 4:14 pm Post subject: Re: Oct '68 13S Manx 1 |
| mackmix wrote: |
| That's perfect! Love that you're keeping it original! |
^^This!^^^ |
Marlin Samba Member
Posted: Sat Jul 04, 2020 4:58 pm Post subject: Re: Oct '68 13S Manx 1 |
I was fortunate to have a Samba member that was restoring his manx and was selling his used front and rear bumper,roll bar,windshield, and skid plate.
This helped tremendously with some of the correct parts.Thankfully he didn't mind boxing and shipping these to Georgia.
The front bumper/ nudge bar needed a little persuasion with the rubber mallet
Marlin Samba Member
Posted: Thu Jul 09, 2020 6:07 am Post subject: Re: Oct '68 13S Manx 1 |
68' H case for the engine. Externally, a manx power stage V build.
vw7266 Samba Member
Joined: April 28, 2004 Posts: 3055 Location: the point, ohio
Posted: Sun Jul 12, 2020 8:18 am Post subject: Re: Oct '68 13S Manx 1 |
| I have nice set of dietz 820 headlights if youre searching for the proper ones for your manx. Keep up the great preservation work |
Marlin Samba Member
Posted: Sun Jul 12, 2020 10:57 am Post subject: Re: Oct '68 13S Manx 1 |
Body bolted in place
adams77 Samba Member
Joined: September 12, 2008 Posts: 221 Location: Statham, GA
Posted: Sun Jul 12, 2020 5:15 pm Post subject: Re: Oct '68 13S Manx 1 |
Nice work! _________________ If Stupidity got us into this mess, then why can't it get us out? ....Will Rogers |
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6768 Location: Northern California
Posted: Sun Jul 12, 2020 11:04 pm Post subject: Re: Oct '68 13S Manx 1 |
Really impressive restoration.
When I rebuild a Manx, I weld up the extra or misplaced holes in the dash frame. The angles and bends are hard to duplicate
It looks like you have a pair studs to mount the steering column on the crossbar. Those were originally hollow spacers bolts fit through
Marlin Samba Member
Posted: Mon Jul 13, 2020 4:39 am Post subject: Re: Oct '68 13S Manx 1 |
vw7266 ~ Thanks for the 820's, (a piece of the puzzle I didn't have)
adams77 ~ Thank you!
BL3Manx ~ Thank you! The bends were tough for sure.
You are the expert, I've read many of your posts in the past
and I've learned a lot. Thank you for sharing your knowledge! |
Marlin Samba Member
Posted: Mon Jul 13, 2020 3:18 pm Post subject: Re: Oct '68 13S Manx 1 |
The manx adapter adds to the length of the steering shaft,
so I took out about 2 inches to keep the steering wheel in its normal position. The manx steering wheel was a little rough so I used peal coat on the it,
we'll see how it holds up. The dash turned out pretty good.
Marlin Samba Member
Posted: Sun Aug 16, 2020 10:26 am Post subject: Re: Oct '68 13S Manx 1 |
I new the gel coat would buff really good so this is why I decided to go the preservation route.
Making progress on the engine.The 009 is only there for the build.
An 010 is what was used I believe .I'm thinking of using the newer cast steel distributor that looks like an 010 but has internals of the 009 made by kuhltek.
61-62 shroud is original paint
legotech7 Samba Member
Joined: May 09, 2009 Posts: 973 Location: North Carolina
Posted: Thu Sep 10, 2020 4:45 pm Post subject: Re: Oct '68 13S Manx 1 |
Nice build. Where did you get the rubber sleeve for your hood and tank? the hole location is the same as mine.
Marlin Samba Member
Posted: Fri Sep 11, 2020 6:48 pm Post subject: Re: Oct '68 13S Manx 1 |
| It is a 49-55 Chevy truck filler neck grommet |
Posted: Sat Sep 12, 2020 6:33 am Post subject: Re: Oct '68 13S Manx 1 |
| Really?. I Ordered one for a 69 vw bus, I hope it fits.. Thanks.... |
Marlin Samba Member
Posted: Wed May 05, 2021 5:02 pm Post subject: Re: Oct '68 13S Manx 1 |
progress on the Manx power engine
Allmost complete
Used Koni shocks painted with new decals
Sand commands just for rollers,to worn and cracked to run on the road
820's installed |
squareweave Samba Member
Joined: November 15, 2004 Posts: 450 Location: British Columbia
Posted: Wed May 12, 2021 7:33 am Post subject: Re: Oct '68 13S Manx 1 |
| Wow, I've missed this thread up until now. Great job on the preservation work. Keep the updates coming. |
