How do I screw this back in?
dwschwartz
dwschwartz is offline
PostPosted: Mon Aug 03, 2020 10:12 am    Post subject: How do I screw this back in? Reply with quote
'87 Westy. Noticed this morning I've got a screw loose(!) on the right side, in front of the back tray. Note how the tray is leaning to the right. Removed the face plate, but not sure how to get to the screw from here. Any suggestions? Thank you.
MarkWard
MarkWard is offline
PostPosted: Mon Aug 03, 2020 10:26 am    Post subject: Re: How do I screw this back in? Reply with quote
Your going to need to be innovative. That bolt is installed prior to putting the lower cabinet into place. I recall a Philip’s head fastener. A flex screw driver or a 90 ratchet screw tool. I purchased both from harbor freight for my canvas top project.
Or, take the bolt out and match it to a hex bolt and a swivel socket and you might be golden.
Sodo
Sodo is offline
PostPosted: Mon Aug 03, 2020 11:11 am    Post subject: Re: How do I screw this back in? Reply with quote
Some DIY fellers love a good fight like this.
Maybe replace it with a much longer M6 allen screw,
adding a tube spacer that places the screwhead down lower to an accessible location.
With a holesaw, cut a large access hole in the bracket?
Be careful that the pilot drill point doesn't damage the copper condenser tubes.
....KTMs, GasGas, SPOT mtb
dwschwartz
PostPosted: Mon Aug 03, 2020 12:50 pm    Post subject: Re: How do I screw this back in? Reply with quote
Thank you @sodo and @markward.
