Will not start
Robs66vw
Robs66vw is offline
PostPosted: Thu Aug 06, 2020 12:25 am    Post subject: Will not start Reply with quote
My 66 beetle has a good battery but will not start. Will not even turn over. I turn the key - and nothing. Not a sound. My lights and gauges all work. Anyone have any suggestions?
mukluk
mukluk is offline
PostPosted: Thu Aug 06, 2020 2:22 am    Post subject: Re: Will not start Reply with quote
Take a look at your starter and make sure the ignition terminal 50 wire (red wire shown in the picture below) is firmly attached to the spade terminal on the solenoid. If that one is good, see if the wire has come loose from terminal 50 at the ignition switch.
Cusser
Cusser is offline
PostPosted: Thu Aug 06, 2020 6:46 am    Post subject: Re: Will not start Reply with quote
See above.
If that wire is attached, put DC voltmeter across battery terminals and read voltage. Then turn key over to start position, re-read the voltage. Post those numbers.
Robs66vw
Robs66vw is offline
PostPosted: Thu Aug 06, 2020 4:03 pm    Post subject: Re: Will not start Reply with quote
Ok I will try that as quick as I get a chance. Thanks for ur help
Eric&Barb
Eric&Barb is offline
PostPosted: Thu Aug 06, 2020 5:11 pm    Post subject: Re: Will not start Reply with quote
Clean/dielectric grease BOTH ends of each of the battery cables also. Do same with the transaxle to body ground cable.
In Stereo, Where Available!
